Idea for missing trans cooler on '19+
Discussion in 'Towing & Hauling' started by Dragracer_Art, Aug 3, 2020.
  1. Aug 3, 2020 at 5:26 AM
    Dragracer_Art
    Dragracer_Art [OP] New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Seems this would be a good opportunity for an aftermarket vendor to mfg a block of aluminum to replace the missing trans thermostat housing.
    Instead of having to source a factory T-stat housing, steel lines, etc... I would be interested in running a billet block with pipe/AN fitting so I could run steel braided lines and AN hose ends to an aftermarket cooler in front of the radiator.
    I cant imagine it would be all that difficult to make out of a thick block of aluminum... as the T-stat isnt even needed.
    Anyone listening ? :yes:
    CavalryCrew602 likes this.
  2. Aug 4, 2020 at 9:13 PM
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
  3. Aug 8, 2020 at 9:07 AM
    Pappion
    Pappion New Member
    Trany is cooled by coolant taken from same point as the cabin heater hose. Issue is it's already 180f. Cool that 40f and your good to go. Maybe splicing a trans cooler in that coolant (hose) line will do the trick. A TSTAT bypass would nice for cold weather.
  4. Aug 8, 2020 at 10:59 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I already started gathering parts...
    Allrsdup likes this.
  5. Aug 8, 2020 at 11:29 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The top pic is the thermostat for 19 and 20's, not sure what the bottom two are but they aren't needed for this install.
  6. Aug 8, 2020 at 11:34 AM
    Allrsdup
    Allrsdup New Member
    Joe
    its the same part lol
    bottom pics are the back side of it haha
    Dragracer_Art[OP] likes this.
  7. Aug 8, 2020 at 11:42 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I see, the top pic looks like the tstat i used but that one won't work on a 19 or 20.
  8. Aug 8, 2020 at 11:44 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    It's not like the one I used, the orings weren't like that one.
  9. Aug 8, 2020 at 11:45 AM
    Allrsdup
    Allrsdup New Member
    Joe
    oh i see what your saying, i thought you meant cant retrofit. yea it does look different.
  10. Aug 8, 2020 at 11:48 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Well good luck hope it works out for you.
  11. Aug 8, 2020 at 12:35 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I split it in half.
    its the two components making up the one part.
    Allrsdup and sask3m like this.
