6x6 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Bruce2020, Jul 20, 2020.
  1. Aug 19, 2020 at 7:05 PM
    #91
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    You betcha!--Any airbag recalls still open?
  2. Aug 20, 2020 at 8:46 AM
    #92
    Bruce2020
    Bruce2020 [OP] New Member
  3. Aug 20, 2020 at 8:48 AM
    #93
    Bruce2020
    Our road safety laws are pretty loose. We are not required to have airbags, just the seat belts are required and it's only for the driver and the person besides him
    Darkness likes this.
  4. Aug 20, 2020 at 8:49 AM
    #94
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Carbon Fiber Tailgate? Or is it a wrap??
  5. Aug 20, 2020 at 8:52 AM
    #95
    Bruce2020
    Not carbon fiber for sure.i can't tell what it is....maybe a wrap
    N84434 likes this.
  6. Aug 20, 2020 at 8:57 AM
    #96
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Jesus that paint job looks like a bass boat.
  7. Aug 20, 2020 at 10:21 AM
    #97
    That's a crazy amount of fab and body work. So how's the 4wd troubleshooting going?
  8. Aug 20, 2020 at 10:26 AM
    #98
    Bruce2020
    Well it's one of the mechanic guy birthday so we ended up having a few beers last night...I'll see how it goes today and keep you updated
    Darkness and bmf4069 like this.
  9. Sep 8, 2020 at 6:46 AM
    #99
    Bruce2020
    Hey there, so this is how the ⁴wd works. If I press the 4wd hi the transfer case engages the 4wd but the add unit on the front diff does not engage. I then cycle the key to off then on and then the add engages. The 4hi light still flashes. If I press the 4lo button it engages and the light becomes solid. Now I can get the 4hi light solid.
  10. Sep 8, 2020 at 6:48 AM
    #100
    Bruce2020
  11. Sep 8, 2020 at 7:15 AM
    #101
    Third gen tail lights, Tacoma headlights, side exhaust, paint job by Basscat or Skeeter. One badass build. Curious about the pics of the transfer case. Factory doesn't have the rear output, so this is a modified factory one correct? Is it luck that the rotation was correct for the rear drive shaft, or did the gears have to be reversed for that axle? Doesn't appear to be flipped. Factory X-fer case for reference below. System is finicky, all the sensors must give appropriate feedback in order for the actuator to engage. Also if the actuator was removed as mentioned before, double check that it was reinstalled correctly.
  12. Sep 8, 2020 at 10:56 AM
    #102
    I'm thoroughly confused by that bottom pic. That's from the middle looking forward. Yet there's 2 prop shafts heading back from the transfer case.
  13. Sep 8, 2020 at 11:22 AM
    #103
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    One from the transmission to the rear (normal)
    One from the transfer case to the back (not normal)
