Trail Tool Kit
Discussion in 'Recovery & Gear' started by NickDPT, Jul 31, 2020.
  1. Jul 31, 2020 at 7:22 AM
    NickDPT
    NickDPT [OP] New Member
    SoCal and DTX
    2020 White 1794 4x4 TRD
    Bilstein 6112/5160 set at 2.5 OME Dakar leaf springs Built Right UCA Falken Wildpeak AT3W 285/75/18 Decked drawer system Front Runner overbed rack Rago dash plate for RAM radio and phone mounts
    Hey All,
    Almost a new 2020 Tundra 4x4 owner, hopefully next week. Wondering what everyone carries in their trail tool kit? Mostly wondering about socket sizes, wrenches that everyone finds most useful? Thanks everyone.
    Backslider likes this.
  2. Jul 31, 2020 at 7:37 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Here's what I picked up from Amazon. I don't venture too far off the beaten path yet and haven't had to use any of it but should have what I need for most basic field repair needs.
    Bag: https://www.amazon.com/gp/product/B0109O0C1I/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Cable Ties: https://www.amazon.com/gp/product/B0777LWBD9/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    For hitting stuff: https://www.amazon.com/gp/product/B01N6E0HEI/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Also for hitting stuff: https://www.amazon.com/gp/product/B06XKBXHQP/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    Pliers & Cutters: https://www.amazon.com/gp/product/B004I41YOK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    Ratchets: https://www.amazon.com/gp/product/B07SXC6YKY/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Socket Set: https://www.amazon.com/gp/product/B07G24B54N/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Hex key set as well but can't seem to find the Amazon link.
    This is in addition to tire repair kit, fuses, spare relays, gorilla tape, etc which are in the truck but not in the tool kit. Need to add some electronic/electrical basics to the tool kit as well such as multimeter, test light, wiring, connectors, etc as well as some JB Weld.
    Leo's first, NickDPT[OP] and Sunnier like this.
  3. Jul 31, 2020 at 7:42 AM
    Kanobi13
    Kanobi13 New Member
    Either replace jack or carry a block to help replacing tire.
  4. Jul 31, 2020 at 7:48 AM
    java230
    java230 New Member
    Make sure you have 19 and 22mm sockets in whatever kit you get. Many stop at 17.
  5. Jul 31, 2020 at 7:50 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Block for my jack, tow strap, recovery strap, 2lb hammer, shackles, small shovel. If i go offroad i also bring my Dewalt 1/2" impact with me along with an impact socket set from 10-22mm. Don't like to leave that in the truck otherwise. Want to get some traction boards as well.
  6. Jul 31, 2020 at 8:18 AM
    Welcome from NY.
  7. Jul 31, 2020 at 8:31 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    People will knock Harbor Freight, but for trail tools their stuff is more than adequate. Plus, most of the hand tools come with a lifetime warranty. Only had one T-25 Allen key break on me because I had an 18” cheater pipe on it.
    For what to carry, Ronny’s toolkit is quite thorough and boardline mobile mechanic status. Good tips in it though like only bringing regular wrenches because of the low profile head:
    https://youtu.be/oTDLb4oNO4c
    RRR1C0, chugs, NickDPT[OP] and 2 others like this.
  8. Jul 31, 2020 at 8:38 AM
    Marty McFly
    Morty McBoonJug
    Low profile head is always good :laughing:
  9. Jul 31, 2020 at 8:40 AM
    300BLK
    300BLK New Member
    All my impact sockets are HF, along with some ratchets and my floor jack. I abuse them HARD and they have never failed. You just have to know what items to buy, namely the Taiwainese manufactured tools which are basically using the same factories as everyone else. That stuff is great. There's tons of reviews online. There's a lot of cheap garbage but the stuff they get right is unbeatable for the money. Only thing i avoid there are power tools, better off buying contractor grade name brand for the warranty and battery system.
  10. Jul 31, 2020 at 8:50 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    @300BLK. Exactly. Do your research on their tools and they should work out for you. I have their impacts too in my garage - solid. However, I keep a full set of deep tekton impacts in my truck because they don’t have any skips 10-22mm. So regular sockets 4-19mm and my deep impacts double-up duty as regular/impact. If there isn’t enough clearance because of the thick impact wall then I’ll put it as a loss and walk away. If clearances are that tight you’ll probably run into bigger issues thoughout the repair anyway
    300BLK likes this.
  11. Jul 31, 2020 at 8:51 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    A small saw or hatchet is handy for brush just in case you don’t like pinstripes
    NickDPT[OP], Mater and 300BLK like this.
  12. Aug 2, 2020 at 6:27 AM
    NickDPT
    SoCal and DTX
    This is all awesome. Thanks y’all!
    ToyoMafia likes this.
  13. Aug 27, 2020 at 5:47 AM
    DuneTransit
    DuneTransit New Member
    2007 Tundra CrewMax 4wd
    I keep a small med kit, long tow strap, 2x shackles, an OBD II scanner for pulling looking at any engine codes that may pop up, a small inverter for running tools, and ratchet straps. Bought some small nylon bags to keep everything organized and put away under the rear seats. Never know when you'll run into situations off the trail or on a road trip.
    On the trail, having a portable tool set with the rest of the stuff, including a breaker bar and other "methods of persuasion" is a must for the trail. Having a spare CV axle could make you a popular guy if you're running the hard stuff.
    equin likes this.
  14. Dec 30, 2020 at 9:39 AM
    Julyy45
    Julyy45 New Member
    Julio
    Atlanta GA
    2020 SR5 Cement CM. Offroad Pkg.
    Doing a bit of a revival to this thread here. I'm working on a trail tool kit myself and a lot of these are great mentions.
    I just purchased a DIY CO2 tank for filling tires. looking at a budget of about $250 for it all. I know a lot of people would suggest an onboard air system, but I been hesitant on the off brand ones and their reliability, or the time it takes to fill. ARB is great but its pretty pricey (atleast the Dual one). Power Tank is also pricey aswell for a tank, and this DIY option is half the cost.
    A 10lb CO2 tank is good for roughly filling 35's with 10psi 32 times, or 15psi 18 times. Not bad.
    I don't plan to hit the trails every weekend, but every now and then, so this makes a bit more sense for me. Plus fill ups take less than a minute per tire on average. So some trade offs, and some perks I suppose with this type of system, but its budget friendly none the less.
    Heres my build:
    10 lb tank - $100
    High Flow Regulator (475 PSI) - $80 + $13 S&H = $93
    25ft Recoil Hose (200PSI max rating) - $9*
    Couplers/Fittings = $10** (220PSI max rating) - $10
    Total: $222 ($212 if using HF replacements)
    * HF has the exact hose for $5
    ** HF also has coupler/fittings for half the cost of Amazon.
    Only thing I'm left with is a Bracket to mount this so its not moving around. Been looking at some Fire Extinguisher ones (Buckeye or Kidde), but if you have a recommendation, send it!
    ToyoD, equin and Terndrerrr like this.
  15. Dec 30, 2020 at 1:48 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Do you have a cost on refilling the bottle?
  16. Dec 30, 2020 at 1:51 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Here’s my humble submission. My “real” tools stay in the garage at home. Most of what you see here is from HF. BONUS: it all actually works. That old pair of Fleet pliers were handed down to me by my grandfather. They don’t deserve to be in the kit with the rest of this stuff, but I like taking them out on the trail with me.
    I will be upgrading the air compressor soon. Probably to the ARB twin since I’m running 35s.
    Sleeper16plat, ToyoD, WVI and 5 others like this.
  17. Dec 30, 2020 at 2:04 PM
    Julyy45
    Julyy45 New Member
    Julio
    Atlanta GA
    Local shop refills a 10lb tank for $15. Can typically range anywhere from $10-$30, but best to go to a fire extinguisher place or a local welding place.
  18. Dec 30, 2020 at 2:43 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    5D4D5A92-42A9-40A1-A18F-CAAC60DC6428.jpg Picked this up at Costco $90. Nice basic truck set but no larger sizes (fits under back seat)
    Jumper cables I’m still old school don’t have one of those fancy little Li-On jump packs yet
    20’ tow strap
    Bag of bungee cords and ratchet straps
    First aid kit
    Fold up military shovel (used more then expected)
    Need a new 10’ chain mine was lost/stolen
    I don’t off road but like to have the basics in case of emergency or to lend a helping hand
    WVI, USCG2005, Julyy45 and 1 other person like this.
  19. Mar 30, 2021 at 11:03 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
  20. Mar 30, 2021 at 11:26 AM
    Julyy45
    Julyy45 New Member
    Julio
    Atlanta GA
    WOW, thanks a million, this is exactly what I need. I never got around to getting or finding a mount holder, but this is exactly what I would need.
    pvn.beluga likes this.
  21. Apr 20, 2021 at 10:23 AM
    COElkHunter
    Jeremy
    Tool roll up and recovery kit. Also carry a Sven Saw, Estwing axe, 2 lb sledge, ball peen hammer, cable and zip ties, duct tape, tarp, extra bottle jack. These fit nicely in my Rigid toolboxes on the roof.
    USCG2005, French Avocado and RRR1C0 like this.
  22. Apr 28, 2021 at 4:41 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Anybody else want to show off their kit? As I'm in the process of building mine and would love to see more kits to get ideas from.
  23. Apr 28, 2021 at 4:57 AM
    IndianaGeologist
    IndianaGeologist New Member
    I haven't yet seen one posted, but could have missed it, but a tire puncture repair kit and a portable air compressor and jump start battery I think are important if you're off the grid aways.
    Sunnier likes this.
  24. Apr 28, 2021 at 5:10 AM
    Damie Street
    Edsel
    I will be installing a ARB single compressor soon. Already have a jump start and have added a tire repair kit to my list.
  25. Apr 28, 2021 at 5:11 AM
    Damie Street
    Edsel
    This is also on the list and my starting point. Will be ordering very soon.
    IndianaGeologist likes this.
  26. Apr 28, 2021 at 5:24 AM
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    Following
  27. Apr 28, 2021 at 7:05 AM
    Sunnier
    Sunny
    San Diego, CA
    This is cool, you sharing all the components so others can duplicate your kit!
    I hope you don’t mind me adding words of caution, in case a newcomer follows your lead:
    for most of the terrain out west, tires will need to be aired down a lot more than 10# off-road.... I see a lot of Taco guys carrying refillable air tanks but usually swap to a compressor once they switch to a Tundra with 35’s. Another factour is, the tanks don’t always get filled to exactly full, so you may not have as many refills as you’re counting on. Probably you could add a guage to the tank to keep track— like I said, just want to offer another perspective to anyone following along that puts money into this kit. An awesome back up would be a cheap-ass portable compressor off Amazon to keep under the back seat.
    And my word of caution here is, once someone knows someone with a newer vehicle that had all the bells and whistles screwed up by jumpstarting someone using cables, they won’t do it again. I still carry jumpers in one truck, but I know I’ll have to find someone else with an old vehicle to give me a jump.
  28. Apr 28, 2021 at 7:12 AM
    IndianaGeologist
    I'm out of the loop on this, how does this cause problems? I had a newer jeep that needed a jump. We used cables and had no issues.
  29. Apr 28, 2021 at 8:24 AM
    Sunnier
    Sunny
    San Diego, CA
    After I learned from a second friend (two over a decade+) their vehicle electronics (computer) failed after jumpstarting another vehicle, I asked my mechanic. He told me this *shouldn’t* happen because voltage in all vehicles should be the same. But he said he’s had cars towed in with a backstory indicating the failures were related to jump starting another vehicle. He suggested it might be that the jumper cables were bad, or the jumpers connected wrong— or the vehicle needing a jump start had some other issue (after-market mods as an example) that caused the vehicle to go down— and somehow that problem led to issues for the vehicle attempting to jump-start it. So... the info is anecdotal based on the described experience of others. I have personally experienced people unwilling to jump-start other using cables, based on this possibility.
    This is why I mentioned, not that it is bad to use jumper cables, but that it’s harder than it used to be to get others/ strangers-when-you-need-help to give you a jump-start. Based on this, I bought one of the portable jumpers, rather than risk waiting on someone willing to risk it, if I get stuck out on the middle of nowhere.
  30. May 20, 2021 at 1:22 PM
    TRD_FanMan
    TRD_FanMan New Member
    2021 Tundra SR5 4x4 OffRoad
    I carry a full set of ASE and Metric Tekton open-ended wrenches, sockets (deep/shallow), basics (hammer/screwdirvers/pliers/vise-grips/etc..), Tekton allen wrenches, a fresh spool of bailing wire and heavy-duty zip ties. That should pretty much cover anything I've run into and needed (so far!)
