295 70 18s on stock suspension
Discussion in 'Wheels & Tires' started by 20-Yoda, Aug 10, 2020.
  1. Aug 10, 2020 at 3:15 PM
    20-Yoda
    20-Yoda [OP] New Member
    2020 Tundra Limited Crew Max 4x4
    Hi all-
    New member here. I am starting to customize my new 20 Limited and can not find a direct answer in the search. When it comes to a 4x4 Crew Max, can I run 295-70-18s with no mods? I am going to be installing a leveling kit and better shocks shortly I am just not sure if I can mount the wheels and tires I bought before its installed or if I will need to wait?
    The rims these are on are factory TRD Offroad wheels
  2. Aug 10, 2020 at 3:23 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I think the wheel offset would be a big factor. IIRC the stock wheel have -60. I put 275/70R18 on my stock rims as winter tires, right after I got a 2.5" lift. These are smaller that you are going (33" vs 34") and I hit the skidplate. I would think 34s make have additional trimming needed on a stock height with stock rims.
  3. Aug 10, 2020 at 3:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think the better question is why do things out of order
  4. Aug 10, 2020 at 5:09 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Depends on which tire. They all run slightly different despite being 295's. Generally its advised to get 1.25" spacers if using stock TRD OR wheels because for those who have made it fit without spacers, its extremely close to the UCA. I have 295 Falken Wildpeaks with 1.25" spacers and had to take off the mudflaps and trim the front of the fender liner for zero rub.
    20-Yoda[OP] likes this.
  5. Aug 13, 2020 at 6:58 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Your running 295 70s? 75? On stock trd off road rims with 1.25 spacers. Stock height or lift?
  6. Aug 13, 2020 at 7:45 PM
    Blueknights75
    Ron
    Clayton, NC
    No.. You will need to at least level the front in order to fit that size tire.
  7. Aug 13, 2020 at 8:20 PM
    300BLK
    300BLK New Member
    295/70/18 on TRD OR wheels with 1.25” spacer, OME 2.5” lift with stock UCAs
    dandrilla likes this.
  8. Aug 13, 2020 at 8:46 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    My brother just got 295/70/18’s on his 1794 crew max factory wheels slight rub on the front splash guard and skid plate. 15min fix and your good to go. Clears the UCA by about 3/8 of an inch.
    Big J likes this.
  9. Aug 13, 2020 at 8:56 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
  10. Aug 15, 2020 at 8:55 AM
    20-Yoda
    Just to circle back-
    These fit with no mods at all (thanks Big J!)
    All that has been done is removal of the mud flaps, which I had previously done when I debadged.
  11. Aug 15, 2020 at 11:14 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! What tires did you go with? Looks great and filled it out nicely. :thumbsup:
  12. Aug 15, 2020 at 11:29 AM
    20-Yoda
    Thanks! They are the Toyo Open Country Xtreme ATs
    Big J[QUOTED] likes this.
  13. Aug 15, 2020 at 12:28 PM
    PermaFrostTRD
    Northern NY
    Can you take a pic straight on from front or rear?
  14. Aug 16, 2020 at 6:27 PM
    20-Yoda
    Im not sure what you are looking for or how close but here are a few shots
    Big J likes this.
  15. Aug 16, 2020 at 6:38 PM
    PermaFrostTRD
    Northern NY
    These are too close but thank you. Just wanted to get a general “stance” look of the 295’s on stock rims with no spacers. So I could compare to my 275s.
    Thank you
  16. Aug 16, 2020 at 7:22 PM
    20-Yoda
    No prob, I can take a pic tomorrow. I thought you may have been looking at the clearances etc not overall stance
    PermaFrostTRD[QUOTED] likes this.
  17. Aug 18, 2020 at 11:24 AM
    20-Yoda
    Here is a pic dead on
    Big J and PermaFrostTRD like this.
  18. Aug 18, 2020 at 12:29 PM
    PermaFrostTRD
    Northern NY
    looks great! Thank you.
