1999 FWC Hawk rebuild
Discussion in 'Other Builds' started by pickeledpigsfeet, Aug 22, 2020.
  1. Aug 22, 2020 at 10:46 AM
    pickeledpigsfeet
    pickeledpigsfeet [OP] New Member
    Sierra Foothills, Ca
    Kings & Icons
    Some people wanted to see pics of my FWC rebuild so I figured I would just start a thread.
    Last few years I had been looking for a FWC. Then in late 2019 I found a older hawk a few hours away from me. I showed up, looked at it, found the whole back half of the floor pack was rotten, offered him a grand for it and brought it home.
    Now the rotten floor wasnt a issue as I knew I wanted to drop the floor 2” for more head room inside anyways. And this camper had almost perfect vinyl which was one thing I didnt want to tackle on the initial build.
    Here is a almost finish pic.
  2. Aug 22, 2020 at 10:48 AM
    pickeledpigsfeet
    Kings & Icons
    Here is the rotten floor pack removed from the aluminum frame. The dry rot was so bad that i had to cut back till I got to decent ply before removing it.
  3. Aug 22, 2020 at 10:50 AM
    pickeledpigsfeet
    Kings & Icons
    Then I welded, epoxied and through bolted a 2” riser, 2x1 rectangle tube to the existing camper frame work.
  4. Aug 22, 2020 at 10:56 AM
    pickeledpigsfeet
    Kings & Icons
    The Hawk is 4’ wide so 1 sheet of 3/4 for the main floor. Level it, screw it in front and rear while supporting the middle of the sheet. Then rip some uprights and glue/screw them to the alum frame and floor. rip some more down to create the wings. Setup some dowels and glue the wings to the main floor pack.
  5. Aug 22, 2020 at 11:02 AM
    pickeledpigsfeet
    Kings & Icons
    Installed hatches for window AC unit and sink access. Installed foam insulation.
  6. Aug 22, 2020 at 11:04 AM
    pickeledpigsfeet
    Kings & Icons
    While I had it all apart I setup the jack mounts to use grade 8 bolts and be removable rather than using 10 grade 5 lag bolts into soft aluminum.
  7. Aug 22, 2020 at 11:07 AM
    pickeledpigsfeet
    Kings & Icons
    Then started building out the kitchen and also added 1’ to the bed slide to allow north south sleeping.
  8. Aug 22, 2020 at 11:10 AM
    pickeledpigsfeet
    Kings & Icons
    Built a couch and a single seat across from it using scrap plywood and a foam mattress. Leaving enough room for my engle fridge to fit near the door for easy access and a self contained toilet on the otherside. Finished triming it all out and threw some poly on it.
  9. Aug 22, 2020 at 11:15 AM
    pickeledpigsfeet
    Kings & Icons
    I had a couple 8’ awnings sitting around so I fabbed up some mounts.
  10. Aug 22, 2020 at 11:17 AM
    pickeledpigsfeet
    Kings & Icons
    I have a few rotopax so I fabbed up some mounts for them too. Used some alum unistrut for a roofrack and install a 100w panel and a maxair fan.
  11. Aug 22, 2020 at 11:20 AM
    pickeledpigsfeet
    Kings & Icons
    Added 6 low profile LEDs, 2 pole jacks for remote solar panels so I dont have to park in the sun. These edges will be trimmed out in thin wall alum angle.
  12. Aug 22, 2020 at 11:22 AM
    ckkone
    ckkone New Member
    SLC, UT
    Great job!
    pickeledpigsfeet[OP] likes this.
  13. Aug 22, 2020 at 11:24 AM
    pickeledpigsfeet
    Kings & Icons
    Still need to finish trimmimg the exterior out, cleaning up the butyl tape and epoxied holes, and paint the whole thing. But that will be this spring.
    Drainbung and ntg like this.
  14. Aug 22, 2020 at 11:44 AM
    pickeledpigsfeet
    Kings & Icons
    Added load lifters front and rear. Backup camera on rear door and 3rd brake light above it. Various hatches for 120v extension cords. For summer trips, AC unit rides on pass ledge and then slides through the rear hatch
  15. Aug 22, 2020 at 11:55 AM
    ntg
    ntg New Member
    2016 TUNDRA TRD
    Topper, Drawer System / Bed Platform,
    clean looking s2000!! :) :cheers:
  16. Aug 22, 2020 at 12:02 PM
    Casper421
    In the woods
    06 DC
    Thank you for the write up!! I’m looking to do the same thing!
  17. Aug 22, 2020 at 12:07 PM
    pickeledpigsfeet
    Kings & Icons
    LOL, was wondering if there were any s2k fans on here. Thanks.
    300BLK and ntg[QUOTED] like this.
  18. Aug 22, 2020 at 12:09 PM
    pickeledpigsfeet
    Kings & Icons
    Best way to get into one for sure. All Terrain Camper will ship the vinyl if you find one with blown out soft sides.
    Not sure if FWC will ship it. But ATC still makes campers with the older FWC specs.
    Drainbung and Casper421[QUOTED] like this.
  19. Aug 22, 2020 at 12:10 PM
    ntg
    ntg New Member
    2016 TUNDRA TRD
    @pickeledpigsfeet Have you used this enough where you noticed if the composting toilet makes the camper smell being out in the open like that?
    I'm always looking for deals and projects and a FWC or ATC camper would be awesome! Looks like you did a great job!
  20. Aug 22, 2020 at 12:11 PM
    TheBeast
    TheBeast The Beach
    looking good !
  21. Aug 22, 2020 at 12:22 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Awesome! Job well done. :thumbsup:
  22. Aug 22, 2020 at 1:41 PM
    pickeledpigsfeet
    Kings & Icons
    Its a self contained toilet like the ones used on sail boats. No smells until you dump it, but if you use the chemical packs it neutralizes the smell and grossness factor. The unit separates into a top and bottom and you take the sealed bottom unit to any toilet and dump it out of this little spout.
    https://www.campingworld.com/porta-potti-portable-toilets---curve-58980.html
    Drainbung likes this.
  23. Aug 22, 2020 at 1:43 PM
    pickeledpigsfeet
    Kings & Icons
    I carry a shower/bathroom popup, so depending on where we are the toilet goes into it. Obviously not possible if stealth camping somewhere.
    actually that reminds me that I forgot to mention that I built it so that with the top down I can sit on the couch and even sleep on the couch with my feet on the fridge. There has been times where I was stuck in a place where I didnt want to draw any attention.
  24. Aug 23, 2020 at 8:59 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Very nice.
    You have serious skills.
  25. Nov 8, 2020 at 7:23 AM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I just stumbled on this thread, great work! Any updates?
  26. Nov 8, 2020 at 8:01 AM
    pickeledpigsfeet
    Kings & Icons
    Started working on my portable chinese diesel heater setup. Will post some pics in a bit.
    Had a family member get sick so have been doing some stealth camping in hospital parking lot.
    Also been planning out a DIY 270 awning. Looks like south africans have figured it out.
    https://www.4x4community.co.za/forum/showthread.php/168671-DIY-swinging-awning
  27. Nov 8, 2020 at 8:23 AM
    Wallygator
    Nice! Saving thousands is always a good thing!
  28. Nov 8, 2020 at 8:42 AM
    pickeledpigsfeet
    Kings & Icons
    I bought a scratch & dent Lagun swivel table. Here are some pics of my heater ideas. Also picked up a water heater and am going to try and squeeze it into a pelican case as well.
  29. Dec 1, 2020 at 9:58 AM
    MGM3Pedal
    MGM3Pedal New Member
    2017 TRD Sport MGM
    What a great project! Nice work!
  30. Jul 12, 2021 at 2:04 PM
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Sub'd, nice work sir!
