How to correct this bolt in a wooden fence
Discussion in 'Home Improvement' started by T-Rex266, Jun 30, 2020.
  1. Jun 30, 2020 at 9:35 AM
    T-Rex266 [OP] Fuck Cancer Staff Member
    I believe the wood is stripped where this bolt goes. (thanks to kids always slamming the gate!) Yes, I'm sure I can move the bolt slightly up, or down to fix it but I believe that will be a temp fix until it becomes stripped in the wood panels again.
    Thoughts?
    831Tun likes this.
  2. Jun 30, 2020 at 9:36 AM
  3. Jun 30, 2020 at 9:39 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Through bolt with a washer/nut on the end wouldn't work?
    Tundyfundy and 831Tun like this.
  4. Jun 30, 2020 at 9:40 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Don't you have a washer and nut on the other side? Get a longer bolt?
  5. Jun 30, 2020 at 9:41 AM
    It was installed when we purchased the house. I'm sure I can get a longer bolt, but won't that just be a temp fix, again?
    No, the bolt doesn't go all the way thru the wood panel.
  6. Jun 30, 2020 at 9:49 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    I would change them both out and just thru-bold them.
    Its just a better way to do it anyway and overtime it will last longer than just having the lag driven into the wood.
    Just get some nice black bolts washers and nuts and replace them both.
    Tundyfundy and Trooper2 like this.
  7. Jun 30, 2020 at 9:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It looks like the board is beginning to split as well. All fixes will probably be temporary until the kids are gone.
    tightywhitey, FrenchToasty and Dc2015 like this.
  8. Jun 30, 2020 at 9:51 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    Boerseun likes this.
  9. Jun 30, 2020 at 9:52 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    I agree!!
    :bananadance:
    Kung and Wynnded[QUOTED] like this.
  10. Jun 30, 2020 at 10:01 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I had that happen before. I ended up reinforcing it with some plumbers tape and a couple screws across the bracket to the left of the lag bolt.
    You could get a bolt and a washer and a nut, or coat the threads of the existing bolt in wood glue and hopefully it'll stick.
  11. Jun 30, 2020 at 10:05 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Every fix will be temporary; but what I would recommend (other than swapping out that board, and then securing the latch with a longer bolt/nut combo with washers on either side to distribute the force a little bit) is getting some JBWeld wood putty; fill the hole pretty good, then press it into the crack that's developing - extending beyond all borders. Once it dries, sand it down a bit, drill a hole for your bracket - and replace it using a longer bolt/nut combo with washers on either side. Honestly, I think repairing it is going to be more work than just replacing that board.
    Boerseun and T-Rex266[OP] like this.
  12. Jun 30, 2020 at 10:11 AM
    Jota21
    Jota21 New Member
    easier/temporary fix for this is to pull the bolt (called a lag bolt - the other style is a carriage bolt with the round head and nut), put a piece or two of copper electrical wire in the hole (i usually just have 14 or 12 gauge laying around), then reinstall the lag without over tightening. The copper gives the threads something to bite into.
    Boerseun, T-Rex266[OP] and Dc2015 like this.
  13. Jun 30, 2020 at 10:14 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    That works also!
  14. Jun 30, 2020 at 10:34 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's what I usually do with smaller holes, such as door hinges. Even just stick a toothpick or 2 in the hole and let the screw bite into that. That would be my approach here also, unless OP can do a through bolt with a washer and nut on the other side, which would be the easiest fix.
    1lowlife and Dc2015 like this.
  15. Jun 30, 2020 at 11:44 AM
    Ok, I found a longer lag bolt and used that after putting some wood glue on the slot. Good eye @Wynnded
  16. Jul 24, 2020 at 1:16 AM
    cecilperez
    cecilperez New Member
    Cecil
    Nice decision. What type of glue have you used? I know that Devcon 5 Minute Epoxy glue works perfectly with wooden parts.
    Dc2015 likes this.
  17. Aug 13, 2020 at 7:05 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    You can try this. Get a piece of 2x4 block and Two longer lag bolts on the inside of the gate. This is only run into a picket so there is nothing holding it. I just rehung two gates on my fence.
    The 2x4 block will give support behind the pickets. I’d make it about a foot long if you can. Just screw it along the whole block.
    Wind usually catches my gates and does the same thing your kids do - slam it shut.
    Tundyfundy and T-Rex266[OP] like this.
  18. Aug 13, 2020 at 7:07 PM
    That was a good suggestion as well
  19. Aug 13, 2020 at 7:09 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sorry if it was already suggested but you can through bolt using a carriage bolt washer and carriage bolt on the inside and have the nut where the present bolt head is.
    https://www.amazon.com/Hillman-2903...ocphy=1014226&hvtargid=pla-308932625904&psc=1
  20. Aug 13, 2020 at 7:21 PM
    831Tun[QUOTED] likes this.
  21. Aug 13, 2020 at 7:24 PM
    SuperWhite20
    Robert
    Georgetown TX
    The trouble with just a through bolt is it is in a picket only. It needs a backer to prevent pulling out when the gate gets slammed by the kiddos or a strong wind. When these pickets dry in a year even a through bolt will come loose.
  22. Aug 13, 2020 at 7:31 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's really not the kids fault though they do wear out everything sooner than most adults. It's a combination of the hardware and build design. If you can put a stop on the post, just like any interior or exterior door has, it'll eliminate the issue long term. If you can nail or screw a piece of wood to the post that the gate closes against so the gate is stopped by the wood strip and not just the latch it should last a long time. Also, it's the framing (2x4 ?) the should be "stopped" not just the edge of a vertical 1x.
    Hope that makes sense
  23. Aug 13, 2020 at 7:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Look closely at the pic, you can see framing/2x4? behind the fence board where the latch is. Something like a 2.5-3" though bolt should hold quite well
  24. Aug 13, 2020 at 8:19 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Sounds like you need to do through bolts but put a metal lapping band across the pickets that gets drilled and through bolted with the latch bolts. Black wrought iron fencing straps are fairly common and can easily be tailored to your gate.
    https://www.oldwestiron.com/product-p/s-11-3.htm
    Just a thought, doesn't need to be this thick but it won't budge when slammed.
  25. Aug 13, 2020 at 8:35 PM
    That’s what she said
  26. Aug 13, 2020 at 8:40 PM
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    I would suggest using stainless steel nuts, bolts and lockwashers and having some kind of a steel piece behind there to give it more rigidity, the stainless won’t rust out and corrode, you can paint it black if you like but if you have some support behind there you should not have a problem with it coming apart
  27. Aug 13, 2020 at 8:55 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Change it out for this, and use through bolts.
    T-Rex266[OP] likes this.
  28. Aug 13, 2020 at 9:45 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    How do you open that from the other side?
  29. Aug 13, 2020 at 10:17 PM
    saybng
    Gary
    Ventura CA
    Attach a cable.
    Tundyfundy likes this.
