Rock warrior grill question
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundy12, Aug 14, 2020.
  1. Aug 14, 2020 at 9:18 AM
    Tundy12
    Tundy12 [OP] New Member
    So I’ve heard you have to use different brackets when replacing the stock grill with a rock warrior grill. Is this true? If so does anyone have a link to where I can purchase them? TIA
  2. Aug 14, 2020 at 9:43 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Depends what year your truck is. You only need the additional brackets if you are installing on a ‘07-‘09. ‘10-‘13 already has the brackets so it is a direct swap from non-RW grille to a RW grille. I put one on my ‘10 Limited without anything additional.
    Iowa12tundra, Tundy12[OP] and SC_TRD like this.
  3. Aug 14, 2020 at 9:48 AM
    Tundy12
    Thank you sir. I have a 2012 so I should be good to go. Ordering one as we speak.
    Taco-Blender likes this.
