Access vs Double Cab Driveshaft & Fuel Cell
Discussion in '1st Gen Tundras (2000-2006)' started by esg612, Jul 26, 2020.
  1. Jul 26, 2020 at 10:46 AM
    esg612
    esg612 [OP] New Member
    Truckee, CA
    Hey guys,
    I've had my 03 Tundra for a few months now and have absolutely been loving it. Unfortunately I had a rock crush my fuel cell and rear driveshaft the other night and I'm wondering if a driveshaft and fuel cell from a double cab will fit in my access cab? One of the pick n pulls near me has a double cab with both of those still in it so I'm just trying to figure out if either will work for me.
    Thanks!
  2. Jul 26, 2020 at 11:05 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    You could take a look at it and measure the drive shaft and see if it is the right length, and has the same mounting fixtures. Same with the fuel tank. Or check Toyota part numbers to see if they cross reference.
  3. Jul 27, 2020 at 11:10 AM
    I'm almost positive the driveshaft won't. Fuel tank should be fine. Where's @Professional Hand Model with that part number thing?
