Damn just caught the catch latch in time!
Discussion in '2.5 Gen Tundras (2014-2021)' started by NoRcptn, Aug 7, 2020.
  1. Aug 7, 2020 at 1:20 PM
    NoRcptn
    NoRcptn [OP] Better than mediocre poster
    NorCal
    2017 Platinum
    2FCEF6EC-F8D6-4D08-8531-68B86D9B09E4.jpg I noticed a popping sound when I opened my drivers door. I thought maybe dry/dust needs grease. Upon further inspection the catch latch was broken at the swivel pin on the body side mount. I have a steep driveway and had issues in the past with kids and doors flying open. Parking uphill crushed a kids leg. So parking downhill is safer but comes with consequences. Even though I’ve been ginger on my door, the weight alone was enough to destroy the door mount side backing.
    On my 04, my hinge literally ripped out of the door.
    Anyway, 132.00 later for that dang part I replaced the 17’s catch. Be aware if the door doesn’t sound right, is creaking or popping at all. It’s absolutely quiet now.
    Tundra Fan and Wynnded like this.
  2. Aug 7, 2020 at 1:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Not good
  3. Aug 7, 2020 at 1:37 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Part number? I've been putting it off
    Did you do both?
  4. Aug 7, 2020 at 1:44 PM
    NoRcptn
    NorCal
    2017 Platinum
    No just drivers side. Others ones look ok so far and get 90% less use. I’m sure at some point I’ll have to.
    I’ll have to dig the part number out of the trash. I’ll update later today when back home.
  5. Aug 7, 2020 at 1:52 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Don't dig the trash, I was just being lazy
  6. Aug 7, 2020 at 1:56 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Was is easy to change?
  7. Aug 7, 2020 at 4:47 PM
    NoRcptn
    NorCal
    2017 Platinum
    Super simple. Had to take off door panel but A1 auto has a great video on how to do it. 3 bolts, 10mm, screwdriver and plastic pry tool. Total job was about 10 minutes.
  8. Aug 7, 2020 at 4:48 PM
    NoRcptn
    NorCal
    2017 Platinum
    Ruggybuggy likes this.
  9. Aug 8, 2020 at 7:06 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Plastic!
  10. Aug 8, 2020 at 7:45 PM
    NoRcptn
    NorCal
    2017 Platinum
    I thought the same thing but then realized without some give it would probably just fatigue the metal and rip.
  11. Aug 8, 2020 at 7:51 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Be sure to use a spray lube on the pin occasionally. The pin wears and you will also get the popping noise. Add some to the hinges while your there.
    NoRcptn[OP] likes this.
  12. Aug 8, 2020 at 8:43 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Mine was popping a while ago also. I noticed it was cracked just like yours. Since my front passenger door lock was also out, I took it to Carmax and both were covered under warranty. :yes:
  13. Aug 8, 2020 at 9:02 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    It’s called a “door check”. I replaced mine in my drivers door as I had let it swing open too many times and it was popping. So annoying.
