  1. Jul 27, 2020 at 2:27 PM
    #6241
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The 88-95? GM trucks used a pretty neat light that had a 15 foot or so cord and a winding reel to store it. The can be "updated" with an LED simply. I've thought of that too
  2. Jul 27, 2020 at 2:30 PM
    #6242
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    From what I remember the light was attached with just a couple of short sheet metal screws in a reinforced part of the underside so that the screws had no chance of going through the hood itself.
    With LED strip lights being so inexpensive I think it shouldn't be too difficult to expand on PHM's puddle light mod for under the hood using a mercury type tilt switch to activate the light strips.
  3. Jul 27, 2020 at 2:38 PM
    #6243
    Professional Hand Model
    Fred
    Hand Protectors
    Its so much work doing this lighting stuff with all the wire runnings. I’d say buy a Husky Little Magnet light and be done with it. :rofl:
    FrenchToasty and Tundra2 like this.
  4. Jul 27, 2020 at 2:43 PM
    #6244
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You also don't work 3rds. You also have a garage.
    Run 4 strips of lights in a box shape. At each corner run jumpers from one strip to the next until you get back to the drivers side lift strut which will be the termination of strips.
    I need to see, and feel this mercury tilt switch before my brain will grab hold fully.
  5. Jul 27, 2020 at 2:46 PM
    #6245
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Jul 27, 2020 at 2:47 PM
    #6246
    Fred
    Hand Protectors
  7. Jul 27, 2020 at 2:49 PM
    #6247
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've got that specific kit on hand. Its actually in the truck. Haven't gotten to that job yet.
  8. Jul 27, 2020 at 3:14 PM
    #6248
    Lil Steve
    Gilbert, AZ
    I agree, installations can be a hassle and not worth it to some. I have a similar light from HF that works pretty well, and I always seem to have some sort of flashlight handy for that quick, take a looksie. But Noah has a point, sometimes you have no choice in when you are spending time under the hood. That's when good lighting/visibility is priceless. That truck bed strip kit looks like it wouldn't be too difficult to adapt for under hood use, even if staying with a toggle switch to turn them on/off.
    A cheapie USB rechargeable LED headlamp I picked up at Sam's Club a few years ago is what I reach for when I need to see better under the hood/dash etc. I'll settle for good enough in this case.
  9. Jul 27, 2020 at 3:30 PM
    #6249
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Lil Steve. Thank you for having my back.
    Very rarely have I been under the hood by necessity barring oil changes. I work/drive a lot at night. Lately I've been under the hood a lot by choice.
    I'm getting real tired of repositioning my light because its big, and bulky. Hard to find a good place for it. Never really liked elastic band head lights. Just not for me.
    My roll of light strips is free, and has pre-marked places to cut it. I think i could easily solder in jumper wires to tie all the strips in together.
    Heres my ideas for mounting.
    Blue lines are led strips, and green is the solder in jumper wires.
    I can't open the hood at work without risk of being fired. Off, or on the clock. Doesn't matter to the office. I'll investigate possible tie in points when I get home.
    NUDRAT[OP] and Lil Steve like this.
  10. Jul 27, 2020 at 3:44 PM
    #6250
    Lil Steve
    Gilbert, AZ
    @Tundra2 Your hood light mod seems very doable, looking forward to the end result. I'm now wondering how the adhesive backing on the strips will hold up with the heat from the engine, they might eventually come unglued and get caught in the fan! I know 3M makes all kinds of really strong double sided tape or maybe mount them with some sort of silicone/RTV? Just something to think about.
    Tundra2 and NUDRAT[OP] like this.
  11. Jul 27, 2020 at 3:53 PM
    #6251
    Festerw
    Festerw New Member
    04 Tundra DC
    Buy the splice kit for those lights. I'm not sure you'd be able to solder those strips easily because they're super thin. I've used similar to these just depends how many pins the strip has.
    https://www.amazon.com/Nelyeqwo-Connectors-Solderless-Gapless-Connector/dp/B082FGH4GH
    Lil Steve and FrenchToasty like this.
  12. Jul 27, 2020 at 4:07 PM
    #6252
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    OoooH
    That's the biggest reason why I haven't done it yet. I'm a-scared.
    Didn't know such a kit existed. I'll have to investigate these on my next break. Thank you!
  13. Jul 27, 2020 at 4:21 PM
    #6253
    Lil Steve
    Gilbert, AZ
    Tundra2[QUOTED] likes this.
  14. Jul 27, 2020 at 4:39 PM
    #6254
    Festerw
    Festerw New Member
    04 Tundra DC
    On the tape. You want 3M VHB tape, clean everything, then clean it again before you stick it on.
    Tundra2 likes this.
  15. Jul 27, 2020 at 4:41 PM
    #6255
    Fred
    Hand Protectors
    Chilling at Lake St. Barts with the Egret all day.
    bmf4069 and Tundra2 like this.
  16. Jul 27, 2020 at 4:48 PM
    #6256
    @empty_lord
    Our 2010 4runner has been starting strange lately and throwing a engine code P0335 crank shaft pos sensor. Is it best just to pull it and replace it, another tech mentioned make sure the WP isn’t leaking and slinging crap all over the sensor. I checked my Reservoir and it’s mid range, not empty. Then I finally found a thread on how to replace it, and it sounds like I should just replace it while I’m there for the amount of work it is to get it out. Any thoughts? also it has a viper remote start, I’ve been reading if the transponder box is going bad, it can cause a long crank issue which may throw weird codes, it’s just weird that it has slightly longer cranks than normal, even w the key.
  17. Jul 27, 2020 at 5:09 PM
    #6257
    Fred
    Hand Protectors
    @empty_lord or anyone else what is the difference between these 3 radiators? Says all fit 2002. Pic grab from online local Toy Stealer Programme.
  18. Jul 27, 2020 at 5:16 PM
    #6258
    Fred
    Hand Protectors
    I read that thread and thats mucho work. I haven’t had any sensors go bad on the 2002 Tundra, but plan on replacing them with the timing belt replace because the drive shaft and crank shaft ones look like lots of work like the 4Runner.
    I’d say replace it since your code is telling you its bad.
  19. Jul 27, 2020 at 5:19 PM
    #6259
    Lil Steve
    Gilbert, AZ
  20. Jul 27, 2020 at 5:19 PM
    #6260
    1st and 3rd are the same part except one is made for DC trucks, the other is for non-DC trucks. Middle one I don't know, except it's for a non-DC truck. I'm assuming at that price point, it must be a higher performance part?
  21. Jul 27, 2020 at 5:23 PM
    #6261
    Yeah the tech said it’s not to bad, but not a 5 minute job either, I will inspect for coolant seepage/weepage/leakage, but he makes it sound like a transponder issue. There’s another audio guru in the club that I was referred to, I’ll ask him what he thinks(he’s done a ton of installs and seems to know what’s what)
  22. Jul 27, 2020 at 5:23 PM
    #6262
    Fred
    Hand Protectors
    Online clickings say all three fit on Toy Stealer Site. My other cross reference sites say unsure, but do not say ‘Does Not Fit’. My truck is 2002 so no double cab.
  23. Jul 27, 2020 at 5:26 PM
    #6263
    Fred
    Hand Protectors
    Looks like 4 hours solid on my back to me.
  24. Jul 27, 2020 at 5:27 PM
    #6264
    Haha that’s how I read it too! I’m in gravel so that’s like 6 for me!
  25. Jul 27, 2020 at 5:32 PM
    #6265
    Fred
    Hand Protectors
    I’ve been using this Break Dance Mat which helps. Keeps warm in the winter and not bad in summer. Brings back memories.
  26. Jul 27, 2020 at 5:42 PM
    #6266
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Check freeze frame and see if the battery voltage is really low when it sets
  27. Jul 27, 2020 at 5:52 PM
    #6267
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  28. Jul 27, 2020 at 6:06 PM
    #6268
    Lil Steve
    Gilbert, AZ
    Un bicho! :rofl:
    No idea what that is but my (Android) phone's camera has Google lens built in and has been pretty helpful trying to identify stuff. I just tried it scanning the pic on my phone while looking at my computer screen and it's not getting accurate results. Maybe you can try a similar app on your phone and scan/take a picture. Sorry, that's all I got.
    Darkness[QUOTED] likes this.
  29. Jul 27, 2020 at 6:08 PM
    #6269
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  30. Jul 27, 2020 at 6:30 PM
    #6270
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Checked out those solderless connections. They look sweet except I would need a 90° bend. @Festerw
    Something like this.
    Or this.
    Checked out that tape that @Lil Steve suggested. Looks like good stuff. When I get home I'll measure a rough ball park for just how much tape I'll need. Place one order, one time.
