Trailer brake and Signal and lights not working
Discussion in 'New Member Introductions' started by Larrissey, Aug 12, 2020.
  1. Aug 12, 2020 at 8:25 AM
    Larrissey
    Larrissey [OP] Don’t become a victim of your own success
    Christopher
    Alberta
    2010 Platnium 270km
    18”wheels
    Hi guys,
    I’m delighted bob took the time and energy to set up this forum.
    I will try my best to explain my issue.
    I have all but 2 wires not working in my 7 pin female receptor plug. Yellow and black. These wires are responsible for brakes and signal lights. I traced them to the first junction box under the hood. I tried swapping relays with the wife’s 4 runner and all fuses and now I am at a still.
    Any information would help
    YardBird likes this.
  2. Aug 12, 2020 at 9:11 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The PSW.
  3. Aug 12, 2020 at 9:13 AM
    Larrissey
    Christopher
    Alberta
    2010 Platnium 270km
    18”wheels
    Thanks buddy
  4. Aug 12, 2020 at 9:27 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  5. Aug 12, 2020 at 10:22 AM
    Larrissey
    Christopher
    Alberta
    2010 Platnium 270km
    18”wheels
    Thanks Man ,
    I have spent 5 hours so far on it tracing it back and fuckin with fuses under the hood however I have not messed with the flasher relay under the steering.
    That’s tonight’s project
    If this doesn’t work I might resort to an auto electrician.
  6. Aug 13, 2020 at 3:30 AM
  7. Aug 13, 2020 at 8:05 AM
    Larrissey
    Christopher
    Alberta
    2010 Platnium 270km
    18”wheels
    Thanks Adam,
    I see you got over 45k messages and I’m thinking that you must be on the forum as a full time job. That’s a crazy amount of writing.
    landphil likes this.
  8. Aug 13, 2020 at 8:36 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Welcome from the west side of the hump.
    Yup, make sure that 30A “Towing” fuse is good, and in the correct location. Then check out the flasher relay.
    1lowlife likes this.
  9. Aug 13, 2020 at 10:04 PM
    Larrissey
    Christopher
    Alberta
    2010 Platnium 270km
    18”wheels
    Thanks landphil,who knows why the flasher is in such a shitty spot. I checked the fuse and it’s all good. I read rock auto are good for buying a cheaper flasher relay. I’m gonna see if Toyota has one in stock if not I will go for the rock auto.
  10. Jul 26, 2025 at 8:39 AM
    probin
    probin New Member
    Phil
    2021 Tundra SR5
    Ok, looks like I’m 5 years late to this forum and topic. I’m driving a 2021 Tundra SR5. I’m having the same issue with the trailer brake lights and turn signals not working when hooked up to multiple trailers. I’ve checked all my fuses including placement and all looks good. I thought maybe it was the R1 tow relay but that wasn’t the problem either. I even replaced the 7pt trailer port and still same problem. Anyone have any suggestions? Extremely frustrated with this one as I keep coming up empty handed with a solution. Thanks! Can’t wait to see what the answers are.
  11. Jul 26, 2025 at 8:32 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Zombie Thread! @probin, you might get a lot more responses if you post your question in one of the applicable forums. This very old intro post probably doesn't get much traffic.
