bumper shims
Discussion in '2.5 Gen Tundras (2014-2021)' started by Henry2019, Aug 8, 2020.
  1. Aug 8, 2020 at 9:20 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    i seen that the CB bumper shims move forward the front bumpers 1/2 - 1”. Anyone in here have experience with them and can tell me about it?
    thanks
  2. Aug 8, 2020 at 9:24 PM
    They will move it up to 1/2 inch. 1 inch would run out of threads. You can use washers and it would be alot cheaper.
    Henry2019[QUOTED][OP] likes this.
  3. Aug 8, 2020 at 9:32 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    ordered from ekstrom design. included 4 pieces of 1/4" shims. i installed 2 on each side for a total of 1/2"
    unsure where you seeing anything more than 1/2". maybe 2 kits ordered and 4 shims installed each side?
    that'd give you 1". there's PLENTY of bumper mount stud to move it forward 1". but, you'd have to order TWO sets of shims.
    EDITED: See my post below; no way to get anymore than 1/2".
    Henry2019[OP] likes this.
  4. Aug 8, 2020 at 9:40 PM
    There is now way you can shim up to 1 inch on these mounts. These washers are exactly 1/2 inch. There is not enough threads left for 1 inch.
  5. Aug 8, 2020 at 10:28 PM
    Toytec has their shims which are a little cheaper.
  6. Aug 9, 2020 at 9:23 AM
    shackleford rusty
    TEXAS!
    tundra234 is absolutely correct. no way to get 1". pic below of my setup. unsure why i misremembered those studs being so long; maybe lack of space and it seemed like it took a while to remove each nut.
    apologies for the misinformation in prior post.
    @Tundra234 - you're at a total of 3/4"? 1/2" washers + 1/4" shim? NEVERMIND... i see what you did. you're a total of 1/2" using washers only.
  7. Aug 9, 2020 at 9:34 AM
    Yes, I did washers only until I order shims. I had to shim forward due to the bumper that I am using.
