Water pump gasket
Discussion in '1st Gen Tundras (2000-2006)' started by romezter, Jul 27, 2020.
  1. Jul 27, 2020 at 9:55 PM
    romezter
    romezter [OP] New Member
    Roland
    Los Angeles, CA
    03 Tundra
    Anyone know what the gasket between thermostat housing and water pump is called ? I attached a photo of the area. I can’t seem to find this gasket just did the timing belt and kit came with the paper gasket for this area and water pump. So have to replace with metal gasket
  2. Jul 28, 2020 at 3:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    romezter[OP] likes this.
  3. Jul 28, 2020 at 4:49 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    That joint was not assembled originally with a gasket, so a gasket won't be available from Toyota. Toyota used their OEM FIPG (formed-in-place gasket) sealant at that joint. A paper gasket was included in the kit for those that feel they need a gasket there.
    https://www.amazon.com/Genuine-Toyota-00295-00103-Formed-Place/dp/B000EDDTV0
  4. Jul 28, 2020 at 9:26 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Dont use the paper gasket there, just use the FIPG. And definitely use the metal gasket on the water pump, like you said. Paper will fail.
    revtune and romezter[OP] like this.
  5. Jul 28, 2020 at 10:30 AM
    romezter
    Roland
    Los Angeles, CA
    03 Tundra
    Next timing belt kit I’m buying will definitely be an Aisin kit. I had bought the dayco one off partsgeek. @Tundra2 i have a 4.7
    Thank y’all for the help
    Roland
  6. Jul 28, 2020 at 2:37 PM
    Professional Hand Model
    Fred
    Hand Protectors
  7. Jul 28, 2020 at 5:11 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
  8. Jul 28, 2020 at 5:16 PM
    Fred
    Hand Protectors
    Yeah. I was already aware this deep in the thread, but post #5 about the next timing belt kit prompted my posted link which is pretty thorough. Even comes with Drive/Cam Seals. Its great kit from the looks.
    I wonder now long the FIPG stays good in the tube? I still have nearly a full tube from the Valve Cover Gasket Job 2 years ago.
  9. Jul 28, 2020 at 5:20 PM
    abcinv
    Tommy
    NW Georgia
    That kit is pretty nice; I had to pickup several items outside my kit that are included with this setup.
  10. Oct 23, 2023 at 8:26 AM
    dpg1974
    dpg1974 New Member
    Danny
    2004 Toyots Tunra 4.7
    upload_2023-10-23_11-25-22.pngWhat about this gasket. It's on rock auto for my year Tundra?
  11. Oct 23, 2023 at 5:14 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I've only taken my engine apart enough to change the timing belt, but I never saw one like that. The water pump to thermostat housing doesn't use a gasket, only Toyota's gasket sealer, known as FIPG. (Formed In Place Gasket)
  12. Oct 23, 2023 at 7:33 PM
    bfunke
    bfunke Tundra Curmudgeon
    That looks like a coolant crossover pipe gasket like the one behind the intake
  13. Jul 1, 2024 at 8:53 AM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    Come on now, you know that gasket isn't a rectangle
  14. Jul 1, 2024 at 8:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    For shits and giggles, call your local parts place and tell them the other guys gave you the wrong gasket for a tacoma water pump. Ask them to describe it to you before you make the drive to pick it up. :rofl:
