Waiting 500 miles before towing?
Discussion in 'Towing & Hauling' started by Alloutdrs1, Feb 23, 2017.
  1. Feb 23, 2017 at 7:23 AM
    Alloutdrs1
    Alloutdrs1 [OP] New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    What do you guys think about towing with a new tundra? I'm not talking a heavy load, about 1700lbs. I have been searching for a new tundra and just so happens I found one back in PA where my family lives. I'm heading up there this weekend with my utility trailer to deliver some things to my aunt. So if I get the truck I would be hauling back just the trailer itself with an empty weight of 1700lbs for 400 miles, first 100 will be up over the mountains. Thoughts?
  2. Feb 23, 2017 at 7:28 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    The 500 mile break in is for the differential gears. First 500 is very critical to not overheat or you will bake the gears and you will get the notorious gear howl under load.
    Having baked more than one set of gears in my life, I would absolutely not recommend towing within the first 500 or even driving a distance longer than 100 miles at a time. Let those gears cool.
    ColoradoTJ likes this.
  3. Feb 23, 2017 at 7:31 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
  4. Feb 23, 2017 at 7:58 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I figured as much, I was just looking at the fact I towed right away when I bought my 14' silverado and havent had an issue. Wasn't sure if the tundra rear end would have an issue. To be honest Even if I bought one at home I don't know if I could go 500 miles before towing. I own my buisness and pull a trailer everyday.
  5. Feb 23, 2017 at 8:06 AM
    I agree with the above posts. Toyota is actually pretty easy for the break in requirements.
    My current truck was no towing and no speed over 55 mph for the first 500 miles. Then the requirements for towing is the next 500 miles is towing at no speeds over 50mph. That sucked, but I did it.
    Y0TA PR0 likes this.
  6. Feb 23, 2017 at 8:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I bought an F150 once and just took it for a couple of drives to break in because I wanted to fish that next weekend. I would not tow before 500 miles but you could if air temps are low, kept speed down, and made several stops to let gears cool.
  7. Feb 23, 2017 at 12:53 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Look at it this way; possibly nothing goes wrong and you're golden, but if you do cause yourself a problem down the road, will you feel like the risk was a good idea? Just another worthless.02
  8. Feb 23, 2017 at 7:27 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    So many what-if's to proper break-in, heck my father bought a 1988 corolla new and it spent its first 7000 miles on the highway traveling back and forth from PA to VA and don't get an oil change until 7500. Sounds crazy and goes against everything break in calls for but that car went 335,000 miles for him without any issue, best car he has ever owned reliability wise.
    I have to take a washer/dryer set and a Tacoma bed cap up there, I think I will try to make it fit in my truck bed and leave the trailer at home. The deal on this truck is good and I don't want to pass up. Make it work out so I wont have to bring a trailer home, she can have 400 easy miles first.
