Have mercy - another "Will these wheels fit" question
Discussion in '1st Gen Tundras (2000-2006)' started by 270Fan, Aug 26, 2020.
  1. Aug 26, 2020 at 8:48 PM
    270Fan
    270Fan [OP] New Member
    2004 Silver Tundra 4x4 DC
    Some of you may have seen my "busted Tundra" thread where I tell the story of my wheel coming off while I was going 65mph down the highway. For all I know that wheel is still rolling and now I find myself in need of new wheels. Since I've been bleeding cash into this truck I'm looking to go budget-wise. I guy offered me a good deal on these FJ Cruiser wheels. He says they fit a 2007-2014 FJ Cruiser but was not sure about a 2004 Tundra DC 4x4. Here's the specs he provided:
    Bolt Pattern - 6X139.7MM
    Size X Width - 16X7.5 Inch
    Offset - 15MM
    And a picture:
    Have mercy on me, the last 6 days have been brutal and I'm one broken shoelace away from losing my mind.
    Thanks
    Phantom25 likes this.
  2. Aug 26, 2020 at 8:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They should fit fine. Tacoma rims fit, and fj/tacoma are basically the same
    270Fan[OP] likes this.
  3. Aug 26, 2020 at 8:51 PM
    aredub
    aredub Supply Chain Guru
    USA
    2001 Tundra SR5 AC 4.7 2WD
    King Coilovers, Pro Comp Wheels, BFG KO2s, Kenwood head unit
    They sure will
  4. Aug 26, 2020 at 8:56 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Get 'em!
  5. Aug 26, 2020 at 9:03 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Waaaaaaait what size tire ate you planning on?
  6. Aug 26, 2020 at 9:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yup they fit... I have the black ones
  7. Aug 26, 2020 at 10:57 PM
    270Fan
    265/75/16
    Truck has a 2.5" lift.
    Thanks everybody.
  8. Aug 27, 2020 at 4:41 AM
    Nobody's gonna ask the important question?
    You never found the other wheel? So it was like
  9. Aug 27, 2020 at 10:28 AM
    First thing I'd try to do is get the shoelaces out of your head! o_O
  10. Aug 27, 2020 at 10:31 AM
    This is one of those cases where you don't want to find the other wheel. That's the kinda stuff that kills people in oncoming cars. Here's a mild version:
    https://www.youtube.com/watch?v=WiFTdXlcKF0
    PS - @ OP, yes, they'll fit!
    270Fan[OP] and bmf4069[QUOTED] like this.
  11. Aug 27, 2020 at 10:58 AM
    270Fan
    I looked for the wheel and never found it. Fortunately it was a divided highway and nobody else was impacted by it - like in the video @shifty` posted. It's a strange feeling watching your tire go by you at 65mph and then just disappear into the desert, all the while you're in a drift trying not to roll the truck.
    The tires I plan to put on are 265/75/16. I asked about these wheels since they are 7.5" wide vs the 7" stock, wanted to make sure the tires will fit the wheels properly and the wheels will fit the truck properly.
    Darkness and bmf4069[QUOTED] like this.
  12. Aug 27, 2020 at 11:01 AM
    I had a wheel come off a double axle trailer I was pulling. It went into the bar ditch, flew over the power lines, and came to a rest in a field. Farmer Joe saw it and went over to it, took a leak, then threw the tire in his truck and drove off. Just a really odd situation all around.
  13. Aug 27, 2020 at 11:31 AM
    Did you have factory 16" or 17"? Do some of the DC's with 17" wheels have clearance issues with 16" wheels?
  14. Aug 27, 2020 at 12:03 PM
    empty_lord
    05 rollover special
    These 16s should fit any 1st gen tundra with the larger calipers
  15. Aug 27, 2020 at 12:14 PM
    270Fan
    Forgive my ignorance, but how do I know which calipers I have?
    According to the factory sticker, it came with 17" Alloy Wheels w/P265/65R17 Tires. The guy I bought it from changed them out to these with 265/70/16 tires
    I need a drink....
  16. Aug 27, 2020 at 3:38 PM
    empty_lord
    05 rollover special
    05-06 have the larger calipers.
  17. Aug 27, 2020 at 4:38 PM
    Professional Hand Model
    Fred
    Hand Protectors
    One time I had a drunk driver jump the median and come head on. Last second he jerked the wheel and jumped back into his proper lane except his wheel cover popped off in the process. It became airborne like a frisbee coming at Mach 1.23 headed vertically straight for my head like a buzz saw. Last second (again) the frisbee action made the cover curve off before making contact with windshield.
    One of my two Guardian Angels (or both) must have deflected both driver and cover from collision. The Angel didn’t clean me drawers, though. :rofl:
  18. Aug 27, 2020 at 4:44 PM
    270Fan
    Mine's a 2004. Does that mean they won't fit and I should part it out?
  19. Aug 27, 2020 at 7:58 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Here is how you figure out what other wheels/tires will fit your tundra. If you are looking at Toyota OEM wheels, type in your model/year. (offset is the ET number which is in mm). 3B5F6EF6-5111-4165-855D-14FE412A0017.jpg
  20. Aug 27, 2020 at 8:04 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    270Fan[QUOTED][OP] likes this.
  21. Aug 27, 2020 at 8:19 PM
    270Fan
    Lil Steve[QUOTED] likes this.
  22. Aug 27, 2020 at 10:41 PM
    empty_lord
    05 rollover special
    nothing fits. send the truck to me.
    but seriously, these wheels should fit no issue. the bigger calipers have issues with some 16" wheels, but these wheels fit even without double stacked weights.
    Hbjeff, bmf4069 and Darkness like this.
  23. Aug 28, 2020 at 5:37 AM
    Go bigger!
    Fo real, you might consider 275's. They will fill out the wheel well a bit more without sacrificing MPG much and they shouldn't rub. Unless you have the tires already of course.
