Broken battery clamp...please help
Discussion in '2nd Gen Tundras (2007-2013)' started by Piggdawg, Aug 13, 2020.
  1. Aug 13, 2020 at 10:33 AM
    Piggdawg
    Piggdawg [OP] New Member
    went to change my battery, the negative post is lead and came off no problem. The positive is copper/brass and broke once I tried to turn it the first time. For the life of me I cannot get this other bolt undone without further breaking it. I have a lead post clamp to replace the one piece if I can just get it undone. Anybideas? Oh, and I am pretty much a moron when it comes to working on cars. Thanks.
  2. Aug 13, 2020 at 10:36 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Spray is good with WD-40, really let it soak in - see if that'll help you get that nut loose.
  3. Aug 13, 2020 at 10:37 AM
    Piggdawg
    I have been spraying all day long with WD40. Still won't budge. Afraid I am going to break something if I force it
  4. Aug 13, 2020 at 10:40 AM
    The Californian
    Eric
    Maybe it would be easier to just replace the whole cable; they're not that expensive.
    Black Wolf likes this.
  5. Aug 13, 2020 at 10:44 AM
    Piggdawg
    Maybe. Not really sure how to do that. But if I replaced the main cable, that bolt attaches a second cable that runs into the fuse box. So if I replaced one I still need to get that bolt off to reattach the second cable. I appreciate the help, like I said I don't really know much about working on vehicles.
    The Californian likes this.
  6. Aug 13, 2020 at 11:46 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    Something like this. Had to use one on my son's car.
    EDDO likes this.
  7. Aug 13, 2020 at 12:03 PM
    Piggdawg
    Thanks. Just went and bought one. Now let's hope I don't blow up my Tundra. Thanks for the help yall
    YardBird likes this.
  8. Aug 13, 2020 at 12:04 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Hold it with a pair of vice grips and use an impact gun?
  9. Aug 13, 2020 at 12:07 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I had the same issue last year on my car. Getting an extra person to help is great. Have one with a pair of pliers or vice grip and grip the flat metal while the other person using a breaker bar or impact to loosen the nut. Then replace the battery terminal with one of these https://sdhqoffroad.com/products/sdhq-built-hd-billet-main-battery-terminal-upgrade-kit I bought OE positive and negative terminals and the prices weren't cheap.
    Flyinryank and Black Wolf like this.
  10. Aug 13, 2020 at 12:38 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Another option..
    https://www.youtube.com/watch?v=F2a8Seirw94
    If your truck is anything like my 2014, they isn't much slack in the pos cable to cut it and put a different clamp on it.
    Another option would be use solderless connectors and extend the cables.
    Not sure what wire gauge you would need.
    https://www.amazon.com/WINOMO-Gauge...4+gauge+wire+connectors&qid=1597347797&sr=8-5
    Not a fan of TT but this video shows how he extended the cables to mount a non-F battery, has the posts reversed from the OEM battery.
    Only posting so you can see how he extended the cables.
    Just get some big shrink wrap and cover all your connections.
    https://www.amazon.com/gp/product/B07MW27JNZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  11. Aug 13, 2020 at 3:31 PM
    Dremel with a cutoff wheel.
    1lowlife likes this.
  12. Aug 15, 2020 at 3:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Even easier.
  13. Aug 17, 2020 at 5:38 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    to answer the question at hand , WD 40 will help loosen it. if that doesn't work a impact and vice grips , or the best one is heat from a small torch heat the nut. being conscious of were your flame is directed. by heating up the nut it will expand making it easier to come off.
    a pro tip when dealing with stuck nuts or bolts is to use lube and slightly tighten and un-tighten back and forth breaking it free and it will preserve the threads.
    i never recommend cutting OEM wire's do to a potential fail or electrical gremlin that can develop.
    im eventually upgrading to a bus bar system over a standard post set do to a 2nd accessory fuse box and large electrical demand of my set up.
