rustyboi
Discussion in 'New Member Introductions' started by Gatskopper, Aug 13, 2020.
  1. Aug 13, 2020 at 5:33 PM
    Gatskopper
    Gatskopper [OP] New Member
    Jan
    2014 Tundra Gen2.5
    New member from central Alberta Canada. 2014 Tundra Double cab, 5.7 iForce v8, heavy duty tow package. Base/Fleet/Utility trim. Magnetic grey. 80k on the clock. Platinum wheels and tyres. Portable lumbar support brace. Yellow fog lights
    Prostar 190, YardBird and Black Wolf like this.
  2. Aug 13, 2020 at 5:36 PM
    Welcome from Colorado.
    Gatskopper[OP] likes this.
  3. Aug 13, 2020 at 5:37 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Howdy.
  4. Aug 13, 2020 at 5:37 PM
    Check out:
    https://www.tundras.com/threads/canada-bs-thread.312/
  5. Aug 13, 2020 at 5:39 PM
  6. Aug 13, 2020 at 5:40 PM
    Gatskopper
    Jan
    2014 Tundra Gen2.5
    I hope to get some input or advice about truck bed rust. I have a gen 2.5 (the current shape). I have rust on the bed in the typical spots. Worse at box mounts ahead of wheel bulge, driver's side The rust has gone right thru the metal. If you Google Tundra truck bed rust, you'll see the typical areas. My truck is barely 5 years old and it's rusted right thru. I have a full service history with local Toyota dealer, where I bought it. I asked for help and they said #toobad #sosad
    What do I do? Am I the only one? Or is my early model of the current shape a forboding sentinel of what's to come for other gen 2.5 owners?
    Any input or advice appreciated!
  7. Aug 13, 2020 at 5:42 PM
    Gatskopper
    Jan
    2014 Tundra Gen2.5
    Thanks for the greetings! I'll be checking out your recommendations!
  8. Aug 13, 2020 at 5:43 PM
    Someone will chime in about this shortly. A known issue that does suck. Can be remedied but won't be a piece of cake. Any pics? Would greatly help!
    A 14? Your 14 has rust that bad already? Do they use road salt up there in the winter??
  9. Aug 13, 2020 at 5:56 PM
  10. Aug 13, 2020 at 6:04 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome Aboard from The PSW.
  11. Aug 13, 2020 at 7:03 PM
    Welcome from NY.
  12. Aug 13, 2020 at 7:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  13. Aug 14, 2020 at 4:37 AM
    Welcome from Ohio
  14. Aug 14, 2020 at 5:56 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal
  15. Aug 14, 2020 at 12:17 PM
    Gatskopper
    Jan
    2014 Tundra Gen2.5
    Just an update. Toyota Canada has told me to bugger off. Any info on accessing further recourse would be appreciated.
    With that out of the way, I'd like to at least give you a heads-up of the issue.
    The bed is mounted to the frame by 2 upside down U-shaped rails that run in a transverse fashion. These are located in front of and behind the rear wheel bulge.
    It is apparent that the edges closer to the wheels are unprotected, and have no seam sealer. It is just so that the area is well-suited to trap road salt and moisture. It is hard to reach to irrigate or clean.
    My suggestion is target-directed cleaning, and liberal coating with a creeping cosmoline type product.
    I'm sure there are many positions on rustproofing. I have started using CRC Heavy duty anti-corrosive, Marine. The cosmoline is dissolved in a dilutant, and this allows for aerosolisation, and it allows it to creep before the dilutant evaporates. This leave a well covered area of waxy, honey-coloured goodness. Cosmoline is what the military uses to keep equipment from rusting.
    Anyway, a little update and thanks for the welcome once again!
  16. Aug 14, 2020 at 12:30 PM
    Gatskopper
    Jan
    2014 Tundra Gen2.5
    Central Alberta gets it's fair share of anti-ice treatments on the road in the winter. I live in a remote rural town, but occasionally head to Edmonton. The City of Edmonton used a liquid de-icing product in 2018/2019. It has wreaked havoc on the concrete of the bridges (visible spalling), and lots of extra rust to vehicles.
    I'm just disappointed that I'm dealing with rust right thru the metal at 5 years...
  17. Aug 14, 2020 at 5:53 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  18. Aug 14, 2020 at 5:57 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
