6" ReadyLift (spacer kit) shock upgrade question
Discussion in 'Suspension' started by Fotnot, Jul 27, 2020.
  1. Jul 27, 2020 at 7:38 AM
    Fotnot
    Fotnot [OP] SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm trying to verify some information/get some suggestions.
    I put my 6" ReadyLift w/ bilstein 5125s for the rear on my 2017 4wd truck that has the spacer kit and not the coilover kit. I drive mainly highway/interstate roads about 99% of the time, so I don't need the coilover kit. The lift utilizes the stock shocks and coils in the front. As of now, the lift has the 6" block up front, and the 4" block in the rear. When the time comes to replace the front shock, I was going to upgrade to the bilstein 5100s on the lowest setting. Now I know this will be about .75-.85" taller than stock. So with that said, could/should I just go ahead and replace the rear 4" block with 5" block to prevent any carolina squat? With the 6" ReadyLift kit, it has a slight reverse rake now by about .25-.5". Am I going about this the right way or is there something I'm missing/not thinking about? Again, any suggestions/tips/ideas/etc. are appreciated. You won't hurt my feelings if you tell me I'm an idiot and all (like really, there's nothing you can say that will hurt my feelings lol). Lift was put on with 54k miles and I am hitting 60k today on my way home. I'm just wanting a lil bit softer ride. Mostly when I'm running over the 5 sets of train tracks I have to cross daily 2xs a day.
    kJtQuLdkvbVhHGSmGVtJksIl1ZVsQ0D0CmxZV-Z7_45521c2d7d7861ac330456051d8d20b39ccae82a.jpg
    jeremyd likes this.
  2. Jul 27, 2020 at 7:44 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you’re upgrading your shock, you should buy one made for a 6 inch lift and get rid of that brick of a spacer.
    in the back you should do a shackle and not a taller block
  3. Jul 27, 2020 at 8:33 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    You're saying to remove the 4" block and replace the stock shackle? I'm not opposed to it. Do you know who offers a 5" shackle?
  4. Jul 27, 2020 at 8:36 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    No, you can do a 1 or 1.5 inch lift shackle to get more instead of a taller block. Personally i would be looking for a custom leaf spring with that much lift.
    Fotnot[QUOTED][OP] likes this.
  5. Jul 27, 2020 at 9:32 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I did a 4" procomp lift with the billsteins up front at the lowest setting to give me roughly a little more than a 1/2" up front along with a plus 3 coachbuilder shackle in the rear along with the block and add a leaf that come with the kit
    Fotnot[OP] likes this.
  6. Jul 27, 2020 at 12:48 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I run a 3 inch block and a 1 inch shackle in the rear, no issues. Also been towing like this for the last 50k miles. Your easiest option is to slap a 1 inch shackle on the rear.
    toyofan87 and Fotnot[QUOTED][OP] like this.
  7. Jul 27, 2020 at 12:50 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm starting to lean towards the shackle. I may get one that's adjustable between 1" and 1.5" in case I need/want a little more.
  8. Jul 27, 2020 at 12:55 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    1 inch setting.
    Hbjeff and Fotnot[OP] like this.
  9. Jul 27, 2020 at 12:58 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    brand? and where'd ya buy them from?
  10. Jul 27, 2020 at 1:00 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    They were 50 bucks on Ebay. There are plenty of choices out there.
