Ideal Alignment Specs?
Discussion in 'Suspension' started by Tundrafan23, Aug 2, 2020.
  1. Aug 2, 2020 at 2:08 PM
    Tundrafan23
    Tundrafan23 [OP] New Member
    I have a 2020 Crew Max Platinum with a 6112/5160 combo set at 1.9 (2 driver shims and 1 passenger) with a CB +3 shackle, 18x9+25 Ray 10s, and 295/70r18 Ridge Grapplers. What are the ideal alignment specs I should be aiming for? Thanks for any help.
  2. Aug 2, 2020 at 7:03 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    here's my sheet.
    running 3/1 readylift on 295/60/20 toyo at2's. factory wheels. stock uca's.
    not sure it can get much tighter with stock uca's. it is recommended that your caster be closer to 3
    very happy w/ tire wear after 10k + miles.
  3. Aug 2, 2020 at 7:05 PM
    Kanobi13
    Kanobi13 New Member
    Any pics want to run the 295 same front level as you and CB plus 3
  4. Aug 2, 2020 at 7:08 PM
    shackleford rusty
    TEXAS!
  5. Aug 2, 2020 at 7:41 PM
    Tundrafan23
    I will take some when I get it back from getting alignment done, I have a camper top on the bed that weighs close to 600 lbs so I don't know if that will help you because that squats the back end a little.
    hatchboi likes this.
  6. Aug 2, 2020 at 7:45 PM
    Kanobi13
    Kanobi13 New Member
  7. Aug 5, 2020 at 7:35 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    This is pretty much what my alignment specs were with 295's on an OME 2.5" lift, factory wheels, stock UCAs. Drives great. It is definitely the upper limit of caster adjustment on stock UCAs.
  8. Aug 5, 2020 at 8:16 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Yep
