How to tell-JBL
Discussion in '1st Gen Tundras (2000-2006)' started by Madcapwoodwright, Aug 12, 2020.
  1. Aug 12, 2020 at 7:51 AM
    Madcapwoodwright
    Madcapwoodwright [OP] New Member
    Denver Colorado
    1st Gen 2000 Toyota Tundra SR5 Access Cab 4x4
    2000 Tundra SR5 Access Cab(?).
    I'm needing to put, at a minimum, a new head unit in.
    The current speakers in the doors, sound decent. But the head unit seems not to have any control at all. No volume (stuck at quiet level) no station change, no nothing but Bluetooth connection using an adaptor.
    The door speakers are 6.5" down low, and what looks to be about a 1" tweeter up high.
    The deck is aftermarket Sony. And there are no JBL markings anywhere to be seen.
    I did the vin look up, and zero mention of JBL equipment.
    What I really need to know, since I'm on a budget of +/- $200, is do I need to replace the speakers as well as the head unit?
    From the description of what I have, does this sound like the infamous 2ohm JBL speakers?
    I have been reading diligently, trying to narrow this down. It's like wading through pea soup, there is so much info.
    I just need to narrow down what my actual needs will be, THEN go about searching for installation instructions.
    Any/all help, and recommendations are most welcome.....also, sorry if this specific issue is covered elsewhere, I swear I did several searches using various search terms.
  2. Aug 12, 2020 at 8:17 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    This may or may not help..
    2000 Toyota Tundra Pickup Access Cab
    https://www.crutchfield.com/car/outfitmycar/mycar.aspx
    Not sure they had JBL in 2000, but having a separate tweeter it might be JBL.
    Is the size of your Sony a single or double DIN?
    Single.
    Double..
    CB00A9B2-0B25-4A63-ACCB-306211C142E4_zps_e38ebfd162a24a2ecb3f6b41aaf8368d712cf3b4.jpg
    Even though you have 20 year old speakers, I'd try replacing the HU and see how it sounds.
    James @james@tech12volts would be a great person to discuss wants and needs as well as purchasing product.
    https://shop.tech12volts.com/main.sc
  3. Aug 12, 2020 at 8:21 AM
    Madcapwoodwright
    Denver Colorado
    Currently it's a small Sony single din.
    I'm fine with the single din from a cost perspective. I plan to bypass any amp Toyota deemed needed in the dash, or elsewhere.
    Double din would be nice, but not needed. Just needs Bluetooth connectivity and enough power to drive the speakers adequately.
    Edit to add:
    I did reach out to James a couple of days ago via email. No response as of today
  4. Aug 12, 2020 at 8:25 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  5. Aug 12, 2020 at 8:26 AM
    Madcapwoodwright
    Denver Colorado
    Perfect, was just looking at these now. Thanks!!!
  6. Aug 12, 2020 at 8:36 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I'd find a nice pioneer or kenwood single din and swap it out.
    I buy a lot of stuff from Crutchfield because of their return policy.
    I had a Pioneer in my 2005, the one pictured above.
    https://www.crutchfield.com/g_46215...pair=FFBrand|Pioneer&nvpair=FFSize|Single-DIN[/QUOTE]
    If I was doing a complete overhaul, I would buy one of James' packages.
    You know eventfully you will probably replace the speakers and get an amp.
    So whatever HU you buy, keep in mind the possible upgrades in the future.
    I had 3 amps under the front seat of my 2005 with a custom sub box..
    Had the XM tuner tucked behind the climate control panel.
    IMG_0217_783600f7ba8e39d0e46b430c1b110c442e2bdce7.jpg Amp3_3ea24b49fbdb53f8808255613c1fae643de7e178.jpg AmpMount2_e9024a3e8e980b4efdcaba018b96b9672ad35607.jpg WooferBox1_f538d9301c8e33d5d9c726c4dc9efa258c83ff08.jpg WooferBox2_e4e9bd4e477af44a505cf4206a2e5a0b7393b9a2.jpg
  7. Aug 12, 2020 at 8:37 AM
    Madcapwoodwright
    Denver Colorado
    Perfect. Thanks for this. Fingers crossed I hear back from James.
  8. Aug 12, 2020 at 8:55 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The amp on the early 1st gens is right behind the stereo, you can check it and see if it says JBL. Also, the best way to check is to pull one of the speakers and look on the back. It will say JBL and the ohms if it is. If not JBL, super easy to replace and bypass the amp if you have one.
    1lowlife likes this.
  9. Aug 12, 2020 at 8:58 AM
    Madcapwoodwright
    Denver Colorado
    Perfect, I thought as much based on all my reading. Thanks!
  10. Aug 12, 2020 at 9:07 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I have 4 JBL speakers sitting here out of my 06 Tundra DBL cab. There is a sticker on the back of each speaker with JBL and the part #. None of the stickers have the ohms listed.
  11. Aug 12, 2020 at 9:23 AM
    Madcapwoodwright
    Denver Colorado
    Looks like I need to try to find my ohm meter
  12. Aug 12, 2020 at 9:47 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    You may want to pull out the Sony and see what previous owner did first. You never know if they cut off the harness or what all they did behind the radio. You’ll also be able to tell if JBL has been bypassed based on the harness that was used (if any)
  13. Aug 12, 2020 at 9:48 AM
    Madcapwoodwright
    Denver Colorado
    This is a good call. Thanks for this reminder.
  14. Aug 12, 2020 at 6:09 PM
    One point in case a non-2000/2001/2002/2003? owner comes in - At least in the Access cab, at least in later years, amp is under the carpet in the cavity under rear passenger seat.
  15. Aug 16, 2020 at 7:34 AM
    Madcapwoodwright
    Denver Colorado
    Update,
    I plan to go to best buy or quality auto sound today, and see what there is to see regarding a new head unit.
    I think I will hold off buying new speakers, until is see what the new head unit sounds like in the truck using existing speakers.
    Fingers crossed these are 4ohm speakers, and that the previous owner did NOT butcher the harness.
