Camburg UCA install
Discussion in '1st Gen Tundras (2000-2006)' started by ajmorenoaz, Jun 22, 2020.
  1. Jul 26, 2020 at 7:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You'll be fine with a 285/75/16. You'll rub frame a little bit but it's not bad. You'll need to do minor trimming on the body and maybe front bumper.
  2. Jul 26, 2020 at 12:34 PM
    ajmorenoaz
    ajmorenoaz [OP] New Member
    2000 Tundra Sr5
    Damn lol so I should stick with the 4 backspace then? 3.75 Isnt enough huh or maybe a 16x7.5 rim altogether?
  3. Jul 26, 2020 at 1:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    16x8 with 4 inch BS is the sweet spot on a gen 1. Clears the frame and does the best job clearing fender
    Darkness and ajmorenoaz[OP] like this.
  4. Jul 26, 2020 at 3:50 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    What size tire are you looking to run?
    Based on a 285 tire:
    4" BS with an 8" wheel is best
    4.5" BS with an 8" wheel is good, minor rub on frame and hardly any rub on body
    3.75" BS with an 8" wheel won't hit frame but will rub body more.
  5. Jul 26, 2020 at 6:17 PM
    ajmorenoaz
    2000 Tundra Sr5
    I’m putting these on tomorrow with the 4.5 backspace if the frame rub isn’t bad
  6. Jul 26, 2020 at 6:19 PM
    ajmorenoaz
    2000 Tundra Sr5
  7. Jul 26, 2020 at 6:20 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Check out Salinas Tires. They have really good prices.
  8. Jul 26, 2020 at 7:33 PM
    ajmorenoaz
    2000 Tundra Sr5
    LBR Off-road has great prices on rims that’s where I’m going tomorrow
  9. Jul 26, 2020 at 9:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You'll be alright. No matter what wheel if you run a 285 tire you'll have to do some minor shit to make them not rub. The frame rub will only be at full turn. I don't even notice it, I run 4.5 backspace.
  10. Jul 26, 2020 at 9:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can always tack on a small piece of metal onto your steering stops right? That prevents frame rub
  11. Jul 26, 2020 at 11:27 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ehh, you could tack a little block on the lower arm where the ball joint hits but not sure that limiting steering that way is worth the effort and might even be bad for the rack. I've had 4.5 bs and 285s for ten years and I wouldn't bother since I'm in a rust free state.
    Hbjeff[QUOTED] likes this.
  12. Jul 26, 2020 at 11:42 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You have the patience of a saint my friend...
  13. Jul 27, 2020 at 3:54 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Here is what 16 years of 285/75/r16 rub look like on the frame with OEM Patrick Style Rims and no spacers/adaptions done the anything.
    bmf4069 and Darkness like this.
  14. Jul 27, 2020 at 6:42 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine is a little milder than his ^
  15. Jul 27, 2020 at 1:45 PM
    Fred
    Hand Protectors
    Its really just a shiny spot wear the black paint wore off. Makes my truck a little slower.
    Darkness[QUOTED] likes this.
  16. Jul 27, 2020 at 8:50 PM
    ajmorenoaz
    2000 Tundra Sr5
    Methods were the way to go
    Put them on today
    I’m running
    Icon Dynamics 2.5 Coilovers
    Camburg UCAs
    Method 305 Nv rims (size 16x8 with the 4.5 backspace)
    BFG KO2 285/75r16
    revtune, bmf4069, saybng and 4 others like this.
  17. Jul 28, 2020 at 5:12 AM
    Fred
    Hand Protectors
    Rubs?
  18. Jul 28, 2020 at 5:38 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looking real nice
    ajmorenoaz[OP] likes this.
  19. Jul 28, 2020 at 5:57 AM
    ajmorenoaz
    2000 Tundra Sr5
    Not yet.. I haven’t noticed it yet it doesn’t rub anywhere as much as it did with the stock wheels and a spacer
  20. Jul 30, 2020 at 10:37 PM
    #50
    ajmorenoaz
    2000 Tundra Sr5
    Update there is a rub at max turn I believe it’s the body I haven’t looked yet I noticed it for the first time tonight leaving the gas station
