Need some help and advice correcting my truck suspension
Discussion in 'Suspension' started by Yangins, Aug 21, 2020.
  1. Aug 21, 2020 at 8:27 AM
    Yangins
    Yangins [OP] New Member
    Lue
    2015 crew max
    Purchased truck a week ago. New to lifted trucks.
    2016 Platinum with TRD SC.
    Tires are 35x12.5 17
    Current SuspensionSetup is Toytec spacer and block spacer on back. This is the way i got it.
    Currrent front is sitting at 40 inch and rear is 42.
    i would like to level with a 2-2.5 left setup.
    I want to switch to Icon 2.5 VS CDVC Coilover kit.
    Also want to get rid of blocks in the back and go to helper/add on leaf spings.
    Need recommendation on help springs?
  2. Aug 21, 2020 at 8:29 AM
    Yangins
    Lue
    2015 crew max
  3. Aug 21, 2020 at 8:31 AM
    Yangins
    Lue
    2015 crew max
    More pics
  4. Aug 21, 2020 at 8:37 AM
    Dilgaf
    Dilgaf New Member
    Dylan
    2015 Toyota Tundra Limited Crewcab
    Kings 2.5 Icon add a leaf LSK UCAs
    Need help looking for leaf springs? Deaver springs are probably one of the most reputable. If you don't want to spend money on brand new springs you could go to an add a leaf
  5. Aug 21, 2020 at 8:38 AM
    Yangins
    Lue
    2015 crew max
    Add on would be prefer the way.
  6. Aug 21, 2020 at 8:43 AM
    Dilgaf
    Dilgaf New Member
    Dylan
    Icon sells an add a leaf option. As for coilovers there are many options, do you want to have reservoirs? Adjusters? you can go mid travel which increases travel by 1" but you have to buy aftermarket UCAs.
  7. Aug 21, 2020 at 8:48 AM
    Dilgaf
    Dilgaf New Member
    Dylan
    I would go through the suspension thread and see other peoples set ups so you can get an idea of what you want. I have Kings 2.5 Ext Coilovers with resevoirs. LSK UCAs and I have an Icon add a leaf in the rear. With my coilovers maxed out and the Add-a-leaf I wanna say my rear sits about n inch higher.
  8. Aug 21, 2020 at 8:48 AM
    Yangins
    Lue
    2015 crew max
    really would like to keep stock UCA.
    So you have a valid point. Will go with no reservior and mild travel. For my use it will be fine. I am not rock crawling. Just overlanding/campimg.
  9. Aug 21, 2020 at 8:53 AM
    Damn. That rust would drive me nuts.
  10. Aug 21, 2020 at 8:55 AM
    Yangins
    Lue
    2015 crew max
    Ya, wisconsin will have to fluid film the bottom before winter. 880FA8BA-A0C8-48EE-B313-4014B034E7B5.jpg
  11. Aug 21, 2020 at 9:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Lots of people swear by the coach builder shackles. Much cheaper than replacing leaf springs.
  12. Aug 21, 2020 at 9:10 AM
    Yangins
    Lue
    2015 crew max
    will loo into it.
  13. Aug 21, 2020 at 9:24 AM
    Dilgaf
    Dilgaf New Member
    Dylan
    I know you didn't ask for my opinion. But, I think a lot of people will agree too, if you are going to spend the extra money on some decent coilovers then you might as well get the UCAs and the Ext. Coilovers. Also, saw that you had Dirty5s (35s), depending on the offset of your wheels you will have to do some trimming. I think +25 is the sweetspot for fitting larger tires on these trucks
  14. Aug 21, 2020 at 9:36 AM
    Yangins
    Lue
    2015 crew max
    Will see either go mild or wild. Really have to think what I use it for.
    looks like it is goof t to be mild to save a lot of trouble.
  15. Aug 21, 2020 at 9:45 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    @Yangins
    how do you like the RTs?
    been sniffing around them in the 35x10.5x17 size
  16. Aug 21, 2020 at 9:51 AM
    Yangins
    Lue
    2015 crew max
    so far good. Noise is not bad at all. ride is way better than the 20's and 305 that was on there.
  17. Aug 21, 2020 at 10:22 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    without a doubt a 35 on a 17 vs 20 will be much more comfortable.
    any opportunities to test out wet traction?
  18. Aug 21, 2020 at 6:05 PM
    Yangins
    Lue
    2015 crew max
    Not yet.
  19. Aug 25, 2020 at 5:17 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    Was talking with the local offroad shop and was quoted $425 for the Icon leaf pack for the rear. Looking to add about 1" cause when I load my bikes in the back I think it is a bit low. Pic doesn't really show it as I am heading down hill a bit.
