Let’s talk suspension, icon vs fox
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Aug 8, 2020.
  1. Aug 11, 2020 at 1:04 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm seeing the same. Also notice the hose design is much shorter as well. Hopefully they did change the design, only way to know is to call them and ask a lot of questions. See if they still run a 16" coil, if they went down to a shorter length that might be a good sign.
  2. Aug 11, 2020 at 1:27 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    I emailed boss off-road just to see what they said, they were only able to give me extended and compressed lengths:
    Extended: 20.0 in
    Compressed: 14.55 inch
    calling fox next Like you mentioned
  3. Aug 11, 2020 at 1:39 PM
    Cummins3500
    Logan
  4. Aug 11, 2020 at 2:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you get a hold of them ask how long the reservoir hoses are too. Mine were longer than the coilover assembly itself, if they solved both problems that's great.
    Rica25 likes this.
  5. Aug 11, 2020 at 2:39 PM
    Casper421
    In the woods
    06 DC
    I don’t see fox having enough demand for a redesign to be feasible. 99% of these trucks are on 5100’s.
  6. Aug 11, 2020 at 3:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm hoping somebody's brakes went out and Fox had a holy shit moment. This is what Seanpistols brake line looked like after one or two off road trips.
    https://expeditionportal.com/forum/threads/seanpistols-01-tundra.100994/page-44
    My hoses were probably 3" longer and cans were meant to be mounted where his bumper bracket is, about 2" out from the frame.
    His had the newer reservoir with the adjusters, that included a 90 at the can where mine had a straight fitting. You can see what he did to solve his problems on this link. I considered doing the same on my cans but it didn't provide enough clearance for me. His hoses are a bit shorter and he had way less backspace than I have. Plus his 35s were nearing the frame further forward than my 33s. Interesting how small geometry changes make such a difference.
    pickeledpigsfeet and Hooptytrix like this.
  7. Aug 11, 2020 at 3:31 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Would love to hear from one of our knowledgable vendors who sell Fox for their input about 2020 Fox shocks.
  8. Aug 11, 2020 at 3:59 PM
    Cummins3500
    Logan
    spot on, no Redesign per they’re technical support. Still using a 16 inch coil, and couldn’t give me the length of the reservoir hose. I’m not sure what they’re brochure I linked above is measuring. Guy confirmed that the eyelet does set at the bottom of the coil like the first picture @Darkness posted. Told me the picture on the part number I clicked isn’t an actual representation, can’t go by that
    fox is crossed off the list official, at least for the fronts
  9. Aug 11, 2020 at 4:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    ADS might actually be better. The first set I saw looked just like Fox, but examining the set Jimmy had, the lower coil perch has a little bit more rise. You might be able to message him to see if he had any problems with his. He broke just about everything else on his suspension so if they were a problem he would know :rofl:
    Front page he posted a pic of the shocks, front ones have a bit of a gap between the eyelet and the perch. Rears look nice too.
    https://www.tundras.com/threads/jt-02-tundra.22274/
  10. Aug 11, 2020 at 5:03 PM
    Cummins3500
    Logan
    I just dropped him a message with a ton questions. I looked through his build thread, he’s put the ads setup and camburg arms through their paces
    Darkness likes this.
  11. Aug 11, 2020 at 5:18 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I have tried to explain this to people but apparently I lack a thesaurus and could not get people to understand why digressive struts are the way to go
  12. Aug 11, 2020 at 5:42 PM
    Cummins3500
    Logan
    Hang on man, I’m here to learn. If you got some info to add by all means post it up. I’m trying to buy once cry once
    Like I mentioned earlier I came from the xterra world. Body lift, t-bar crank, some uca’s, and shocks and it was set
  13. Aug 11, 2020 at 5:53 PM
    Professional Hand Model
    Fred
    Hand Protectors
    $2-3k will get you 4 nice shocks and some coils. Start adding off that number with all the extras you’ll want to do ‘while in there’ up front. Plan on spending $$$ more to do it all right the first time.
    You’ll spend $1-1.5k on rear customs leafs and the assorted sundries.
  14. Aug 11, 2020 at 5:55 PM
    Hooptytrix
    Dirty South
    Google can explain better than me but simply they function completely opposite of each other. If you take a progressive strut and press it against the floor with your body weight, the piston will go in slowly. Digressive will not, it will stay firm. Now slam it and the digressive will collapse, progressive will lock (hydro lock). Now take that to driving a rally car at high speed bouncing and jumping all over the place, that is digressive struts in action. Progressive struts can’t take that beating, they would lock up and you will be riding on bricks.
    Downside is digressive struts ride firm on low speed holes, dips and bumps. Progressive struts are excellent in that part
  15. Aug 11, 2020 at 5:58 PM
    Hooptytrix
    Dirty South
    And I’m surprised no one has mentioned Keith from dirty deeds. He beats his truck off road and created a whole business with his knowledge. Check out his website and email him, he is super cool and really knowledgeable
  16. Aug 11, 2020 at 5:58 PM
    Fred
    Hand Protectors
    junior and Hooptytrix[QUOTED] like this.
  17. Aug 11, 2020 at 10:27 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ive ran icons on my tacoma for 10 years now (when my father had it it had Donahoe shocks. aka icon before icon) they do ride stiff slow speed impacts but smooth on the highway... ive got nothing to complain about with it, i actually love how they ride... my big thing with fox is any truck i see traded in at work (so a few. but less than 10 in 6 years) with fox, THEY RUST BAD if your in the rust belt.
    Hooptytrix likes this.
  18. Aug 11, 2020 at 11:08 PM
    celicacy
    celicacy New Member
    Cy
    Jacksonville, FL
    2014 Tundra Crewmax
    Icon 2.5 Coilovers, Icon UCA, Katzkin Leather, LED Headlight, Nitto Ridge Grappler 305/55/20, Fuel Wheels, Trd Rear Sway bar
    I just installed some Icons 2.5 front and rear. No complains so far. Feels a lot more solid on turns and a lot less body roll. I can also get close to 4 inches of lift from the coilovers. Customer service is also top notch!
  19. Aug 12, 2020 at 4:57 AM
    Fred
    Hand Protectors
  20. Aug 12, 2020 at 5:12 AM
    #50
  21. Aug 12, 2020 at 5:15 AM
    #51
    Fred
    Hand Protectors
    Right now were up to about $3-5k in shocks and leafs packs. Whats our budget on this project?
    Sunnier and robabeatle like this.
  22. Aug 12, 2020 at 9:12 AM
    #52
    Cummins3500
    Logan
    @Professional Hand Model
    I was shooting for around $3500 when I was planning on the icon stage 3 kit w/ camburg or total chaos uca’s.
    I read about shock valving till I’m crossed eye And it seems like when I settle on something, that option falls out. The dude with ads didn’t speak to highly of em
    @FirstGenVol
    I’ll give them Elkas a look
  23. Aug 12, 2020 at 9:40 AM
    #53
    empty_lord
    05 rollover special
    I’ve got camburgs on the tundra, I had chaos on the taco. Then Icons on the taco.
    They’re all the same for the most part. Camburgs can be had cheaper, that’s why I went with camburgs.
  24. Aug 12, 2020 at 10:40 AM
    #54
    Fred
    Hand Protectors
    It gets overwhelming. I lurked this site a little bit :D before joining and got crosseyed myself. I’ve always had success by keeping things simple which is why I ended up with the 5100’s and having others do the work. I spent about $3500 for a basic OEM total front re-build (parts AND labor).
    New:
    1) 2-OEM LCAs
    2) 4-5100’s
    3) Sway links
    4) Front rotors and pads (Quality)
    5) China cheapo front CV axles
    6) High Dolla Alignment with read outs
    7) SPC Cams Bolts (quality)
    Couple of things:
    1) Shoulda taken the spindles and had new bearings installed.
    2) Shoulda gone OEM new CV Axles.
    Got lucky and scored my job on the ‘once a year tax free’ holiday! Saved $500!:yes:
    Those Icon and Camburgs look nice and I may do those in a few years. DIY will make it worthwhile this time.
  25. Aug 12, 2020 at 10:53 AM
    #55
  26. Aug 12, 2020 at 10:56 AM
    #56
    Fred
    Hand Protectors
    I’d put ‘go home turd gen!’
  27. Aug 12, 2020 at 10:57 AM
    #57
    I was so excited to use @Lil Steve meme I forgot to write words.
  28. Aug 12, 2020 at 11:18 AM
    #58
    Bro, you didn't even give credit to the right guy. :rofl:
    @Lil Steve made that one.
  29. Aug 12, 2020 at 11:19 AM
    #59
    Omg, I'm full of the derp today. Too much heat...
    GODZILLA and Darkness like this.
  30. Aug 12, 2020 at 11:22 AM
    #60
    Fred
    Hand Protectors
    Weekend Beer Detox Program is on its third day.
    DT’s are next. :D
    Darkness and bmf4069[QUOTED] like this.
