Speaker Replacements?
Discussion in 'Audio & Video' started by 2018Tundo, Aug 15, 2020.
  1. Aug 15, 2020 at 8:00 PM
    2018Tundo
    2018Tundo [OP] New Member
    cahd
    2018 Tundra SuperCrew
    Ive done some looking on crutchfield just to get a idea on the size of all my speakers in my 2018 Non Jbl Radio. Seems like Kicker makes a KS line that has replacements for all doors, fronts at the windshield also the center. Has anyone ran these? I plan on swapping out the HU soon just wondering how good or bad these will sound off the factory amp. I know its weak.
  2. Aug 15, 2020 at 8:03 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    New spwakers will not sound much better without new amp and/or head unit.
    jobe likes this.
  3. Aug 16, 2020 at 2:56 AM
    jobe
    jobe New Member
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    i think you should replace the head unit first and then continue on to speakers.
  4. Aug 16, 2020 at 5:09 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yes, start with your headunit. In my old tundra I swapped in a cheap android one, and that made a huge improvement and louder too.
  5. Aug 16, 2020 at 5:48 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    HU and some sound mat of some sort will be a noticeable improvement. Really tightened up the low end in the front doors.
  6. Aug 16, 2020 at 6:18 AM
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    I have the 2020 with JBL premium system. Sounded horrible and can’t believe they call that a premium system. I just switched out the head unit for a Pioneer 10” floating screen HU and the sound of the system was instantly 100 times better. Still not great, but way better. I am now waiting on my replacement speakers and amp from James at Tech12Volt to install. Then I think I’ll have it were I want it.
    AggiePhil and Trooper2 like this.
  7. Aug 16, 2020 at 6:33 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    From my experience, I would add a 5 channel amp, front speakers and a sub first. I did so and I’m happy with the sound and the stock HU does a good job.
    mtndds98 likes this.
  8. Aug 21, 2020 at 4:04 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Hehehe. James should be kicking back somthing to all you folks for all the free advertising you are doing for him
  9. Aug 21, 2020 at 5:17 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    James recommended the JL Audio C1-650's for my replacement and I have the stock head unit and non JBL.
  10. Aug 21, 2020 at 5:36 AM
    Trooper2
    JR
    Did you install these? If so was there much improvement?
  11. Aug 21, 2020 at 6:07 AM
    purplenova
    Tom
    Ohio
    I have not ordered them yet. I was just going off James recommendation to me via email questions. Think there are many on here who already have them installed. Hopefully they will comment
    And actually - I missed the the main section of the OP's question where he is running factory amp. So my comment may not be valid.
  12. Aug 21, 2020 at 6:14 AM
    Jbehredt
    Westminster, CO
    I’ve got them in my truck. Components in front and coaxial in the rear. Night and day over stock paper cones with no pillar tweets.
    purplenova likes this.
  13. Aug 21, 2020 at 6:28 AM
    purplenova
    Tom
    Ohio
    Did you install yourself or a shop? Did you have separate tweets in the rear doors like on the CM?
  14. Aug 21, 2020 at 9:38 AM
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    I am really glad I have all the new speakers and amp coming. With the new HU it does sound a lot better, but if I listen to it too loud (no even that loud), the system shuts off and says “amp error”. Gets over heated pretty quickly. Turn the truck off and restart it and it clears.
  15. Aug 21, 2020 at 4:30 PM
    Jbehredt
    Westminster, CO
    Installed myself with the adapter plate made by James @tech12volts. Rear doors do not have separate tweets.
  16. Aug 23, 2020 at 4:44 PM
    jaflynn738
    jaflynn738 New Member
    Virginia
    Did he just recomend changing the speakers and adding amp with it?
