Diode Dynamics Stealth LED Light Bar
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by GREENwithENVY, Aug 9, 2020.
  1. Aug 9, 2020 at 11:29 AM
    GREENwithENVY
    GREENwithENVY [OP] New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Anyone mount this LED light bar and hate the mounting brackets and fasteners as much as I do? The light bar is top notch...the mounting bracket and fasteners needs re-engineering.
    You cannot adjust the light once mounted to the truck - it has to be removed. And, the M6-1.0x10mm socket head screws are not long enough - by the time the bracket, lock washer, and flat washer are added, approximately 4.1mm of the thread remains.
    I've had to tap out both sides to straighten up the threads and ordered some 14mm socket head with a flange to increase the set on the screw (and hopefully be able to tighten it sufficiently from moving).
    I finished the CS Designs switch bank for the console - it turned out pretty good.
  2. Aug 9, 2020 at 2:02 PM
    Tommy750
    Tommy750 New Member
    2019 Voodoo Blue TRD Pro
    Completely agree with you on the stupid mount. Put mine on about 7 months ago and guessed at the adjustment. Now, about 10K street and maybe 200 desert off road miles later, the bar is still fastened on tightly but has sagged to where it rests on the bottom of the enclosure. The light also vibrates quite a bit on washboard roads since the mount flexes a fair amount. Probably going to stick a couple short pieces of foam tape underneath the unit to "fix" this problem for now. Let us know if you come up with a more elegant solution. That said, it is pretty solid and I still crack a smile every time I flip it on cuz the LED is nice and bright. BTW, nice switch detail.
    Beesta, ElNopal and GREENwithENVY[OP] like this.
  3. Aug 9, 2020 at 2:21 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Where did you get the cup holder and shift trim?
  4. Aug 9, 2020 at 2:31 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    AJT Designs
    SM 2018 1794 likes this.
  5. Aug 9, 2020 at 4:00 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Do you have a contact for the CS Designs. switch bank?
    Rocfrog likes this.
  6. Aug 9, 2020 at 4:05 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    X2
    I just relented to having the light bar “rest” on the small elevated tabs that held the bumper grille.
  7. Aug 9, 2020 at 4:27 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I guess I should get it right (CN, not CS) - or @Rocfrog here on the forum!
    Rocfrog likes this.
  8. Aug 9, 2020 at 4:54 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Thanks!
    Rocfrog likes this.
  9. Aug 9, 2020 at 5:46 PM
    SouthWestGA
    Thanks! Unfortunately they don’t make them for second gen
    Geo4x4 likes this.
  10. Aug 20, 2020 at 11:43 AM
    TUNDRA13KID
    TUNDRA13KID New Member
    steve
    A LOT
    Looking for a 52" led light bar to install above the front windshield. Can you redpond with your pros and cons? Thx
  11. Aug 20, 2020 at 12:34 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Pros: Looks Cool
    Cons: Wind-Noise at highway speed | Off Road Use Only - must be covered at all time in some States.
    TUNDRA13KID[QUOTED] likes this.
  12. Aug 21, 2020 at 4:46 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Well, after a F-ton of issues with the DD42, I decided to purchase the Cali-Raised 32" Stealth bar. The brackets are superior to anything I've seen - two mount points to the truck, good hardware. Only downside is no install instructions...and their online videos leave out the most important install technique - how to remove the plastic piece from the bumper (without breaking the tabs or dropping the entire bumper). To remove the plastic piece, it takes finesse and patience - getting your hands in the area and using a ratcheting box end to remove the nuts. It took about 3 hours pull the trim pieces, install the light, and reinstall the trim...(the light harness was already ran from the DD42). Well hidden and looks good...will post pictures later.
    TUNDRA13KID likes this.
  13. Aug 22, 2020 at 6:27 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Pictures of switch on/off (backlit, ran add-a-fuse tap to fuse box - no splicing or t-tapping wires (not a fan of cutting factory wire).
    Pictures of Cali Raised 32" Stealth Bar installed and lit up.
    Sophara, bulldog93, Mike59 and 5 others like this.
  14. Aug 22, 2020 at 7:03 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks really good , i have the DD lights also, I ended up tapping one side cause i strip it, I definitely agree the brackets are not that great.
  15. Aug 22, 2020 at 8:55 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    The use of Posi-taps offers a superb alternative to the “cutting of factory wires”. One small prick of a needle-like point is used to pierce/tap the wire. If a change of wire set-up is required later, the Posi-tap can be removed and the factory wire remains intact. In fact, many times, the insulation of the pierced wire “self-heals” and requires very little, nothing more than a wrap or two of electrical tape.
    I have used them with great success. More so, I have an illumination circuit line that is tapped with them that I have extended, dedicated to feed all subsequently installed OEM factory style switches. I prefer the switches to all have dimming capability with the rest of the dash lights.
    https://www.amazon.com/Posi-Tap-Con...ild=1&keywords=posi-tap&qid=1598110802&sr=8-9
    Cheers on the light bar, looks great!
    bulldog93 and Mater like this.
  16. Aug 22, 2020 at 9:52 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Learn something every day...never heard of those...being an old school solderless connector "crimper," when I saw the add-a-fuse for the box, I thought "...wish I'd had those 30 years ago when in the floorboard installing radios, amps, and speakers." Good to know...thanks for the suggestion.
    bulldog93 and ElNopal[QUOTED] like this.
  17. Aug 22, 2020 at 10:07 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I hear you! I actually learned about them here on this site from a couple of early posts @NewImprovedRon had made suggestions to members about. I since had given them a try and have not looked back! I usually have about a dozen or more on hand in the various sizes just because they are so flexible/reversible for in-cab wiring projects.
    Best!
    NewImprovedRon likes this.
  18. Sep 8, 2020 at 4:46 PM
    French Avocado
    Utah / Wyo
    @GREENwithENVY - what did you use to paint the CN Design switch plate?
  19. Sep 8, 2020 at 5:26 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I used all Rust-Oleum products - I used 180-220 grit to lightly sand the plastic printer build lines down. Be careful not to round edges or remove too much plastic. Moved to 400-800 grit and wet sanded the part. There will still be some build lines - that's okay.
    Move to the plastic adhesion promoter to prep the part. Once dry, used the gray filler primer (this stuff has a lot of solids in it). I sanded a couple of times in between coats. Most, if not all, build lines will be gone and your piece will be smooth to touch. I started spraying the flat black (2X Ultra Cover Flat Spray) and wet sanded with 1000 grit until very smooth - 2 or 3 coats (until satisfied with the finish). Then used the flat clear (2X Ultra Cover) and made sure all the surface was a worthy of being a production part. Since the painted layers was so thick - I allowed the part to cure for a week in my garage (I've found all my painted parts in the Tundra cab hold up much better if allowed to cure).
    You can find all these paints/sandpaper at Advance Auto Parts...probably Walmart too.
  20. Sep 8, 2020 at 8:24 PM
    French Avocado
    Utah / Wyo
    Thanks much!
    GREENwithENVY[OP] likes this.
  21. Sep 21, 2020 at 3:11 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    @jaysbeaker
    French Avocado and jaysbeaker like this.
  22. Sep 21, 2020 at 3:21 PM
    jaysbeaker
    jaysbeaker New Member
    2020 Smoked Mesquite Platinum
    Drivers side grab bar
  23. Sep 25, 2020 at 8:06 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    I had the same sag before .... install heavy gauge zip ties and that lift it off the panel ...
    ElNopal likes this.
  24. Sep 26, 2020 at 7:35 AM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    So thinking about ordering the Cali-raised stealth LED light bar, I want to know if it is easy to adjust without rmving the front bumper such as the DD-42. Where did you also find the best instructions for removing the plastic piece from the bumper? Light looks awesome by the way! definitely on my list of mods.
  25. Sep 27, 2020 at 10:52 AM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Here's my opinion - once you snug the light up, I used a small bubble level to determine a very small (hair) downward angle and tightened it up. The brackets really almost set the light bar perfect, IMHO.
    I didn't find the best instruction...but I followed Cali-Raised video (which conveniently leaves out the hardest damn part) and looked over a post of some dude who snapped all 6 plastic pegs off removing the black center bumper piece. Another person said you can get it off, if you take your time and are patient...I agree with him.
    If don't have a creeper...go buy one...probably the best HF purchase I've made. Plus, pick up some ratcheting wrenches - I used the 10mm to loosen the aluminum nut caps from the plastic "thread," then used a regular 10mm socket to continue to remove by hand.
    Step #1: Remove 3 plastic trim pins (use plastic panel tools)
    Step #2: Remove the two 10mm bolts on each end
    Step #3: Gently flex the bottom of the black plastic trim so you can reach your hand and arm in there...feel around and you will feel those aluminum nuts (3 on each side). Use your ratcheting wrench to loosen the nuts and remove by hand using a socket...repeat 5 more times.
    The hardest part of the removal is braking the 14mm bolts on the top bumper bracket (if you've messed around with the DD42, you know what I mean).
    I purchased the Harbor Freight creeper after I struggled with the DD42 to install the Cali-Raised...after rolling around for a few hours, I wondered what the hell is wrong with me that I'd not bought one of these before.
    bulldog93 likes this.
  26. Dec 13, 2020 at 12:36 AM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    I just installed my 42” as well. Piss poor brackets/very nice light. That bracket could be properly made from something like 1/8 “ or 1/4” plate. Bumper studs seem long enough. Also, someone could have two mounting holes in them for each side if they do the math right and the light bar would be solid and also not have to guess how far in or out it will be. Mine is set to far in. I wanted to keep it rigid as possible. Didn’t help much. You can see a 1/2” gap then the tabs. Going to have to reposition at a later date. If anyone has come up with a good fix, I’m all ears. Merry Christmas All!!
  27. Dec 13, 2020 at 8:24 AM
    Saab95v6
    Saab95v6 New Member
    I just received my DD42" light bar , looking at all the mounting issues , it will be best for me to just return it and wait till there is a better mounting solution.
  28. Dec 13, 2020 at 9:34 AM
    Lugnuts2020
    2018 crew max
    im going to mess around with it and see what solutions I come up with....more to come.
    JEFFTHEROBOT likes this.
  29. Dec 13, 2020 at 4:34 PM
    Lugnuts2020
    2018 crew max
    Ok.....adapt and overcome. Maybe not the most ideal but will get the job done for sure. Light bar is now very secure. Adding the side bolts to the bumper will only make it nearly impossible to try and steal it. At least in a timely fashion.
    GREENwithENVY[OP] and ElNopal like this.
  30. Dec 13, 2020 at 5:10 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I wish I saw this thread before I ordered mine. Supposed to be here in a couple days. Not sure if I’m going to keep it now or return it.
