Tundra Double cab
Discussion in 'General Tundra Discussion' started by H~TX_SR5Guy, Aug 13, 2020.
  1. Aug 13, 2020 at 9:21 PM
    H~TX_SR5Guy
    H~TX_SR5Guy [OP] New Member
    F
    2019Barcelona Red SR5 DC
    Hello all, I’m wondering if it is possible to put a power roll down window like the crew can has on a 2019 double cab?
    YardBird and 619Tundra like this.
  2. Aug 13, 2020 at 9:27 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Hey welcome. Good thing I told you to log on. I think others have done this mod.
  3. Aug 13, 2020 at 9:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If your asking about the rear window in crewmax, sorry, no can do. Structurally different back there for DC.
    Black Wolf, GODZILLA and 1lowlife like this.
  4. Aug 13, 2020 at 9:38 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ I concur..
    It isn't going to happen without MAJOR modification..
    I can't even find a power SLIDER for 2014 DC.
    I think some of the Limited come with them...
    Trooper2[QUOTED] likes this.
  5. Aug 13, 2020 at 9:45 PM
    Trooper2
    JR
    There was an aftermarket slider out there being offered. They were kind of pricey.
  6. Aug 13, 2020 at 10:14 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’ve looked into this. It can be done, anything can be done. Is it cost effective. Doesn’t appear to be. Won’t be any sort of warranty.
    I’ve had both Crewmax and now DC. The design of both insides of the cab are different.
    Crewmax has base ball field back there and slightly different angle to the cab where the window mechanism mounts and where the slide up/down is mounted. Seats are mounted more forward for this occupation of the window mechanism and track. There’s an extra panel and support, channel where the window rides in. CM Cab is more flat appearance.
    DC doesn’t have any of the room the CM has, not any of the above parts.
    That said anything can be done.
    It came down to looking at these places for parts.
    http://www.car-part.com/mobile/index.htm
    Or
    https://erepairables.com/
    Just examples where to get some parts. Hopefully the links work.
    To get parts from. It would be easier to gut the back of the cab area, remove the bed and cut out the back of a CM and adapt it to the DC as a whole panel. For those who know a fabrication guy, shop, or you a DIY.
    There not as much real estate in the back of the DC to do it. I’m not saying it can’t be done. Heck a subwoofer is hard to mount behind the seat in DC, but can be done.
    I think it’s a compromise or real estate.
    Anyone else want to throw there two cents in? :anonymous::anonymous:
    Trooper2 likes this.
  7. Aug 13, 2020 at 10:20 PM
    Inquiringone
    Ter
    NorCal 408
    Link to this please ? Slider left to right, not up and down? I have the left to right in my limited.
  8. Aug 13, 2020 at 10:25 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The PSW.
  9. Aug 13, 2020 at 10:40 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  10. Aug 13, 2020 at 10:41 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I seen it done on a single cab Tundra. But it's not for the faint of heart. It involves lots of work, time, money. The DC and CM cab designs are different so it will also involve cutting sheet metal, welding, fabrication. If it was an easy swap, I'm sure lots of people would have done it already.
    GODZILLA likes this.
  11. Aug 13, 2020 at 11:04 PM
    Inquiringone
    Ter
    NorCal 408
  12. Aug 14, 2020 at 4:15 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Hmmm....
    I bought my 2015 SR5 TRD DC previously owned. It has the rear slider window.
    If it's not stock, the previous owner did a nice job making me think it is.
    This is my third truck in 17 years; first truck to have this option...
    Love it...
    Inquiringone likes this.
  13. Aug 14, 2020 at 5:55 AM
    Trooper2
    JR
    Is the slider actually powered?
  14. Aug 14, 2020 at 5:58 AM
    Trooper2
    JR
    @1lowlife provided some links in post #9. Appear to be the same ones I have seen.
    Inquiringone[QUOTED] likes this.
  15. Aug 14, 2020 at 6:03 AM
    18" TRD Off Road Wheels
    I think the OP means the whole window like what a CM has. Lots of DCs have a small slider, but I haven't seen any that have the full window. If yours does, pics for sure!
  16. Aug 14, 2020 at 6:04 AM
    Trooper2
    JR
    Think slider refers to left to right type of opening window.
    GODZILLA[QUOTED] likes this.
  17. Aug 14, 2020 at 6:07 AM
    Agreed. That would be my thought process as well, but I've heard some people call the CM window a slider. Just trying to make sure I am understanding what is being said. :goingcrazy:
  18. Aug 15, 2020 at 5:30 AM
    Haggis777
    SW Michigan
    Yes, the switch is to the lower left of the steering column in this cluster below the headlight adjustment.
    And it is only the small horizontal slider to clarify. It does not go uppey-downey...
    Only leftey-rightey...
    Hope that wasn't too technical.:rofl:
    A full rear drop-down window would be sweeter, though.
  19. Aug 15, 2020 at 6:05 AM
    Trooper2
    JR
    Nice! :thumbsup:
