Window problem
Discussion in '1st Gen Tundras (2000-2006)' started by Ruscob, Aug 7, 2020.
  1. Aug 7, 2020 at 1:00 PM
    Ruscob
    Ruscob [OP] New Member
    2006 Toyota Tundra ext cab
    I have a 2006 Tundra:
    On drivers door, the only window button that works is drivers window button. All other three window buttons and door lock buttons do not work. Passenger window button works on passenger door but lock button doesn’t work. Rear window buttons work on each door. As I shut the drivers door the locks make two clicks unlocking or locking can’t tell, just makes couple clicks and nothing happens. I’m lost..
  2. Aug 7, 2020 at 2:41 PM
    shifty` Ten EV 12's so you know I raise hell
    First thing to clarify, which is clearly written in the manual and the first place to look for operational questions, does anything change when you press this button, which is used to lock out every window except the driver's window from rolling up/down?
