Fog Light Install Help
Discussion in '1st Gen Tundras (2000-2006)' started by Hooptytrix, Jun 6, 2019.
  1. Jun 6, 2019 at 5:48 AM
    Hooptytrix
    Hooptytrix [OP] Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    My 2005 SR5 DC did not have OEM fog lights. I read a few threads which explained how to. I swapped the turn signal stalk with a used one, installed the relay in the fuse box, installed the lights and plugged into the OEM wiring and turned on the lights and then turned the fog light switch...... High beams come on, no fogs. High beams work correctly using the stalk as intended but they also come on when you turn the fog lights????? I'm stuck as of now.
  2. Jun 6, 2019 at 6:28 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    when I installed LED headlights and foglights only my highbeams came on, no fogs. I have read that a resistor is needed for one of the headlights and that will fix it. Not 100% certain if that is your issue, but sounds like it. I know that the LEDs draw less power, so that causes issues. I wonder if there is a connection off somewhere causing it to 'not complete the circuit' or something along those lines. My resistor was like $10.
    I know this is a long shot, but I thought I would throw it out there in hopes it might lead you to your problem! Good luck!
  3. Jul 30, 2020 at 3:57 PM
    2truckornot2truck
    2truckornot2truck Aspiring Truck Guy
    Felix
    2006 Tundra DC SR5 V8
    None yet! Does steering wheel cover count? :)
    Hi did you ever figure it out?
