Swapping map lights to LED - now won't work at all!
Discussion in 'Lighting' started by sotex, Aug 12, 2020.
  1. Aug 12, 2020 at 3:14 PM
    sotex
    sotex [OP] Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    I'm swapping out my bulbs for LEDs. Got the passenger side done (damn those bulbs are a pain to remove), but when I plugged in the LED on the driver side...NOTHING. Flipped LED and still nothing. Tried another LED...NOTHING. Flipped...you guessed it - NOTHING. I even put the bulb back in and now it won't work either.
    What could I have screwed up while removing the bulb?
  2. Aug 12, 2020 at 3:15 PM
    timsp8
    NY
    Check the fuse. Are the others working? I think there was another thread here with the same issue.
  3. Aug 12, 2020 at 3:19 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Fuse is first thing to check. Are other bulbs working?
    sotex[OP] likes this.
  4. Aug 12, 2020 at 3:21 PM
    sotex
    Jeff
    San Antonio, TX
    All other interior bulbs are working. Does the driver side map light have its own fuse?
  5. Aug 12, 2020 at 3:59 PM
    Trooper2
    JR
    There could be another fuse, not sure, check manual. Can you check for voltage with a meter?
  6. Aug 12, 2020 at 4:11 PM
    sotex
    Jeff
    San Antonio, TX
    Thanks for the suggestions. I went back and reinstalled it and it worked. Now I'll disconnect the negative terminal before I do the rest because I hate what I've read from others!
    Patch999 and NewImprovedRon like this.
  7. Aug 12, 2020 at 4:16 PM
    Trooper2
    JR
    Pulling fuses may be easier.
    Good luck!
    sotex[QUOTED][OP] likes this.
  8. Aug 12, 2020 at 5:27 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    NewImprovedRon and sotex[OP] like this.
  9. Aug 12, 2020 at 6:30 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    are the led bulbs polarity dependent? some are. will only light up if plug in the correct side, if it doesnt turn ON. flip 180 and try again. it will work then.
    Tundyfundy and sotex[OP] like this.
  10. Aug 12, 2020 at 7:53 PM
    edwardc_
    edwardc_ New Member
    Edward
    2020 Tundra
    You blew the fuse it’s under the driver side dash easy to replace. It’s like 4 dollars at auto zone for a pack of 5.
    NewImprovedRon likes this.
  11. Aug 12, 2020 at 7:55 PM
    sotex
    Jeff
    San Antonio, TX
    Already fixed it. Thanks!
