Rear end hit, frame damage - how bad?
Discussion in '2nd Gen Tundras (2007-2013)' started by robots4joey, Aug 10, 2020.
  1. Aug 10, 2020 at 11:58 AM
    robots4joey
    robots4joey [OP] New Member
    2010 crewmax 4.6l
    This tundra is a 2010, apparently the accident was 6+years ago. Truck is aligned every year and has no driveability issues. My thoughts are this is just a towing/trailer braking risk, as well as rear collision risk. I originally considering leaving it unrepaired but never towing over 2,000lbs...
    I know this is a fairly common problem with rear collisions, I'd love to hear from anyone with experience either fixing or leaving the frame as is...
    Last pic is other side, also has a smaller bend too
    Other side also has slight kink as well
  2. Aug 10, 2020 at 12:06 PM
    robots4joey
    2010 crewmax 4.6l
    Slight bed hump too
  3. Aug 10, 2020 at 12:33 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well that’s not helping anything by being bent like that. But with where it is a frame shop should be able to straighten it out for less that $1000
  4. Aug 10, 2020 at 12:38 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Get it fixed.
    Consider if you were in a second accident. Do you want a solid frame or one with pre-crumpled zone?
  5. Aug 10, 2020 at 12:43 PM
    robots4joey
    2010 crewmax 4.6l
    I'm with you guys. I'm pretty sure I can get it fixed (maybe not 100pct cosmetically) and then not have to worry about it! Now to get some quotes...
  6. Aug 10, 2020 at 6:27 PM
    myktundra
    myktundra New Member
    2011 Tundra DC TRD SAP
    Can it be straightened and then maybe boxed in a bit or double up on the metal to keep it strong?
  7. Aug 11, 2020 at 8:54 AM
    Dr_Al
    Dr_Al New Member
    Al
    My guess is that it's designed to be crumple zone from the factory so when in an accident it bends to soften the blow to the people in the cab. I can be straightened with a frame machine. I wouldn't beef it up as you could make it too strong. I would also replace the bumper mounts as they are most likely bent as well.
