Loctite?
Discussion in 'Suspension' started by NoCoToyo, Jul 30, 2020.
  1. Jul 30, 2020 at 6:20 PM
    NoCoToyo
    NoCoToyo [OP] New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Prepping to install my lift.
    Loctite on any of the components?
    Elduder likes this.
  2. Jul 30, 2020 at 7:25 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I use blue loctite on most everything that isn't a normal maintenance nut/bolt.
    Elduder and TheBeast like this.
  3. Jul 31, 2020 at 1:39 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    NO loctite. Maybe some anti-seize on shock bolts.
    Sundown5oh likes this.
  4. Jul 31, 2020 at 3:06 PM
    NoCoToyo
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Thanks!
  5. Jul 31, 2020 at 3:11 PM
    Elduder
    Elduder New Member
    No issues here with years of using Loctite blue on suspension components. I use anti seize on soft material fasteners like plugs. Both have their benefits, best bet is to take a paint pen and run a quick line on the nut to mounting surfaces, then you can visibly identify if the fastener is loosening.
