Java's 2020 Crewmax
Discussion in '2.5 Gen Builds (2014-2021)' started by java230, Jul 28, 2020.
  1. Jul 28, 2020 at 11:27 AM
    java230
    java230 [OP] New Member
    To start, I have never bought a new truck. Coming from a 4runner with 275k miles this is nice. Otto.... My wife calls is silverado (as in silver auto), also a Chevy truck, so I told her it could be silver Otto. Two words [​IMG]
    Debated a lot, front runners were GX460, Colorado zr2, and the Tundra. GX is too much $$ used even and small V8, Colorado is really unknown reliability, but good MPG, Tundra won out. Old school 6speed means shitty MPG, but the big V8 and Toyota reliability and here we are.
    Anyway, new truck, picked up with a whopping 7 miles on it.
    Grey on Grey interior. I was actually expecting black (I didn't read specs close enough I guess. Also the TRD Package).... But this is good. Grown on me greatly.
    500 miles later we are home. It EATS highway. Loving it.
    First Mod [​IMG]
    Friends are enablers..... Ordered a whole pile of parts before I even owned the truck.....
    Mod #2, Lamin X on the OE Fogs. TRD Package includes black LED headlights, and LED fogs as well.
    Have RCI Sliders and a canopy on order as well..... Looking at storage options for the bed, bed slide (half width) or drawer? Options.... But Excited for a new (mild) build. The 4runner is sticking around as backup car and beater to leave at trail heads when we backpack.
  2. Jul 28, 2020 at 12:04 PM
    java230
    Got some of the parts for my drawer. Half my cut list got lost in translation between the cabinet guy and me.... But that's ok, because math is hard! I had some dimensions off.... Should get the res of the parts today.
    Exterior grade MDO. Inside will get lacquered, exterior will be bedliner.
    Whipped up a quick clamp/square jig since I had some extra wrong sized parts....
    Sides are on. Screwed and waterproof glued. Top will get nailed and screwed. Needs to resist the upward force when the drawer is pulled out.
    Will set it in the bed before the top goes on. Drill up from under for Tnuts. Then it will be bolted in place from below for final install.
    For switching I went with the ARC 4001, 4 circuit, 30 amps each using standard relays. Not standard off road equipment, but has been used for race cars forever. Complete warranty forever. Not as fancy as a sPod but should work.
    MTRock likes this.
  3. Jul 28, 2020 at 12:58 PM
    I'm looking at a white one here...it is 44K out the door :eek:
    java230[QUOTED][OP] likes this.
  4. Jul 28, 2020 at 1:06 PM
    java230
    This one was more than that!!
  5. Jul 28, 2020 at 1:32 PM
    Varies by market I guess.
  6. Jul 28, 2020 at 3:13 PM
    java230
    I need some actual time to work on the truck.... Parts are piling up all over!
    DSR1 and Infinity amp. The stock stereo is garbage. REALLY bad. DSR1 interfaces with the digital signal from the headunit and converts to normal analog for the amp. Only good thing is Toyota put the factory amp under the pass seat, so all the connections to the speakers and whatnot are right there. Have a nice P&P harness, so zero hacking into OE needed. Just need to run 4ga power.
    SDHQ ditch light brackets. Really nice pieces. I have never really liked the look of the ditch lights but I am going to try. Ill run them as reverse lights if I hate it. Not a lot of real estate for lights on these.
    Annnd roof rack parts just showed up! Going to try using 8020. Took a gamble on length, don't have the canopy to play with yet (corona slowing things down.....) so the cross bars may be a little short to mount awning on easily.... But 8020 looks pretty slick! I went with a double width.
    Lots of structural corners/connectors etc.
    And before anyone freaks out, I don't plan to have huge loads on the roof. Canoe, a sheet of plywood, 2x4's etc.
  7. Jul 28, 2020 at 3:20 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Nice looking truck! Welcome from Michigan. The mods didnt take long to get started! Good to see.
    java230[OP] likes this.
  8. Jul 28, 2020 at 3:24 PM
    java230
    Thanks!!
    Had an hour and a half to make some progress yesterday.
    Laid out for L track. Its not going full length as I expect the dog to be at the front most of the time (and this was an 8' piece :) )
    Pocket routered out.
    Nice tight fit. I took a lot of material out of the ply, and wanted to be able to add that structure back with the track.
    System Three G-Flex epoxy. I have used this stuff before and its amazingly strong and flexible. Designed for fixing aluminum boats. You can literally bend the thin coat left behind in the mixing cup without it fracturing at all. Should hold up well to vibration and material movements with temps.
    Clamp it up and leave it alone.
    A little foil tape on the ends keeps the track from filling.
  9. Jul 29, 2020 at 9:32 AM
    java230
    Assembly time!
    Kreg screws are always just a touch proud, since I will be using UHMW PE for slides, I need smooth walls. 120 grit flap disk works great.
    Now the hard part, holes in the new truck.... 7 to be exact because I screwed up one location. Luckily it was just an 1/8" bit so easy to fix.... 4 in the back 1/3, two in the front.
    Back side get 4 recessed 5/15" T Nuts. They will be bolted from below.
    Front gets two Riv nuts, to be installed from the top.
    Top goes on, glue and 18ga nails, plus some screws in select locations.
    No shiners or glue dribble on the inside, so back can go on. All the nails and screws holes were filled with plastic wood putty.
    Next drawer assembly!
    Well drawer assembly sucked. I inch'ed myself.... Need a new drawer bottom
    But I got The slides made. Uhmw U channel, ripped into L shapes. The leftover will go on the bottom of the drawer.
  10. Jul 29, 2020 at 9:39 AM
    java230
    Couple free minutes today.
    SDHQ light brackets on. Pretty darn simple.
    And these came to go on them! BD S1's in wide cornering. 2375 lumens for a single chip. Bright enough to see in daylight, I am curious how are will do.
    Got some time for the drawer today.
    Its big. Sand the edges so glue will bond.
    Recessed the latch
    It fits!
    Slides well on the UHMW, may need to add air holes.... Its got some suction
    Added an aluminum strike and catch for the latch
    Glued the slides in place
    TOYOTARIG and vanthesupreme like this.
  11. Jul 29, 2020 at 9:39 AM
    java230
    I no longer drive a turd.
    And if your ever doing vinyl stuff, get yourself this. A friend who does vinyl wraps recommended it, it works amazing.
    A little CAD. sorry lighting sucks...[​IMG]
    A little more are WA la.
    Transfer to ply, 2x because o can do it better than #1
    A little router and block action and it fits pretty damn well.
    Hopefully I can get the bed liner sprayed Wednesday.
  12. Jul 29, 2020 at 9:41 AM
    java230
    Canopy on! Sungtop rebel. Not bad.
    Remove one more sticker....
    All masked off for bedliner.
    Sprayed! I used a Scholtz gun I had, It's for bedliner and undercoating, but Raptor's gun must be much smaller orifice. Holy crap did I go thru it QUICK. Its only one coat, but does seem to be well coated.... 4 liters are supposed to do a full size truck bed, two coats.... I used two on this.
    Wait till it just sets up a little and peel tape!
  13. Jul 29, 2020 at 9:41 AM
    java230
    And drawer is installed! It fits great, my filler panel fits, and its not super heavy. Id bet 100lbs maybe. I can move it myself reasonably easy, its just awkward.
    First I had to finish the latch and strike. Glued and screwed in place. Latch is offset to add a webbing pull on the other side.
    Then added some brackets to hold the filler panel, just some scrape aluminum.
    Four bolts in the back, sealant on them, then a coat of paint for good measure too. Two in the front, from the top, didn't take pic...
    And WaLa! Works great!!
    Filler fits good.
    Cubby below, house battery will likely go there.
    Tight to the tail gate. About 1/8" there.
    Oh and new DFG Made in the USA aluminum slide. Nice little piece.
    tdawson05 likes this.
  14. Jul 30, 2020 at 7:23 AM
    java230
    Cut starboard spacers, get it up over the ridges, and the tailgate. Latch barely drags on the tailgate now. May add a little more spacer if needed.
    Install day finally came! Had a bit of help and it took us 5 hours 58 minutes from the time the truck got pulled in. We weren't really rushing, but the heat killed us.
    Working on a new truck is AMAZING. No rust, not much road grime even! Once the fastener was loose you could spin it off by hand even! Clean threads are amazing.
    Font In, taking the upper UCA off made it easy to drop the in CO in. Swapped to the SPC ones. Had to disconnect the sway bar to get just a wee bit more droop.
    And this was the only issue with the kit. The resi line must run outboard and forward on the CO's. They were both assembled the same way, so one needed to be flipped. Was not possible without breaking the flex line, so the top cap had to be removed. Off to the store for a 12mm Allen wrench, but simple.
    Rear end all free. Leafs are heavy. I am not super wild about how the OME kits does the brake line extensions, it simply raises them up off the axle. Seems like a spot to catch sticks etc..... Maybe find some longer replacement hoses.
    Forgot to take pics.... But all back together.
    Now onto the wheels. More sidewall is better IMO, so I downsized to a 17". They clear, but barely. They have a bit less backspace than I anticipated, but I think I can live with it. Make a bit more rubbing in the front, and a little more poke than I would normally run, but it was the only BS option in the 17"
    Wee bit of poke...
  15. Jul 30, 2020 at 7:24 AM
    java230
    First trimming was badly needed. Inner fenders in the front cut out, may need a little more after some articulation tests. Rear mud flaps cut, not much left.... Body mount will need top get whacked.
    Much more space than it appears...
    Not more space than it appears.....
    Then an attempt to keep some dust out....
    And then some power time!
    And while I was running the power, I saw this. Tucked behind the Tcase actuator. 1/29/20 is probably the trucks Bday
    Coming in a grommet on the bed. Fuse block will be above on the canopy.
    Tucked here temporarily. Breaker will likely be on the fender.
    And cheap me found some used goodies finally. One little dent, but otherwise quite clean.
    Ground wire runs down to an existing bolt on the frame.
    Bracket to hold the fuse panel. Pinched under the window frame and a dab of glue as well.
    Fuse block in place. Screws were run in and the backs ground off before install.
    Drilled a hole in the corner of the topper, terminated the wires and all loomed up.
    Circuit breaker mounted and wired up. A little trim and the OE battery cover snaps right back on.
    While I was there, made a little bracket. This gets held in place with the hatch bolts from the canopy, and gives me a spot to mount a light.
    Flexy light, red and white, with a dimmer. Made a little hook to keep it from dropping while driving. White velcro chunks are temporary.... Although they work really well!
    Excuse the mess of temp wiring, but I have one light and the fridge wired for this weekend.
  16. Jul 30, 2020 at 7:24 AM
    java230
    Great time hanging out with some old friends this weekend. First time in the dirt for the new truck. It worked great! No real complaints other than the canopy is rubbing on the tailgate. The layout worked well, and the truck just disappears gear into it. The 4runner was always stuffed to the gills!
    Ate a lot of dust. Drove up to the highest point you can drive in WA.
  17. Jul 30, 2020 at 7:43 AM
    java230
    OK that gets us current. Now a question. I need to move the TSS radar down to where the trd pros have it. Will the Jomax bracket do that? It uses an existing hole, but I was thinking I can drill another if needed.
  18. Jul 31, 2020 at 7:42 AM
    java230
    Body mount chop parts came in. I am thoroughly impressed. for $25, they cut and bend the plates, and send a laser cut template with them. Line the hole in the template up with an existing bolt and outline. Cannot get better! They are from SDHQ
    gabex35 likes this.
  19. Jul 31, 2020 at 1:56 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Truck looks great. What size tires are you running with those 17s?
  20. Jul 31, 2020 at 1:58 PM
    java230
    Thanks! I love it so far.
    They are a 285/75 (34x11.5)
    gabex35[QUOTED] likes this.
  21. Aug 10, 2020 at 8:10 AM
    java230
    Roof rack finally!
    Using 8020 profile. Had to make some angled spacer blocks, man a mill would be nice. Flap disk worked. Just making up for the curve in the roof.
    Spacer, and everything all bolted up.
    Tight to the roof, and added zero height. The shark fun antenna is still taller.
    Added a rubber strip to the top.
  22. Aug 20, 2020 at 2:45 PM
    java230
    These finally showed up! RCI sliders, ordered May 18th..... They are pretty nice though, and super beef.
    Bolts at the back edge, next to the gas tank sucked. A lot. Probably 45 mins on one stupid bolt..... Hydraulic lift table is awesome tho.
  23. Aug 25, 2020 at 9:44 AM
    java230
    Mud flap time. I was going to DIY, but figured Rockblokz would save me some time..... For what they charge I would think they would fit a little better! I assumed I would have to massage the font due to my wheels/tires, but I figured the rears would fit. Nope. Had to drill and oval a couple holes, and if you want them to stick out to the max, the two large holes for the bumps are exposed.....
    Definitely better coverage tho.
    Defiantly going to need to heat/mold/cut
    dpast88 likes this.
  24. Aug 25, 2020 at 11:14 AM
    java230
    Anyone have any luck moving the TSS sensor themselves? I need to drop mine to the Pro location.....
  25. Oct 16, 2020 at 9:46 AM
    java230
    Well someone finally built what I have wanted..... (yes its a different truck, but they are making Tundra ones as well) I planned to DIY one at some point, but man that is tempting.
    Jake91 likes this.
  26. Oct 26, 2020 at 2:14 PM
    java230
    Well look what showed up!
    Seems well built. But I hit all the edges with a flap disk, they were super sharp from cutting. Powdercoat doesn't hold up well on sharp edges.
    Now to figure out TSS sensor relocation.
    DaBoro54 and thetastelingers like this.
  27. Nov 16, 2020 at 8:14 AM
    java230
    Well here we go! Bumper is back from powdercoat.
    Service position. Note the grill is supposed to be put back on before bumper goes on..... I didn't....
    Comeup 12.5rs and fog lights installed.
    Bumper on!
    Reinforcement brackets that bolt into the stock tow points. IMO good not to just rely on the frame horns.
    Wiring in the rain....
    Wires from the solenoid pack to the winch itself were lice and long, and color coded too! Bolted the controller straight to the bumper next to the winch. T slots in the back made it easy! There is no good access to the controller. You can get to it from the front, barely. I figured if I was buried in a mud pit etc I really wouldn't want to try to plug the controller in under water. So all the wires got extended.
    8 conductor marine tinned wire was used. Not much room to spread the splices out, so its a little ugly.
    Goobered the back of the plug with dielectric grease and wrapped up.
    Whip up a little aluminum bracket.
    Now the plug is next to the washer bottle under the hood.
    Weatherpacks on the OE wiring for the fog lights.
    Off to find a Xmas tree! Got rejected right around the corner sadly... Rain on snow makes for some snotty stuff, and being alone I didn't want to push it too far.
  28. Nov 16, 2020 at 8:52 AM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    ^ What is the vehicle with the awning..... looks interesting
  29. Nov 16, 2020 at 8:55 AM
    java230
    Ltaco17 likes this.
  30. Nov 16, 2020 at 12:31 PM
    drobb
