Rear Diff fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by slongo, Jul 29, 2020.
  1. Jul 29, 2020 at 4:34 PM
    slongo
    slongo [OP] New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    Took the Forum advice - I ordered the Ravenol 75/85 Diff fluid and plan to change front and rear fluid as soon as the 100 degree Humidity take a break .
    Is there enough room to refill the Diffs with the Ravenol spouts or do I need to figure out a pump system ?
    Thank you for any and all help
    YardBird likes this.
  2. Jul 29, 2020 at 5:32 PM
    TemujinNomad
    TemujinNomad New Member
    Rear diff can be poured directly from bottle. Front and transfer needs a pump.
  3. Jul 29, 2020 at 5:48 PM
    SeminoleATL
    SeminoleATL New Member
    2014 Limited CM Blue
    Stock... for now
    I used a pump on the front a rear diff. O the TC, I used the ravenous spout and it worked perfectly. The rear would be easy with it.
  4. Jul 29, 2020 at 6:23 PM
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    Transfer case you can do with the spout easy
  5. Jul 29, 2020 at 6:38 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If changing at 30k i just use plain jane oil. How many owners of the big 3 ever change diff oil? I did on some of my Fords at 100k if they made it far.
  6. Jul 30, 2020 at 5:35 AM
    Blacktooth
    Blacktooth New Member
    Raleigh, NC
    2018 Platinum
    I used Red Line and had a tough time in the rear because of the bottle shape. Might as well pick up a $5 pump while you're getting your gear oil.
  7. Jul 30, 2020 at 5:54 AM
    slongo
    The problem I see is the Ravenol Bottles are a weird size top and a traditional pump isnt going to fit . What have others done when using the Ravenol products ?
  8. Jul 30, 2020 at 7:35 AM
    spn4125
    spn4125 New Member
    I recommend getting a halfway decent pump for the job. I bought a cheapo pump off of Amazon when I did my front and rear diffs and it took sooooo many pumps to empty each bottle. My forearms looked like popeye by the time I was done, it was miserable.
  9. Jul 30, 2020 at 11:46 AM
    SeminoleATL
    Stock... for now
    This^^^^^
    I used a transfer pump for the diffs using Penzoil and was slap wore out. To my luck, the Revenol is a different size so i had to use the spout in the bottle. SOOO Glad it dit. It works great. For reference, it is a flexible tube that extends probably 4-6" from the top.
