Let’s see your wheels and tires on a crew max
Discussion in 'Wheels & Tires' started by surf760, Aug 6, 2020.
  1. Aug 22, 2020 at 6:48 AM
    #121
    Hongkongwongdonf
    Hongkongwongdonf New Member
    Will
    Gastonia, NC
    2017 tundra limited
    5% tint. Black rhino arsenal 20x9.5 295/55/20 KO2.
    Do you need anything other than the Bilstiens also to slightly lift it ? And how does it ride ?
  2. Aug 22, 2020 at 6:49 AM
    #122
    rayk
    rayk New Member
    Fuel Contra 22x10 33x12.5x22
  3. Aug 22, 2020 at 8:01 AM
    #123
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    I had a wrap company ColorBomb do a complete crome delete on the hole truck then had them do a complete front clear bra. I love it
  4. Aug 22, 2020 at 8:09 AM
    #124
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    It’s a 4” Pro Comp lift with 35x12.5x20 tires186F4749-6CFA-4D95-943F-90725C9912B8.jpg
  5. Aug 22, 2020 at 8:55 AM
    #125
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    How much did that cost ?
    Double Badass[QUOTED] likes this.
  6. Aug 22, 2020 at 9:05 AM
    #126
    csayno
    csayno New Member
    2020 Tundra TSS CrewMax 4x2
    Just got it Monday. TSS package. First Tundra and these are insane. Probably just need a small lift and I should be set.
    impactbumper and Hightide like this.
  7. Aug 22, 2020 at 10:47 AM
    #127
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Not very good but here you go, I'm putting in the coach builder shackles tomorrow, +3's
  8. Aug 22, 2020 at 10:54 AM
    #128
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Those 37s look so good
  9. Aug 22, 2020 at 11:02 AM
    #129
    ARES35
    ARES35 New member for life
    Mile high
  10. Aug 22, 2020 at 2:24 PM
    #130
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    No, just the 5100's up front. You can use your stock coil over springs. I am at the top setting which gives ~2.4" of lift. It's just about level. But when I load my 2 bikes into it I think the back is a bit low.
    So I could either go to the middle setting on the front shock, think it's about 1.9"sh. Or I could go with a block or shackle in the back so the front can stay the same. Think I'm leaning toward the shackle in the back. Things I've read on here seem to go lean that way.
    it rides great. I think if anything changed I would tend to think it's the bigger/wider tires.
  11. Aug 23, 2020 at 3:38 AM
    #131
    ionnaeus
    ionnaeus New Member
    Jon
    Chattanooga, Tennessee
    2018 Limited CM MGM 5.7
    Looks like my 2018! Same set up and love it!!
  12. Aug 23, 2020 at 5:02 AM
    #132
    needsmoresalt
    needsmoresalt New Member
    Patrick
    2020 Tundra TRD Pro
    A few
  13. Aug 23, 2020 at 6:05 AM
    #133
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    Not sure if the vehicle comes with those lights in front of the windshield but I love those.
  14. Aug 23, 2020 at 6:15 PM
    #134
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Kenda Klever RT 33x12.5x18 with XD 820s 18x9 +18mm offset (3/1 lift from BDS )
  15. Aug 24, 2020 at 1:14 PM
    #135
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    Looks great, do you have a side profile photo, to show how far out the wheels look under the flares?
  16. Aug 24, 2020 at 2:03 PM
    #136
    rockmup
    rockmup New Member
    Todd
    Thanks, Mesquite Brown
  17. Aug 24, 2020 at 2:40 PM
    #137
    ryanryan34
    Olympia WA
    Not much at all with it only be a +18MM offset. Didn't want them to stick out much either.
  18. Aug 24, 2020 at 2:51 PM
    #138
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Great look.. been looking for a set up where I won’t be throwing rocks all over my paint haha
    ryanryan34[QUOTED] likes this.
  19. Aug 25, 2020 at 10:27 AM
    #139
    pearlpower
    What size tires are you running? I like your setup and want something similar on mine.
  20. Aug 25, 2020 at 11:49 AM
    #140
    ryanryan34
    Olympia WA
    Thanks! 33x12.5x18 on a 3/1 lift ( a few post back you can see a full side view of it )
  21. Aug 25, 2020 at 2:54 PM
    #141
    pearlpower
    Thanks for posting. I thought a +18mm would tuck in and not stick out as much. I like the look. Are those Bushwhacker flares?
  22. Aug 25, 2020 at 8:10 PM
    #142
    abpadilla1794
    abpadilla1794 New Member
    Alexis
    Black 2016 Toyota Tundra 1794 4x4
  23. Aug 25, 2020 at 8:20 PM
    #143
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
  24. Aug 25, 2020 at 8:21 PM
    #144
    GarTX526
    GarTX526 New Member
    Many pending.....
  25. Aug 29, 2020 at 5:52 AM
    #145
    BigJuelz
    BigJuelz New Member
    2020 Magnetic Gray Platinum
    Did you have to modify the suspension or wheel well to fit these?
  26. Aug 31, 2020 at 8:59 PM
    #146
    Roy17185
    Roy17185 New Member
    Utah
    2020 MGM Tundra TRD Off Road
    • Method 20x9, +18 Offset.
    • 275/60R20 Falken Wildpeak AT3/W
    • Stock Suspension
    ThePolak likes this.
  27. Aug 31, 2020 at 9:05 PM
    #147
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Good stuff!
    What’s the set up?
  28. Aug 31, 2020 at 9:53 PM
    #148
    275/70R18 Falken Wildpeak AT3W tires on gunmetal SCS Ray 10 wheels with +25 offset. Had to remove the front air dam, and still have some rubbing on the mud flaps when turning in reverse.
  29. Aug 31, 2020 at 11:46 PM
    #149
    Colinm
    Colinm New Member
    Colin
    08 tundra crew cab
    Custom front bumper with led light bar Custom rear bumper 18” method wheels with 35” grappler tires King shocks front and rear with resevoirs Prinsu cab roof rack with led light bar Homemade custom rear roof rack Belair camper shell with custom drawers Raptor front grill with led lights Ditch lights Navigation
    18” methods with 35” grappler wheels
    2.5” lift with kings with res. All around. Total chaos upper control arms
  30. Sep 1, 2020 at 11:03 AM
    #150
    GarTX526
    GarTX526 New Member
    Many pending.....
    ReadyLift ProPlus2, 295/70R18 Nitto Ridge Grapplers, Black Rhinos 18x9.5 w/ +12 offset
    spectrasoul and Hightide[QUOTED] like this.
