  1. Aug 12, 2020 at 7:43 AM
    #6841
    Good man. This is my attitude also, and I wish more humans on this f'n planet would behave the same FFS. It would be so much better of a place to live, feel much more like a global community if we did.
    But to PHM's point, unless you've suffered through something once, the gesture doesn't mean as much. So I wouldn't expect too much love or appreciation out of anyone you're hooking up if they haven't been down the opposite road of perish at least once or twice in the past so they know how much appreciation is warranted.
    Damn, Limited too. That's a great deal! Congrats. As our oldest is 10 this year, I'm going to need to start thinking about stuff like this. Damn sure won't get my truck.
    bmf4069, Hooptytrix and GODZILLA like this.
  2. Aug 12, 2020 at 8:52 AM
    #6842
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    It's a nice little buggy.
    The paint is kinda a mess. Been out in the sun it's whole life. Getting quotes on painting
    Inside of car is perfect.
    GODZILLA likes this.
  3. Aug 12, 2020 at 9:11 AM
    #6843
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sixer?
  4. Aug 12, 2020 at 9:17 AM
    #6844
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Nah 4 banger.
  5. Aug 12, 2020 at 9:34 AM
    #6845
    empty_lord
    05 rollover special
    2.4 then eh. Take a picture of the engine near the timing cover and I can tell you if it’s been re ringed or not. If it hasn’t you might be able to get it re ringed for free.
  6. Aug 12, 2020 at 9:35 AM
    #6846
    empty_lord
    05 rollover special
    Or just private message the Vin and I can tell you
    TX-TRD1stGEN likes this.
  7. Aug 12, 2020 at 9:41 AM
    #6847
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Sending pm now
  8. Aug 12, 2020 at 10:02 AM
    #6848
    When did they switch to the 2.5L? That's whats in our 2012 but it's the same 3rd generation. Do the 2.5's suffer from the same problem?
  9. Aug 12, 2020 at 10:05 AM
    #6849
    empty_lord
    05 rollover special
    Some do. Not as bad. But we are seeing them come in burning oil bad. Mostly people sticking to the 10k interval on oil. And driving in town never highway
  10. Aug 12, 2020 at 10:08 AM
    #6850
    Makes sense. Ours hasn't started burning any oil but I've changed the oil religiously every 4-5K.
  11. Aug 12, 2020 at 10:28 AM
    #6851
    Professional Hand Model
    Fred
    Hand Protectors
    Fluid whore!:D
  12. Aug 12, 2020 at 10:54 AM
    #6852
    Fred
    Hand Protectors
    @empty_lord
    Whats your take on the best diy Coolant System Flush product?
    The Toy stealer here uses BG and they put the truck on a machine. I’ve had them do this a long time ago on the truck with coolant and oil systems, but I’ll be DIY the TB Job and at the same time want to get the coolant system walls cleaned up prior to the fresh fluids and New Radiator going back on.
    Anyone else with a recco please chime in. Thank you.
    For rust, I’ve seen Thermocure as a high recco. Other options are available for removing oils/gunkies, but not sure about them. Seems like a messy part of the job.
  13. Aug 12, 2020 at 11:04 AM
    #6853
    empty_lord
    05 rollover special
    Drain and fill. Drain the radiator, drain the 2 plugs on the engine block. That gets most out. Toyota coolant doesn’t need a flush flush unless it’s been mixed with other colors or engine replacement, etc
  14. Aug 12, 2020 at 11:17 AM
    #6854
    Fred
    Hand Protectors
    Good news on this. I’ve done the plug removals on both sides of the block on my last coolant job. Even did the heater coil flush out with a hose and poured new coolant in there before burping.
    Goofy prior mechanic did put the ‘green’ coolant in 5 years ago which is why I switched back to Asian Red last year. I assume this is ok. Current System fluid looks good after a year of the Red. Recco flush or good to go?
  15. Aug 12, 2020 at 11:28 AM
    #6855
    empty_lord
    05 rollover special
    You should be fine. Drain radiator and refill that to clean out some remnants of green if you really wanted. But probably not needed
  16. Aug 12, 2020 at 11:30 AM
    #6856
    Fred
    Hand Protectors
    Yeah. That got flushed out last year. I poured the red in with the plugs off and watched it run out. I’ll be changing the oil cooler hoses this time so all that section will be drained. :yes:
    bmf4069 likes this.
  17. Aug 12, 2020 at 11:46 AM
    #6857
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    i know it's been discussed because i think i recently stumbled across it, BUT
    can you fuck up not using specific coolant?
    Had some Peak long life laying around and topped off a few weeks ago
  18. Aug 12, 2020 at 12:06 PM
    #6858
    empty_lord
    05 rollover special
    Green is safe. Just not as long lasting. Orange is when you have issues
  19. Aug 12, 2020 at 1:07 PM
    #6859
    GM pickup I bought 5ish years ago was in hell shape, coolant was brown. This is what I ended up picking up. Ran three cycles with this stuff. By the end of the 3rd cycle everything was clear.
    https://www.amazon.com/dp/B00B99U074/
    That said, I hadn't used it prior. It did work well. Was a tedious 3 hour process to finish, roughly an hour per cycle.
  20. Aug 12, 2020 at 1:42 PM
    #6860
    MEWaters
    MEWaters New Member
    Maine
    errr, I added green to a reservoir filled with orange or red?
    is a flush in order?
  21. Aug 12, 2020 at 1:48 PM
    #6861
    You might as well. It can only help at this point. Make sure you drain those plugs that were mentioned earlier.
  22. Aug 12, 2020 at 1:56 PM
    #6862
    MEWaters
    MEWaters New Member
    Maine
    thank ya
    due for bay 2 O2 sensor, tire rotation, transmission flush, oil change, and this
    great for a new guy lol
  23. Aug 12, 2020 at 2:27 PM
    #6863
    Fred
    Hand Protectors
    Gorilla Arm Technique will be needed!
  24. Aug 12, 2020 at 2:28 PM
    #6864
    MEWaters
    MEWaters New Member
    Maine
    i have ungodly arm length / reach but not sure about the muscle part any more.
    Will get to it all
  25. Aug 12, 2020 at 2:36 PM
    #6865
    Fred
    Hand Protectors
    Get the Zerex Asian Red from Wallace Wurrld. Cheap and meets all Japanese Specs.
    Flush that Heater Core and blow it out with Borneo Blow Dart Technique. Then fill it up with the Asian and reconnect. Proceed to fill the radiator and let some run out of the valve at the bottom to wash the crud out. Any hoses you can open and run some new through makes for cleaner job.
    Button it all up and burp it. Find a steep driveway and let her run. Top off the rez to the high line when hot and that is your new bench mark check line. Should never move when engine is hot. If it does you have a leak. Cold engine and the line will show lower until it heats up and expands up to your top line.
  26. Aug 12, 2020 at 3:31 PM
    #6866
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I love the directions given around these parts for DIY stuff. gives me a lol about everyday.
  27. Aug 12, 2020 at 3:52 PM
    #6867
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How hard is it to remove the clear lens from the instrument cluster?
    I think I'm turning into PHM with all this 303 I've been using lately.
    The dust under the trip reset button is bothering me. :rofl:
    bmf4069, NUDRAT[OP], CodyP and 2 others like this.
  28. Aug 12, 2020 at 3:56 PM
    #6868
    Fred
    Hand Protectors
    I read about some guy who polished all his scratches off of the lens. Its been a few years since reading about it. I think the process is tricky, but you can do it. Might be able to blast some compressed air in the hole and disperse the dust instead of removing.
    Tundra2[QUOTED] likes this.
  29. Aug 12, 2020 at 4:03 PM
    #6869
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    It's not hard. Just have to remove guage cluster and then it is simple.
    I have heard of people replacing it.
  30. Aug 12, 2020 at 4:39 PM
    #6870
    Fred
    Hand Protectors
    You ever see this have oil leak/seep? Anyone and/or @empty_lord
    Wondering if the figure 8 gasket should be replaced while ‘in there’ doing TB?
