New truck now has a million little sap drops on it.
Discussion in 'Detailing' started by GratefulDean, Aug 13, 2020.
  1. Aug 13, 2020 at 8:16 AM
    GratefulDean
    GratefulDean [OP] Swagless
    Dean
    Rocky Mountains
    2020 Tundra SR5 TRD in Cement Grey
    Bed Rack, Decked System, Softopper
    So, I noticed this morning what looked like sand blasting damage on my windshield. Upon further investigation they turned out to be tiny droplets of what I think is sap and they are all over the truck. They seem to be rather intractable.
    What product can I use to get rid of these? Will the product require me re-waxing my 1 month old truck?
    Thanks all!
  2. Aug 13, 2020 at 8:17 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Goo gone is usually pretty good against sap. And yes, you'll definitely have to wax afterwards.
    BravoDeltaRomeo and War Machine like this.
  3. Aug 13, 2020 at 8:25 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I like Stoner Tarminator, it works great and is easy to find. If it's just the windshield then you can use a razor carefully, unfortunately im sure the stuff is all over your truck. Id use tarminator, clay, wash then seal or wax
  4. Aug 13, 2020 at 8:47 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  5. Aug 13, 2020 at 9:25 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Bug and tar remover. Green spray bottle works well. I get slot of sap on my and my gfs truck. Auto goo gone if it’s really set on.
  6. Aug 13, 2020 at 9:59 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    A good warm water wash with a good car specific detergent will get rid of the spots. Be sure to use one that's good for grease and follow up with a good wax. What you're seeing probably isn't sap, it's honeydew from aphids. Basically, it's aphid poop. If it's your tree, go to a local gardening supply store and buy a couple of containers of ladybugs. They'll be chilled when you get them. Keep them in the fridge until night time, water the area around the tree and up into the branches, and release the ladybugs at the base of the tree. As they warm up, they'll climb the tree and feast on the aphids. I modified some bird houses to that the opening is too small for a bird, but plenty big enough for ladybugs. I release a fresh batch every spring.
    Updated with a picture I forgot I had. The bars on the opening are a couple of pieces of brass rod held in by a couple of screws.
    ToyoMafia and Boerseun like this.
  7. Aug 13, 2020 at 3:03 PM
    GratefulDean
    Dean
    Rocky Mountains
    Holy Sh!t, thanks everyone. I was hoping not to have to wax the truck until spring. May clean it off and go ceramic...
    Aphid poop,
  8. Aug 13, 2020 at 3:06 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Bro this post is awesome f’ing ladybugs. Tight work
  9. Aug 13, 2020 at 3:32 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This all the way. I started noticing the same thing recently, my friend who has a degree in biology and is a landscape designer said aphid poop. I've got ceramic and instabead, so it comes off easily with a quick detail fluid and a mf towel between washes.
    Having raised roses at my previous house, I can confirm ladybugs are the real deal. Release the bugs!
    War Machine and ToyoMafia like this.
  10. Aug 27, 2020 at 7:27 AM
    GratefulDean
    Dean
    Rocky Mountains
    So, I waited 2 weeks (I usually wash my truck Friday mornings) and went ahead with a wash. Power wash only, no manual agitation. That took care of the problem... I was so stressed about it. I have to do a huge detail on me wife's 2014 Highlander which hasn't been waxed since it was new and was not looking forward to doing a similar strip and wax on my new truck.
    I did park under a large flowering tree, I assume that's where they came from. Next time I'll roll with ladybugs as a preventative measure...
    Randy Morton likes this.
  11. Aug 27, 2020 at 7:33 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I have the same issue as you, but I've washed twice with a power wash and had no success. Did you do anything else?
  12. Aug 27, 2020 at 7:40 AM
    GratefulDean
    Dean
    Rocky Mountains
    They have hot water from the pressure washer at the car wash I go to. That may have been the ticket. I was going to consider getting scalding hot water in a couple of 5 gal buckets with car wash soap if that didn't work. Just wear some kitchen gloves.
  13. Aug 27, 2020 at 8:06 AM
    The Californian
    Eric
    Hot water must be the key, thanks!
  14. Aug 27, 2020 at 8:08 AM
    GratefulDean
    Dean
    Rocky Mountains
    Good Luck!
