Best offset to run 35x12.5r20’s on 3 inch lift
Discussion in 'Wheels & Tires' started by gcolen47, Aug 4, 2020.
  1. Aug 4, 2020 at 7:26 AM
    gcolen47
    gcolen47 [OP] New Member
    Garrett
    2020 White Tundra Crewmax TRD Off Road
    Hey everybody, looking at getting a 3 inch toytec boss suspension lift and some 20x9 Hostile Alphas and 35x12.50r20 Nitto Ridge Grapplers. My question is what offset should I get the wheels to minimize the amount of rubbing I’m going to have? They offer it in 0 offset or +12 offset. Coming from Tacoma’s I’m used to a little negative offset being a good thing but from some of my research it’s looking like a little positive offset may be good on the tundras. Just looking for some feedback. Thanks
  2. Aug 4, 2020 at 7:34 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Everything I've read on here has led me to believe +18 to +25 is the sweet spot on our Tundras.
    I think the stock wheels are around +60 but cause upper A-arm interference with 35's.
    I just got a set of 18x9 Methods in +25 and will have them on by end of week.
    Lift is 3" and tires are 35x12.5/18 Terra Grapplers so it should be a pretty good example.
    Bob_Wiley and Netmonkey like this.
  3. Aug 4, 2020 at 8:03 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    ^ yup.. +18 to +25
  4. Aug 4, 2020 at 8:36 AM
    gcolen47
    Garrett
    That’s most of what I’ve been seeing. I’ll probably go with the +12 to give me a little less cutting/trimming hopefully than the 0 offset
  5. Aug 4, 2020 at 8:49 AM
    Tundrafan23
    Tundrafan23 New Member
    You are going to need a BMC to fit 35x12.5r20 regardless of what offset you run, but the consensus is that +25 is a sweet spot for minimal cutting.
  6. Aug 4, 2020 at 10:27 AM
    Netmonkey
    Georgetown, TX
    Not necessarily.
    I have 34" tires and 20x9 +20mm offset wheels and there is an inch of clearance to the body mount. I could easily fit 35's without cutting it:
    TRDblvd likes this.
  7. Aug 4, 2020 at 11:18 AM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    agreed, I run 35x12.50 on my stock pro wheels, about a +28 offset with my spidertrax wheel spacers. No BMC, but run an aftermarket bumper. If you rub on the front bumper nothing a little massaging or bumper shims can’t fix.
    Bob_Wiley and Netmonkey[QUOTED] like this.
