Windshield Cowel
Discussion in '2nd Gen Tundras (2007-2013)' started by Zimms, Aug 5, 2020.
  1. Aug 5, 2020 at 1:06 PM
    Zimms
    Zimms [OP] I suggest you let that one marinate.
    Ben
    Wisconsin
    2012 Black Tundra Platinum
    I noticed the other day that my windshield Cowel is sunken in. Is this a normal issue for these trucks? Should I just replace it or should I take it off and try to force it back into position? Any thoughts would help.
  2. Aug 5, 2020 at 3:07 PM
    BLACKOUTUNDRA
    BLACKOUTUNDRA New Member
    Austin
    2014 Black Tundra Platinum
    Take a heat gun or a hair dryer and heat it a bit then push it out to line up again
  3. Aug 5, 2020 at 3:09 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did you have your windshield replaced recently? Maybe they caused it?
  4. Aug 6, 2020 at 7:09 AM
    Zimms
    Ben
    Wisconsin
    I can definitely try that.
  5. Aug 6, 2020 at 7:10 AM
    Zimms
    Ben
    Wisconsin
    I just bought this truck about 2 months ago and noticed this while I was washing it. I think it's the original windshield, but not positive.
  6. Aug 6, 2020 at 9:15 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    I wouldn't be surprised if the truck took a bird hit in that area, which pushed the cowl in. You may have to remove the cowl and straighten it and then reinstall.
  7. Aug 7, 2020 at 7:53 AM
    Zimms
    Ben
    Wisconsin
    Well I took the Cowel off. It was slightly bent from it sitting that way for so long. I took a hair dryer and and pushed it back to form a couple times. Then heated it again and reinstalled it. Looks pretty good if you ask me.
