Water pump question for the 4.6L
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Aug 17, 2020.
  1. Aug 17, 2020 at 4:23 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    Hello everyone
    I have a 2011 SR5 with the 4.6L V8. I have been getting parts together do replace the water pump, thermostat, belt and pulleys. I ordered everything from Rock Auto and I went with he Aisin water pump.
    When I opened the box for the pump it does not look right. The pully mount is a large nylon wheel. From everything I have seen it should be the flat metal ring with 4 holes for the pulley bolts. Can anyone that has the 4.6L please tell me if I have the correct part. All of the part numbers match up.
    Thanks.
  2. Aug 17, 2020 at 4:44 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  3. Aug 17, 2020 at 4:56 AM
    JohnLakeman
    If the box says it's an Aisin water pump, and the housing shape and mounting holes appear to be the same as the picture above, then it's likely the correct water pump. You have essentially bought an aftermarket pump made by Aisin. It is not necessarily the exact same water pump provided to Toyota specs, but Aisin believes the pump to still be functionally the same.
    I suspect Aisin has figured out how to save a dollar by replacing the steel pulley mounting hub with a plastic one.
  4. Aug 17, 2020 at 6:49 AM
    Jon1979
    Jon
    Upstate NY
    The backside of my pump looks the same but the pulley mount in no where the same. Unless they expect you to just use the plastic piece as a pully there is nothing to attach the old metel pulley to.
  5. Aug 17, 2020 at 1:35 PM
    JohnLakeman
    Try uploading a pic. I can't visualize what you're describing.
    It is possible Rock Auto sent you the wrong part. The Toyota part linked earlier clearly shows a pulley hub with four holes.
  6. Aug 17, 2020 at 1:45 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  7. Aug 18, 2020 at 5:10 AM
    Jon1979
    Jon
    Upstate NY
    Sorry I should have sent these from the beginning. I think I am going to send it back and get the Beck/Arnley instead
  8. Aug 18, 2020 at 5:18 AM
    JohnLakeman
    Ha. I think that is a protective cover over the pulley hub to protect the mechanical seal from impacts to shaft during shipment. Did you try tugging it off?
  9. Aug 18, 2020 at 6:05 AM
    Jon1979
    Jon
    Upstate NY
    I thought that as well but it does not budge and I did not want to damage anything and effect the return.
  10. Aug 18, 2020 at 6:40 AM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    That is most certainly a protective cap over the pulley boss. Take a flathead screwdriver and pry it off.
  11. Aug 18, 2020 at 10:19 AM
    Jon1979
    Jon
    Upstate NY
    If that is the case can we pretend I never created this post? I have probably installed 6 or 7 water pumps in my past and I never had one with a cover over the pulley mount. :(:oops:
    drowhawk likes this.
  12. Aug 18, 2020 at 10:56 AM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    haha you are forgiven.
  13. Aug 18, 2020 at 11:59 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Is everything ok now?
  14. Aug 19, 2020 at 6:05 AM
    Jon1979
    Jon
    Upstate NY
    Well I ended up sending that pump back and ordering the Beck/Arnley one yesterday morning. Rock auto let me send I back for free, but if this one comes like that I will defiantly know what to try. Thanks everyone.
    TokerJoker likes this.
  15. Aug 19, 2020 at 3:00 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Let us know how the next one comes, with pics.
  16. Aug 21, 2020 at 10:07 AM
    Jon1979
    Jon
    Upstate NY
    So oddly enough I received the Beck/Arnley pump last night. It has Asin stamped in it and it looks different then the first one they sent me. Mainly no plastic cover, plate between the t-stat mount is not on the new one, T-stat mount is thinner on the new one and the gasket in the box matches up perfectly with the new pump. I will send some pics when I get home.
