  1. Aug 22, 2020 at 5:00 PM
    Professional Hand Model
    Fred
    Hand Protectors
    The oil filter has a certain amount of oil (1/4 quart?) in it when you pull that off which accounts for the disparity in your drainage amount. Also, I (do not recco this to anyone) turn the engine on after draining the oil (plug screwed in/old filter still on) and let it run for about 2 seconds which pumps about 1/2 quart out.
    Adding 6.5 quarts gets me right at the perfect halfway mark on the dipstick. 7 quarts gets me right at the high line. I’ve run both amounts no problems.
    jImmegart[QUOTED] likes this.
  2. Aug 22, 2020 at 5:03 PM
    Fred
    Hand Protectors
    Yzzd-3 is the same size as always.
  3. Aug 22, 2020 at 5:10 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Ya ok. I have half a qt left, so I can fill in the morning. For High heat is it better to be in the middle or high for oil? I read somewhere to have it closer to full, or am I making shit up?
  4. Aug 22, 2020 at 5:12 PM
    Fred
    Hand Protectors
    Not sure, but anywhere between middle and high is good.
  5. Aug 22, 2020 at 5:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    6.5 quarts when engine is warm and your parked on a level surface and the truck sits for 5 minutes off, should be dead nuts on the top dot
    NUDRAT and FrenchToasty like this.
  6. Aug 22, 2020 at 5:21 PM
    Fred
    Hand Protectors
    Thats right. I read in the FSM that the factory fill (brand new engine) is 7 quarts. Drain and fill 6.5 quarts.
  7. Aug 22, 2020 at 5:38 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Ok got the 5100's on and completed the leaf spring swap. All up it was a 4 hour job even though I have been juicing the bolts with penetrant for 5 days now. The ATS Springs are very good quality and I could not find any flaws on them. I got the HD springs and Jarod at ATS said I would get 1.5 to 2.5 inches. It yeilded exactly 2 1/4 on both sides. I'm sure it will settle a little and stay at 2".
    Short trip around the block (4 mile trip here in flat boring north dakota) they are firm but holy heck if it didn't smooth out the wash boards and potholes! It's like day and night difference. My oem Springs gave good service and showed little wear besides rust and pretty loose between the leafs but otherwise still comfortable.
    I had to shave off about an 1/8 off the center pin that rests on the axel so it would sit flush. I also had to trim the top of the pin so the OEM bumps top would fit. I'll do wheelers superbumps soon. Other than that they fit like a glove and will take some serious weight and abuse I'm sure.
    MS22, bmf4069, Darkness and 8 others like this.
  8. Aug 22, 2020 at 5:44 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Installed the transmission cooler and thermostat today.
  9. Aug 22, 2020 at 5:50 PM
    Fred
    Hand Protectors
    Those ‘Leaf Keepers’ look solid. Much better than the OEM ones that bend and allow the leafs to splay. Glad those are part of the deal on your new leafs as they are a must for wherever I get my new leafs.
  10. Aug 22, 2020 at 6:16 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    They have made them really well. I was about $500 otd with new u bolts and I couldn't think there's a better deal out there. The customs available for our trucks probably have a little edge but pound for pound these are the winner in my mind.
  11. Aug 22, 2020 at 6:17 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Your install is very clean. I might do some shifting around of my setup after seeing yours A+ job buddy
    Jerry311SD[QUOTED] and Tundra2 like this.
  12. Aug 22, 2020 at 6:18 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    What size spacer and tires you running? I just bought a set of 4Runner snowflake wheels.
  13. Aug 22, 2020 at 6:44 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    I've got the spidertrax 1.25 spacers. Pretty awesome stuff, well built and feels safe. They are absolutly necessary for the 4 runner snowflakes as they are to far inward of the fender flares without spacers. I'm running 265/70/17 falken wildpeaks right now but will be moving up to 285/70 when 1stgenoffroad gets me my dobinsons springs for the front. Keep an eye on Amazon as they have deals on the spidertrax often. Cheers from ND
    MNtundra[QUOTED] likes this.
  14. Aug 22, 2020 at 7:33 PM
    I've seen several reports of "dipstick too short" here on Tundras.com and this may be what your issue is.
  15. Aug 22, 2020 at 8:38 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I encourage it ;) Shipping can't be toooo expensive, right?
  16. Aug 22, 2020 at 8:55 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I wonder if Greyhound busses still ship freight down below.... Actually I wonder if Greyhound busses still exist.
    edit - yep. Thursday seems to be the cheap travel date. A person Phoenix to Chicago is $210 on Sept. 10th with no discounts. No a bad price if shipping parts is similar to shipping peoples.
  17. Aug 22, 2020 at 9:06 PM
    empty_lord
    05 rollover special
    Yea but then I’m stuck driving to Gary indiana
  18. Aug 22, 2020 at 9:08 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    closer than New Mexico.
    bmf4069 and Thrussn like this.
  19. Aug 22, 2020 at 9:26 PM
    empty_lord
    05 rollover special
    I don’t like driving through Gary because my chance of death goes way up
    MNtundra, bmf4069, Darkness and 3 others like this.
  20. Aug 23, 2020 at 9:44 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That's weird yours did that. Mine went in no problem. The top of the pin was a little long so I had to cut that down so the bump stops would fit
  21. Aug 23, 2020 at 9:46 AM
    rock climber
    Mine is so clear I have to basically look for where it's "wet"
  22. Aug 23, 2020 at 10:38 AM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Yeah it was a little bit of a pain to take the first one off and chop the 1/8 off but maybe they have newer hardwear on them now. It was a small problem easily fixed. I've been driving all day and I'm so impressed with the ride quality now...can not wait to get my springs in so I can get the front lifted up level.
  23. Aug 23, 2020 at 12:19 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I replaced my front rotors. No more vibration during braking. Now I have another issue. After the new rotors were installed, I took it for a spin to down some testing. I did an emergency stop and felt the ABS kick in once but not on subsequent emergency stops. The truck now brakes smoothly and stays straight, no more pedal wobble or steering wheel shake. But now I feel the ass end bouncing up and down a bit when slowing down at times. Maybe I need to adjust the proportioning valve back there again? Which way do I need to adjust it to have the rear brakes grab a bit more? I think I also need a tire balance which I will try and get done tomorrow after work.
  24. Aug 23, 2020 at 12:35 PM
    Fred
    Hand Protectors
    Adjust nuts UP for more rear brake powers.
    artsr2002[QUOTED] likes this.
  25. Aug 23, 2020 at 4:25 PM
    Getting this basket ready to mount. Most of the reviews said it's best to seal all the joints and gaps before spraying it with bedliner.
    Also, here are a few more shots of the sliders. Really pleased with these. I like the fact that they offer a little protection from all the rocks these K02's like to throw.
  26. Aug 23, 2020 at 4:53 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    How's the quality of the basket? I want to do that prinsu style rack build but not sure if I will have time before snow starts dropping in October. Headed south from north Dakota and like to gtfo when I have a good opportunity in the weather.
    Where and how much did you get the sliders for?
  27. Aug 23, 2020 at 6:14 PM
    The basket is about what you would expect from an item at this price point, made in China. It's good, not great. One reviewer said he carried a 33" tire in it. It will take a little abuse but not a ton. It should be perfect for my needs though, assuming I can mount my awning to it.
    The sliders are made by White Knuckle Offroad. They are expensive but there are only a few options for our trucks. Only 2 good ones for access cabs. Brute Force ships theirs with the legs off so by the time I paid for all the welding I think it would have been about the same if not more.
    https://white-knuckleoffroad.com/product/toyota-tundra-2000-2006-rock-sliders/
    oscardog86 likes this.
  28. Aug 23, 2020 at 6:53 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    @FirstGenVol fair enough, I saw a guy in the parking lot that had a ice chest (45 yeti) in his and it was bent down to the rooftop. Guy said he hit some speed bumps pretty good in his neighborhood and forgot the chest was up there lol but hey mounting a awning to it is a different story. Probably best suited for that job.
    Ouch those are spendy. I'm pretty savvy with a welder so I've been eyeing these but hope they would hold up to jacking the truck up.
    https://www.1stgenoffroad.com/store/p33/Trail_Gear_Rock_Slider_Kit.html#/
  29. Aug 23, 2020 at 9:24 PM
    Thrussn
    Gabe
    NM
    Decided to hunt down the source of my exhaust leak on my JBA headers. I replaced the collector gaskets and sealed them with high temp rtv, but it didn't stop the leak. Anyone know why it would still be leaking after I did that? :monocle:
    Filthyphil and bmf4069 like this.
  30. Aug 23, 2020 at 9:28 PM
    empty_lord
    05 rollover special
    Ouch
