  1. Aug 1, 2020 at 9:37 PM
    #6481
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Ditto
    [​IMG] She’s going to roll for the first time in years tomorrow
  2. Aug 1, 2020 at 10:36 PM
    #6482
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    They are. In my blue bug I used to run a single 15 in a sealed box with an old Punch amp. Not a single rattle but it rattled house windows from the street. I later switched to a single 12 and an 800 watt Kenwood amp that seriously felt like a concert.
    Now I'm married and I'm considering what I'll build for it. I have an old Type R 12, could use that. Might go a different route and build a deck with four 6.5s and a pair of 8s beneath it. Who knows, i just wanna drive them again.
  3. Aug 1, 2020 at 10:41 PM
    #6483
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats looking beautiful. Whats up with the extra u bolts? Whats the plan for rear brakes?
  4. Aug 2, 2020 at 3:04 AM
    #6484
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Where once there was darkness there is now light.
  5. Aug 2, 2020 at 3:14 AM
    #6485
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here goes nothing...
    Flex seal under heat shrink. Turns out flex seal is flammable :rolleyes:
  6. Aug 2, 2020 at 4:40 AM
    #6486
    empty_lord
    05 rollover special
    I had oem and the ones that came with the deavers. I didn’t like how far the deaver ones stuck down, the oems tightened up and have full thread engagement so I’m happier with those.
    rear brakes will be 2014 fj pads rotors and calipers with a working parking brake. Front brakes are tundra brakes. It’ll be running a sequoia master cylinder with the SOS adapter
  7. Aug 2, 2020 at 6:25 AM
    #6487
    Professional Hand Model
    Fred
    Hand Protectors
    Spray it on the tires and then wipe it in. If they are thirsty, then maybe do two applications back to back. The 303 goes a long way as you’ll find out. You only need a little.
    For interior applications, I recco spraying it on a microfiber and then wipe it on. Helps save on the product and from getting on your windshield glass.
    bmf4069 likes this.
  8. Aug 2, 2020 at 6:54 AM
    #6488
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Haven't quite figured out a good switch location, but I'm working on it.
    Hard part is done!
    Tedious work, but worth it. 4.25 hours with breaks included.
  9. Aug 2, 2020 at 8:41 AM
    #6489
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Aug 2, 2020 at 8:46 AM
    #6490
    Keep an eye on those sticky blocks that you zip tied to. I did something similar inside my work van for late night on call action(I know I usually take the truck, but it was fun to do) and I used those stickies to hold some of the wires up, and they fell down after a while. I even cleaned the surfaces w IPA.
    I know you’ve already got your toggle switch mounted, but you could also look for a hood switch, like they use for car alarms, that makes or breaks the circuit when you open the hood. You could then wire your switch as a kill switch if you didn’t want it automatically on when you opened the hood.
  11. Aug 2, 2020 at 8:56 AM
    #6491
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thats a bummer to hear because I'd bet mine will do the same. Cleaned surfaces with IPA, and applied small doses of adhesion promoter.
    I was looking around for a tilt switch, but didn't think about a hood switch. Neat idea!
    I figured a toggle would be easy enough to replace if I ever have to.
  12. Aug 2, 2020 at 8:59 AM
    #6492
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mounted the light strip in front of the hood weatherstrip. I was gling to mount it behind it in the green location.
    Heres my thoughts on that.
    I figure if I'm trucking along and the front light strip decides to come loose for some weird reason that the weatherstrip, and the radiator will keep the light from getting in my fan.
    Already did a little test drive. Putting around real easy. Nothing came loose. Not even a little.
  13. Aug 2, 2020 at 9:02 AM
    #6493
    @empty_lord or anyone else.
    Is this a safe jack point on our Rav4? Looked everywhere in the manual and can't find an answer. This runs horizontally across the front below the radiator.
    2 more run length wise down the sides.
  14. Aug 2, 2020 at 9:08 AM
    #6494
    Fred
    Hand Protectors
    Fuzeit around those stickys as soon as you can. Load them up around the four sides with a nice bead and they’ll never go anywhere. Just keep them up and caulk around them. No need to remove.
    Tundra2[QUOTED] likes this.
  15. Aug 2, 2020 at 9:15 AM
    #6495
    empty_lord
    05 rollover special
    The front should be fine. It’s reinforced there to do it
    The side ones are a big NO
  16. Aug 2, 2020 at 9:23 AM
    #6496
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Anyone have recommended toe specs for out trucks? According to my cowboy measurements I have .5x degrees of toe in right now.
  17. Aug 2, 2020 at 9:37 AM
    #6497
    Fred
    Hand Protectors
    NUDRAT[OP] and lsaami[QUOTED] like this.
  18. Aug 2, 2020 at 10:02 AM
    #6498
    empty_lord
    05 rollover special
    I finally have a roller!
  19. Aug 2, 2020 at 1:41 PM
    #6499
    Fred
    Hand Protectors
    Opinion: Worth trying to fix a Tundra 4.7L with a broken timing belt? Or, is it even possible?
  20. Aug 2, 2020 at 2:02 PM
    #6500
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Wow, that's bad news.:eek: You put so much effort into your truck. What happened?
  21. Aug 2, 2020 at 2:08 PM
    #6501
    empty_lord
    05 rollover special
    New engine
  22. Aug 2, 2020 at 2:08 PM
    #6502
    empty_lord
    05 rollover special
    Did yours let go?
  23. Aug 2, 2020 at 2:08 PM
    #6503
    Fred
    Hand Protectors
    Nothing to my truck. Was just asking about another truck I saw for sale with a blown belt.
    Darkness likes this.
  24. Aug 2, 2020 at 2:09 PM
    #6504
    empty_lord
    05 rollover special
    If it did the warranty on the belt might help..
  25. Aug 2, 2020 at 2:11 PM
    #6505
    Fred
    Hand Protectors
    I’ve got 2 more years ‘left’ on my belt. Was replaced in 2012 at 110k miles. Sitting at 171k now.
    Dog likes this.
  26. Aug 2, 2020 at 2:19 PM
    #6506
    I think 17 people almost pooped themselves over your post about the t belt!
    bmf4069, Darkness, NUDRAT[OP] and 3 others like this.
  27. Aug 2, 2020 at 2:28 PM
    #6507
    Fred
    Hand Protectors
    I hope it never happens to anyone. The truck I saw had 400k miles on it and is selling ‘fairly’ cheap. They probably let it go too long? Was just curious if they can be brought back from the dead.
  28. Aug 2, 2020 at 3:28 PM
    #6508
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Yes i did too lol, i was like "ooooo shieet"
    GODZILLA likes this.
  29. Aug 2, 2020 at 3:58 PM
    #6509
    Fred
    Hand Protectors
    Man its been slim pickings on Dreggsliss. Historically, there were a few 1st Gens a week rolling through and they’d last 2 weeks tops. Now its nothing but 1 dogged out piece of crap on there a week. Even the 2000-06 Soccer Mom Sequoia page is non-existent when there were 5-6 nice ones a week for cheap!
    Whats going on?
    Dog likes this.
  30. Aug 2, 2020 at 4:43 PM
    #6510
    empty_lord
    05 rollover special
    They can. With a used engine. For a fair price if the trucks clean it’s worth it
