35s on stock rims
Discussion in 'Wheels & Tires' started by Tomdra, Jul 28, 2020.
  1. Jul 28, 2020 at 6:04 PM
    Tomdra
    Tomdra [OP] New Member
    Hey guys. I'm looking to put 35s ko2 on stock 18" trd rims.. also putting on a 3/2 leveling kit... Question is. How big of a spacer would I need to avoid BMC. Another option is just buying new rims.. if I went with a new 18"r what offset would I need to fit a 12.5 wide 35 ?.... Thanks.
  2. Jul 28, 2020 at 6:56 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Atleast 1.5", that's what I ran on my old 2007, if you go new rims +25mm offset is a good sweet spot
    Tomdra[OP] likes this.
  3. Jul 28, 2020 at 6:58 PM
    Tomdra
    So what would a 18 offset do? ..
  4. Jul 28, 2020 at 6:59 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Just do the BMC. I don't see how spacers will but will more than likely exacerbate the issue.
  5. Jul 28, 2020 at 7:01 PM
    Berdine
    Frank
    Binghamton, NY
    Push your wheel out farther. You'll need to remove front mud flaps, possible body mount chop, depends, mine only rubbed at full lock
    Bfgs run smaller than 35s. There was a guy years ago did it with no wheel spacers, no bmc if I remember
    Tomdra[OP] and 831Tun like this.
  6. Jul 29, 2020 at 7:22 PM
    Tomdra
    So basically I can dump the 35 on my stock 18s and no spacers and do the BMC?
  7. Jul 29, 2020 at 7:33 PM
    Berdine and Tomdra[QUOTED][OP] like this.
  8. Jul 29, 2020 at 7:36 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Believe it or not, all the trucks are slightly different. I dunno if that'll work for you. I seem to remember that I ran 35s on stock wheels w/ 1.25" Spidertrax spacers and needed a BMC. I think the spacers were purely for stance and may have caused the need for the BMC. Or the spacers may have been required to clear the UCAs. Sorry, I can't remember.
    Berdine and joonbug like this.
  9. Jul 29, 2020 at 7:42 PM
    Tomdra
    I am just gonna have to try and find out from the sounds of it .. thank you tho
    Berdine and 831Tun like this.
  10. Jul 29, 2020 at 8:05 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    35s on stock rims without spacers will almost def hit on the stock upper control arm as well
    joonbug likes this.
  11. Jul 29, 2020 at 8:06 PM
    Tomdra
    Almost or definitely? I'm looking for a sure answer thanks
  12. Jul 29, 2020 at 8:07 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I don’t have personal experience but I have heard that they WILL based on the tons of content I’ve read here over the years
    joonbug and Tomdra[QUOTED][OP] like this.
  13. Jul 29, 2020 at 8:08 PM
    Tomdra
    Thank you. I'll keep my fingers crossed. And will update tonmorow
  14. Jul 29, 2020 at 8:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You put spacers to clear your uppers which caused you to get a BMC.
    Tomdra[OP] and 831Tun[QUOTED] like this.
  15. Jul 29, 2020 at 8:09 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks, at least someone remembers.
  16. Jul 29, 2020 at 8:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Haha. I don’t really remember if that’s what actually happened to you. I’m just guessing. A 35” tire that’s a legit 12.5” wide will hit the uppers. OP I’d suggest just going with 295/70/18. That will most likely fit without spacers and a CMC. Maybe. Lol
  17. Jul 30, 2020 at 7:16 AM
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    Ok my stupid question for the day....What does "BMC" stand for?
  18. Jul 30, 2020 at 7:22 AM
    Tomdra
    Body mount chop.
  19. Jul 30, 2020 at 7:23 AM
    Rlawshe1
    Rlawshe1 New Member
    Rob
    2020 MGM
    Also keep in mind that generally the stock TRD wheel will be a 18x8. A 35x12.50x18 will need at the bare minimum a 8.5” wide wheel for a safe fitment. At the tire shop that I run, we absolutely would not do that install for liability reasons
  20. Aug 9, 2020 at 6:13 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Some manufactures also make a 35 x 11.50
