Dirty Deeds 02 Sensor issue
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Jun 29, 2020.
  1. Jun 29, 2020 at 6:16 AM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Ordered my 02 adapter from Keith and installed it last night. Erased CEL and checked codes...both 02 related....CEL went off last night and came back this morning. Any thoughts on a work around? Or am I just stuck with this? TIA, John
  2. Jun 29, 2020 at 12:36 PM
    Professional Hand Model
    Fred
    Hand Protectors
    IIRC you installed new exhaust/headers?
  3. Jun 29, 2020 at 2:00 PM
    smokey0810
    Just exhaust, no headers
  4. Jun 29, 2020 at 2:02 PM
    Fred
    Hand Protectors
    Keiths Exhaust?
  5. Jun 29, 2020 at 2:20 PM
    smokey0810
    Sorry, my bad. Yes, Keith’s exhaust. Got the O2 adapter installed, cleared the CEL, and it came back. Think codes were 0076 (or 56) and 0430. Both oxygen sensor related. Figured that since the sensor was just tied onto the pipe with baling wire, that’s what was kicking it off. Maybe time for a new sensor?
  6. Jun 29, 2020 at 2:24 PM
    Fred
    Hand Protectors
    Give it the test. In red were my o2 Sensor readings. The rears were dead and no CEL. Fronts were Bosch and below Spec and no CEL.
    Charruabrew and flyfisher like this.
  7. Jun 29, 2020 at 2:39 PM
    Call Keith for advice???
  8. Jun 29, 2020 at 7:28 PM
    smokey0810
    Gonna do some tests this weekend on the sensor and then give Keith a holler next week if I find nothing wrong with them. PHM really has some good info there, thank you much for that!
  9. Aug 22, 2020 at 4:15 PM
    smokey0810
    Well, replaced the sensor with a new Denso and light came back on....and code for bank 2 sensor 2...P0156
  10. Aug 22, 2020 at 4:56 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did you splice the wires in? or did you do a complete harness swap?? Its possible that the connector is not plugged all the way in, or the splice has been undone, or have been damaged.
  11. Aug 22, 2020 at 5:12 PM
    smokey0810
    Just unplugged and plugged the new one in
  12. Aug 22, 2020 at 5:48 PM
    blackdemon_tt
    Are there any air leaks in the engine bay???? May be push in all air hoses to ensure one didn't come loose on accident.
