Tire up sizing downside
Discussion in 'Wheels & Tires' started by Djone27, Aug 24, 2020.
  1. Aug 24, 2020 at 7:35 AM
    Djone27
    Djone27 [OP] New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I currently have 285/55R20 BFG KO2s (32.3" x 11.7" @ 51lbs). Im planning on switching to Cooper AT3 XLTs. Looking at either 275/60 or 275/65. The Coopers are .7" / 1.9" taller, .6" / .7" narrower respectively, and 5lb / 9lb heavier respectively. Preliminary measurements appear to show the 275/65 will fit with little or no modifications (maybe just removing the front guard on the bumper). How will that additional weight affect the truck? 2017 Crewmax 4x4 SR5 with black TSS rims (20 x 9 +50). Stock height, stock black shocks/suspension.
  2. Aug 24, 2020 at 7:43 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive run a few tires
    oe Michelins(current) at 42 lbs
    Bfg 275/65/18 at 51 lbs
    toyo 35x12 at 67lbs
    massive difference in transmission shifting with the different tires. Dropping down from the bfg to the Michelins has really improved my trans shifting on acceleration and on the highway.
    the 35s were awful with stock gears. The taller the height, the lower your rpms get for a given speed. The weight also lowers your mechanical advantage. You can feel it. I do a lot of city driving, so the feel of accelerating is important to me and the P rated tires are much better for that being lighter weight. You could consider a 275/60 in a P rated? Split the height/weight difference
    I never felt a handling difference between any, but i have stiffer shocks, braking with taller tires is slightly worse, but our brakes are so large it was more than fine.
    TRDblvd likes this.
