2020 Tundra - How to Turn Off Headlights with Engine Running
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnny_B500, Aug 4, 2020.
  1. Aug 5, 2020 at 3:32 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Get one of these and stick it on top of the sensor.
    https://www.amazon.com/dp/B01CGW34R0/ref=cm_sw_em_r_mt_dp_LnZkFbTFPC97F
  2. Jul 6, 2021 at 10:12 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Feature I learned with my new Canadian Tundra:
    The socialist Canadian government doesn't let me decide if I want my headlights on.... I guess they think we're too dumb up here to decide when to turn the headlights on/off. I'm so glad our government is caring for us in everything we do (sarcasm).
  3. Jul 6, 2021 at 10:26 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Can't really blame them when you see every second gen driving around with only the front park lights on in the dead of night.
    Wynnded and HARPER306 like this.
  4. Jul 6, 2021 at 10:33 AM
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    What a dumb take. They made drls mandatory cause idiots kept driving at night or low light conditions with their lights off. They see the dashboard lit up and good enough
    CMikeB, Wynnded and Cpl_Punishment like this.
  5. Jul 6, 2021 at 11:40 AM
    coldcanuk
    Not talking DRLs.........As said in my quote I have no control over keeping my headlights off. Nothing to do with DRL. Hope that helps.
  6. Jul 6, 2021 at 12:09 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Buy a headlight switch from USA
    coldcanuk likes this.
  7. Jul 6, 2021 at 1:35 PM
    HARPER306
    SK, Canada
    Regardless, why would you ever need the lights off aside from specific usage scenarios?
    Cpl_Punishment likes this.
  8. Jul 6, 2021 at 2:04 PM
    GatorBodine
    GatorBodine New Member
    Auto headlamps are stupid. I see so many vehicles going down the road at night and you can tell they are the using the auto feature because the tail lights aren’t illuminated. If the vehicle is gonna automatically turn headlights on, then turn the taillights on too.
    CMikeB and coldcanuk like this.
  9. Jul 6, 2021 at 2:13 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That tells me they're running on DRLs, not auto headlights...
  10. Jul 6, 2021 at 2:13 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Uhh... what? What auto headlight feature are you talking about? Is this a Canada only thing?
    The auto headlight turns all front and back lights on for road safety.
    omgboost and Cpl_Punishment like this.
  11. Jul 6, 2021 at 2:43 PM
    HARPER306
    SK, Canada
    There are always drl on in Canada. The auto function does turn on both fronts and rears once low light conditions are detected, however not all vehicles have it
  12. Jul 6, 2021 at 2:57 PM
    g6t9ed
    Right, but the person I quoted stated the auto function would not turn on rears. I'm trying to figure out if they understand how the function works and why they think the rears would not turn on.
  13. Jul 6, 2021 at 3:50 PM
    GatorBodine
    Not a Canada thing. Some vehicles taillights don’t come on when the auto headlights function is enabled. I assume the Tundras taillights come on but I haven’t actually checked yet.
  14. Jul 6, 2021 at 3:53 PM
    GatorBodine
    Maybe so but never appeared that way to me.
  15. Jul 6, 2021 at 4:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just guessing here: Canada may require that the actual headlamp bulbs be illuminated, but at a lesser wattage; possibly 40W. The amber DRLs that we see on U.S. destination vehicles may not comply with Canadian regulations. This would be when the engine is running with the headlamp switch in either Off or Auto. If in Auto, when the ambient light threshold drops to a particular level, all exterior lamps illuminate to standard brightness.
    The derps that we see driving at night with the headlamps only illuminated and not the tail lamps have the switch in the Off position but may believe that everything is okay based on the minimal forward illumination and that the dash lights are backlit at all times as they are in the 2nd Gen Tundras.
    GatorBodine and Cpl_Punishment like this.
  16. Jul 7, 2021 at 9:26 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Wynnded is correct. Before the era of LED DRL the headlamps were the DRL in Canada. The bulbs were illuminated at a lesser power compared to full on headlights (wattage I am not sure).
    I have never heard of nor seen Auto headlamp systems that do not turn on all of the illumination associated (marker lights, tail lights, etc) once the ambient light threshold is reached. Wouldn't be a very good feature if that was the case.
  17. Jul 8, 2021 at 11:23 AM
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    Wynnded[QUOTED] likes this.
  18. Oct 2, 2021 at 5:02 PM
    Firetech5224
    Firetech5224 New Member
    2020 Tacoma
    Turn the headlight switch from AUTO to the MARKER LIGHTS then turn your parking brake on and shut your truck off and turn it back on. Headlights will stay off.
    Tundra family likes this.
  19. Nov 30, 2024 at 11:58 PM
    uktKFzzzvxWx
    uktKFzzzvxWx New Member
    Late to the party, but I've figured out a solution.
    I unplugged the light sensor, after that the "auto" position basically functions as lights "off". Oc DRL still comes on when driving for a canadian truck but at least the parking brake trick works now.
    Tested on my 2024 tundra
  20. Dec 1, 2024 at 5:41 AM
    #50
    CMikeB
    CMikeB New Member
    Back in prehistoric times, we used to be able to turn the silly auto headlights/ DRL's off by just clicking the Park Brake on just enough. Always worked for those who were actually considerate enough to turn lights off, while on the ramp, launching or taking up their boat. Everyone else just turned headlights off and used Park Lights....(for one of their intended purposes)
  21. Dec 1, 2024 at 6:07 AM
    #51
    Tundra family
    Tundra family New Member
    Makes me miss the good ol days when you knew the lights were off because the dash was dark as sin.
    CMikeB likes this.
  22. Dec 1, 2024 at 8:39 AM
    #52
    CMikeB
    CMikeB New Member
    That was back before we needed everything done for us. When we couldn't see the dash, WE turned lights on so we could. By doing so, we could also be seen by others!
