VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 1, 2020 at 5:54 AM
    #4051
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Awesome. So the custom features are all available? Direct shift and gear lock?
  2. Aug 1, 2020 at 8:04 AM
    #4052
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Is this going to be the last revision we get? With all the features and adjustments we've requested in previous zendesk emails like tire size calibration or map switching?
    Vr0ck likes this.
  3. Aug 1, 2020 at 10:38 AM
    #4053
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    So it sounds to me like Direct Shift will make it a true manual. So for example, I have an AMG with 9 speed dual clutch transmission. When I put it in manual and use the steering paddles to shift, it will shift into whatever gear I want and it doesnt matter what I do with the throttle. I can bog it down full throttle at low RPMs or I can redline it until it bangs off the limiter.
    Is that how Direct Shift will work?
  4. Aug 1, 2020 at 10:39 AM
    #4054
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Also, when will we get VF Tuner available?? I have a 2013
    @OVTune
    MTRock likes this.
  5. Aug 1, 2020 at 10:54 AM
    #4055
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You got it. Gives you control over your transmission.
  6. Aug 1, 2020 at 11:01 AM
    #4056
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'd like to hear from Mat about this since this is very confusing.
    I have some friends who think it will still downshift based on his earlier descriptions.
    If it truly stays in whatever gear you select, then how is it different from Gearlock? (question for Mat)
  7. Aug 1, 2020 at 11:17 AM
    #4057
    helidave
    flagstaff
    2015 DC 4x4
    If you want it to be like your AMG, you need both gearlock and direct shift. Direct shift to change gear when you shift, gearlock to hold the selected gear. simple
  8. Aug 1, 2020 at 11:19 AM
    #4058
    osidepunker
    Alex
    2013 Tundra DC 4x4
    haha well sounds like both on the same tune is not an option
  9. Aug 1, 2020 at 11:22 AM
    #4059
    helidave
    flagstaff
    2015 DC 4x4
    Not sure why you'd think that. I requested both, as have several other people on this thread. I've never seen Mat say it was one or the other.
    HulkSmurf14 and shellshock like this.
  10. Aug 1, 2020 at 11:24 AM
    #4060
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well I requested both. Not sure why you think it would be both on the same tune. I'm expecting two different tunes
  11. Aug 1, 2020 at 11:36 AM
    #4061
    helidave
    flagstaff
    2015 DC 4x4
    I thought you were talking about both on the same tune because you said "sounds like both on the same tune is not an option".
    The two features work together to give you maximum control over the transmission. That's the whole point.
  12. Aug 1, 2020 at 11:45 AM
    #4062
    osidepunker
    Alex
    2013 Tundra DC 4x4
    well if thats true, that would be great. One tune, put it in S mode, it shifts to whatever gear you select and it stays in that gear no matter what.
    It would be super cool if Mat would just come out and say, "yes. thats how it works"
    helidave[QUOTED] likes this.
  13. Aug 1, 2020 at 1:06 PM
    #4063
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    That is the plan, yes and what I am working on right now.
    Just to let you guys know, I won't be able to get EVERYONEs file to them today. I have to account for all logs, requests, and make those adjustments + the features on top into a new file.
    that's 100% how it works yes.
    I have your file ready to go, emailing it to you in 15, so test it out and you'll see !
    Stroke250 and HulkSmurf14 like this.
  14. Aug 1, 2020 at 1:23 PM
    #4064
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Great thanks Mat!
  15. Aug 1, 2020 at 1:35 PM
    #4065
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    users with 0CJ64
    users with 0CL42.
    users with 0CM21.
    users with 0CM51.
    users with 0CN21.
    Gearlock/Direct shift / updates sent.
    check this same post, I'll continually edit it as more are sent.
    Stroke250, LifeCycle, Vr0ck and 3 others like this.
  16. Aug 1, 2020 at 2:31 PM
    #4066
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Mat what other features will be included in these updates besides the gearlock and direct shift? Or is it more less implementing all the latest refinements to the overall tune?
  17. Aug 1, 2020 at 2:33 PM
    #4067
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    it is implementing everything we have been working on since January into everyones tunes.
    I don't have additional features scheduled after this.
  18. Aug 1, 2020 at 4:31 PM
    #4068
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    FYI for 2019s ECU ID 0CP50 / 0CP71/81
    We plan to release this as a vF Tuner update next week.
    Sending out 0CN21 / 2018 as that is a massive amount of our user base, please be patient as we send them now
    TruckyTruck and Stroke250 like this.
  19. Aug 1, 2020 at 5:24 PM
    #4069
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Are we supposed to email you to get an update, or will you update everyone regardless? Just want to clarify before I clog your inbox...
  20. Aug 1, 2020 at 5:31 PM
    #4070
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Do you have an open ticket and receive and email?
  21. Aug 1, 2020 at 5:53 PM
    #4071
    snivilous
    SW UT
    I don't think so? I have a ticket that's my previous tune iterations but it's not like I'm waiting to hear back or it's "active". And since he's saying he's releasing tunes for XXXX ECU every couple hours that's why I wasn't sure if I should ping him or just wait a few days.
  22. Aug 1, 2020 at 6:03 PM
    #4072
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    As I understand it, Mat was going to email those with open tickets. I suppose that you could still email him to see what he says and maybe he'll add you to the list, what's one more email among the thousands they get? lol As usual, include you ticket number and probably your ECU version in the subject line to increase efficiency. It looks to me like all the ECUs that he's listed at this time are N/A tunes. It may be some time before he's able to get to S/C tunes like ours. The list so far looks alphabetical as well, so that may give a hint as to order/timeline.
    TruckyTruck likes this.
  23. Aug 1, 2020 at 6:45 PM
    #4073
    TruckyTruck
    Gary
    Everytime my phone dings, I think its my update! :laugh:
    shellshock likes this.
  24. Aug 1, 2020 at 6:57 PM
    #4074
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oh hohoho....shouldn't have said that out loud, I'm going to PM you til the early morning hours. :boink:
    TruckyTruck[QUOTED] likes this.
  25. Aug 1, 2020 at 6:58 PM
    #4075
    TruckyTruck
    Gary
    Haha ding, ding, ding
  26. Aug 2, 2020 at 7:57 AM
    #4076
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Out of the ones we have sent, has anyone flashed and tested yet?
  27. Aug 2, 2020 at 7:59 AM
    #4077
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Will be trying it shortly.
    Wynnded likes this.
  28. Aug 2, 2020 at 10:36 AM
    #4078
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    More files are being released today, and we expect vF Tuner to have 07-17 support for Tundras by mid august.
    Then, anyone who wants vF Tuner + our tunes, are welcome to. (all years 07-19)
  29. Aug 2, 2020 at 10:43 AM
    #4079
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This. :yay:
    Tundra files are still .p5f, not .vft?
  30. Aug 2, 2020 at 12:17 PM
    #4080
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    :yes:
Thread Status:
