  1. Aug 18, 2020 at 1:53 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Did you see what our one member did with their Red Topper? Looks perfect.
  2. Aug 18, 2020 at 1:58 PM
    Fred
    Hand Protectors
    ‘Leveled’ the truck today with a drop kit.
  3. Aug 18, 2020 at 5:27 PM
    Fred
    Hand Protectors
    Stoked on the BaFx Bluetoof paired up with Torque Pro App. Did a quick rundown on the truck idling in the driveway and no codes present. We have a great start! :rofl:
    Engine Coolant got up to and plateaued at 200° with intake temp at 95°. Didn’t mess with transmission temp other than a brief glance at 105° after a few minutes idle. This thing is as nice as they say in the 17,549 reviews.
    Now to dive into it over the next week or two. I’ll be buying an OBD extender cord to tuck it out of the way. :yes:
    ColoradoGuy, bmf4069 and Thrussn like this.
  4. Aug 18, 2020 at 6:09 PM
    Damn, you need to get that stankbug stance back!
  5. Aug 18, 2020 at 6:16 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Could be the pic, but appears to have a little bro lean?
  6. Aug 18, 2020 at 6:19 PM
    Are you trying to get darkness to like a silver truck?
  7. Aug 18, 2020 at 6:57 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    The 4wd driveshaft I got from the junkyard has a super shot center support bearing. It would wobble around really bad up to about 20mph.
    Instead of getting a new bearing, I decided to bite the bullet and have a custom one piece made. I shouldn't have to worry about a center support bearing ever again! :fingerscrossed:
    I've also noticed a slight drip of ATF from where the trans mates with the transfer case. Would that be a transfer case input shaft oil seal?
  8. Aug 18, 2020 at 7:08 PM
    Thrussn
    Gabe
    NM
    I also had to disconnect those custemm QD sway bar links because they would clunk so loud that I would actually get concerned looks from people I would drive past. On a positive note, I PB blasted my frame a couple days ago in honor of PHM and his wisdom, but didn't take any pics.
  9. Aug 18, 2020 at 8:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its working (I have plenty of black paint)
    @Thrussn that's a good upgrade. How is the rest of your conversion going? I'm jealous, it will probably be 2 years before I can convert mine.
  10. Aug 18, 2020 at 9:32 PM
    Casper421
    In the woods
    06 DC
    Would that be before or after your tube bumper?
  11. Aug 18, 2020 at 9:36 PM
    Thrussn
    Gabe
    NM
    I'm actually just about done. I'm running into just about every snag possible. I thought I could use the Sequoia transfer case, but I had to order the right one on eBay. It has a temporary warranty fortunately. I've got the engine harness, spindles, diff, and axles installed. I just have to do the rear regear and slap in the front driveshaft and I should be golden.
    I'll make a post about it here next week sometime I'm sure lol
  12. Aug 18, 2020 at 9:53 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    After, but you realize how many project cars I have that come before the truck? Sometimes I wish it was just the truck.
    If I stay focused I'll get there
    shifty` and Casper421[QUOTED] like this.
  13. Aug 18, 2020 at 9:55 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I like hearing that. If you could go back would you do it again, or listen to the crowd that said sell it and buy a 4wd?
  14. Aug 19, 2020 at 4:21 AM
    Fred
    Hand Protectors
    Nice! The steel is sucking it all up right now. Once you get through this 4x4 tweaking you can give the frame a grease rub. Stoked for you on your 4x4 conversion. How much was that new drive shaft if you don’t mind me asking?
    Thrussn[QUOTED] likes this.
  15. Aug 19, 2020 at 4:36 AM
    Fred
    Hand Protectors
    Its the new leveled look. Turd Gen does this a lot. ‘Hey look I level my truck!’
    Me: Looking at picture, I twist my screen to offset brosquatch.
    bmf4069 likes this.
  16. Aug 19, 2020 at 4:40 AM
    Fred
    Hand Protectors
    Yeah. Actually, I had about 1400lbs in the bed which correlates to my bump stops being about an inch off the frame. I snapped this shot to mess with everyone here for laughs.
  17. Aug 19, 2020 at 6:58 AM
    Thrussn
    Gabe
    NM
    I would do it again. It was actually enjoyable and if you have all the right parts from the beginning, I would even say it's fun.
    I wouldn't want to do the trans swap alone or without a proper transmission jack.
    Tundra2 and Darkness[QUOTED] like this.
  18. Aug 19, 2020 at 7:05 AM
    Thrussn
    Gabe
    NM
    I wanted to have my local driveshaft guy weld the current shaft I had into a one piece, but he said he didn't want to do it. He's one of those guys who are a bit different but are really good at what they do. He said he would rather build a new one from the ground up. After all was said and done, it was $350.
    When doing a grease rub on the frame, how do you get it in the inside or center part towards the front? I recall you talking about a specific overlap on our frames towards the front of the cab.
    bmf4069, oscardog86 and Darkness like this.
  19. Aug 19, 2020 at 8:05 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gave the whole dash a 303 lovin special four days ago.
    Shiny:D
  20. Aug 19, 2020 at 8:48 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I might do that but i dont want to change the way toyota intended the truck to be
  21. Aug 19, 2020 at 9:00 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's what I expect too. When I get to the transmission part I'll likely hijack my buddys lift and so it at his shop. I can do the rest in my driveway easily.
    Did you get the vacuum line figured out? I started reading a Haynes manual and then my wife wanted some crap done and I got sidetracked. I figure there are unused ports on the intake manifold that could be used.
    bmf4069 likes this.
  22. Aug 19, 2020 at 9:35 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    When my input seal was leaking it was straight gear oil. Just my experience..
  23. Aug 19, 2020 at 11:50 AM
    Thrussn
    Gabe
    NM
    When I saw the trans in person, I quickly learned that the lines on the a750f transmissions are just breathers with the same style vent as the rear axle. I didn't have to mess with any vacuum stuff fortunately. I have no idea how the a340f transmissions are set up, but I'd assume it's pretty similar.
  24. Aug 19, 2020 at 11:51 AM
    Thrussn
    Gabe
    NM
    I'm definitely leaking ATF and not gear oil. It must be a trans output shaft seal or something like that.
    Filthyphil[QUOTED] likes this.
  25. Aug 19, 2020 at 12:49 PM
    Holy cow, that kinda reminds me of this. :D
  26. Aug 19, 2020 at 1:17 PM
    Fred
    Hand Protectors
    I fabbed up a flexible fiberglass rod with a sponge wrapped with a microfiber. Loaded up the wad packer with grease and went Cannon Ball Grease Packing with STP MolyEP.
    I also spray the PB Penetrant up the boxed front frame which has a long range spray action. Use the straw in the side holes to get those areas closer to the front.
    Thrussn[QUOTED] and FrenchToasty like this.
  27. Aug 19, 2020 at 1:21 PM
    Fred
    Hand Protectors
    Makes feather dusting follow ups easy!
    NUDRAT and Tundra2[QUOTED] like this.
  28. Aug 19, 2020 at 1:22 PM
    Hmmmm.... the forum preview is giving me away.
  29. Aug 19, 2020 at 1:23 PM
    Fred
    Hand Protectors
    Yeah. I wouldn’t want to change it either. That picture was me joking around. The bed had 1400lbs in it.
  30. Aug 19, 2020 at 1:24 PM
    I bet we could get meta with this.
    bmf4069 likes this.
