Installing 18 Land Cruiser rims with KO2s
Discussion in 'Wheels & Tires' started by nikosan, Aug 20, 2020.
  1. Aug 20, 2020 at 9:17 AM
    nikosan
    nikosan [OP] New Member
    2014 Tundra Platinum
    here at America's Tire to install 18 inch rims and tires on my Platinum with TRD Calipers and the rims won't clear due to the big calipers. Will it clear if I removed the TRD calipers and install regular calipers? Want to make sure before I go thru the expense replacing it and finding out that it won't work.
    I don't want to install KO2 on the 20 inch rims. Will an aftermarket 18 inch rims work?
  2. Aug 20, 2020 at 9:29 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yes, TRD big brake kit requires 20" wheels. Going to the small, stock brake caliper and rotors will allow you to fit 18" wheels.
  3. Aug 20, 2020 at 9:34 AM
    nikosan
    Thanks for your quick reply.. will replacing it to stock calipers and rotors require bleeding the ABS?
  4. Aug 20, 2020 at 10:01 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Yes, brake bleeding required cuz you will be disconnecting the brakes lines to install oem calipers. Just a suggestion but I would not downgrade calipers. I'd keep the trd bbk.
  5. Aug 20, 2020 at 11:12 AM
    nikosan
    Yes looks like the high cost of downgrading to stock calipers and rotors and cost of labor suggest to keep the TRD big brake kit and the 20 inch rims
  6. Aug 20, 2020 at 2:05 PM
    nikosan
    being a newbie and stressed out while at Tire shop, I just realized I posted in the Build section where it should be on the 3rd Generation Discussion. My apologies, Moderator pls move this thread. Thanks
  7. Aug 20, 2020 at 3:12 PM
    SeminoleATL
    SeminoleATL New Member
    2014 Limited CM Blue
    Stock... for now
    Where are you located
  8. Aug 20, 2020 at 3:39 PM
    nikosan
    San Francisco Peninsula
  9. Aug 20, 2020 at 4:26 PM
    SeminoleATL
    Stock... for now
    ok. Was going to offer to trade you some Linited 20” wheels :). Babur you’re a bit far from Atlanta!
