  1. Jul 26, 2020 at 8:08 AM
    #6211
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    @FirstGenVol this is where I was saying yo I could put your fuse tap.
  2. Jul 26, 2020 at 8:12 AM
    #6212
    Professional Hand Model
    Fred
    Hand Protectors
    I meter tested that location a few months ago and it reads 30amps with ignition power off. I remember bringing it up and @empty_lord said it could be tapped but go no higher than 10-15amps.
    lsaami[QUOTED] likes this.
  3. Jul 26, 2020 at 8:20 AM
    #6213
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I eat e coli for BWEKFAST
  4. Jul 26, 2020 at 8:21 AM
    #6214
    Pucks18
    @Tundra2 me and you seem to be equally obsessed with our own trucks. Somethin about them.. the difference is you have the mechanical ability to do major things to it! Lol
  5. Jul 26, 2020 at 8:35 AM
    #6215
    Fred
    Hand Protectors
    My fweeings are hurt!
  6. Jul 26, 2020 at 9:57 AM
    #6216
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    How many amps and watts does that fridge require? You may need to run a heavier gauge cable to power it properly
  7. Jul 26, 2020 at 4:39 PM
    #6217
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Jul 26, 2020 at 4:55 PM
    #6218
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Jul 26, 2020 at 4:59 PM
    #6219
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was a VERY tricky soldering job without a solder sucker. The first go round I put the led bulb in backwards and I thought I messed up the in-laid pathways on the board. SCARY!
    Leds are like a check valve for electricity. Only flows one way.
    theblurry1 and lsaami like this.
  10. Jul 26, 2020 at 5:02 PM
    #6220
    lsaami
    lsaami Let ‘er buck
    Minnesota
    looks great!
    Tundra2 likes this.
  11. Jul 26, 2020 at 5:05 PM
    #6221
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I am considering doing this for a small fee. Obviously, I have only done the access cab style currently. Just an idea I'm kicking around. :confused:
    The smallest bag of free leds I could find was 100 count so I have plenty of extra.
    NUDRAT[OP] and Hooptytrix like this.
  12. Jul 26, 2020 at 5:18 PM
    #6222
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    THANKS! I was really worried about breaking stuffs
    theblurry1 likes this.
  13. Jul 26, 2020 at 5:37 PM
    #6223
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well I'm INCREDIBLY sentimental over this truck in particular. The way I see it is that this truck will help me remember all the adventures Pops, and I have been on. All the good things I've experienced because of this truck. When I say I will drive this truck the rest of my life... I don't think most of you realize just how serious I am about that statement.
    I was, and still am scared to work on my truck. Make no mistake about that.
    I've learned through employment lots of practices, both good/bad. Drill, and tap holes. How to lift things.
    How to fuck off on the clock.
    ALWAYS use the correct tool if you can. For instance use the correct wrench/socket instead of an adjustable wrench, or vise-grips.
    The most important lesson I've learned is plan ahead, and take your time. Don't get ahead of yourself.
    Work has taught me a lot of things. Comes in handy working on a light duty truck. Keep in mind I'm used to changing out parts, and making adjustments on 20 ton injection presses.
  14. Jul 26, 2020 at 8:04 PM
    #6224
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Jul 26, 2020 at 8:06 PM
    #6225
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Not bright enough. I still have retinas
  16. Jul 26, 2020 at 8:08 PM
    #6226
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its a work light for me. Lol
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Hooptytrix likes this.
  17. Jul 26, 2020 at 9:05 PM
    #6227
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Checked for new engine codes. All good! Time for ceremonious drive!
  18. Jul 26, 2020 at 10:36 PM
    #6228
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  19. Jul 27, 2020 at 4:13 AM
    #6229
    @FirstGenVol I'd definitely check the nameplate on the fridge to see what you need. If it doesn't give it in amps, take the wattage and divide by 12. If the factory outlet is rated for that, you can take an add a tap directly from a constant hot in the fuse box, d/c the factory wire, and add the new one. 15A is 14 guage min, 20 is 12.
    One thing to consider: 15A is a pretty large draw to put on a battery not being charged. If you don't have a good/newish battery, you might come out the next morning to a dead battery.
  20. Jul 27, 2020 at 4:35 AM
    #6230
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
  21. Jul 27, 2020 at 4:43 AM
    #6231
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was kicking that idea around for awhile. It would make my night shift jobs suuuu-weeeeeeeet! Eliminating the big bulky milwaukee rover. Me personally I would like to find a switch, and install it in such a way so they come only when the hood is up. Automatically!
    Barring that a simple toggle switch would work too. Not sure how much heat LED strips can take though.
  22. Jul 27, 2020 at 4:51 AM
    #6232
    Fred
    Hand Protectors
    Actually, I’m in deep research on his light bulb door switch install right now. Been up all night analyzing the best solder tools and microchips needed to get things done.
  23. Jul 27, 2020 at 4:53 AM
    #6233
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh the window switch?
  24. Jul 27, 2020 at 4:53 AM
    #6234
    Pucks18
    Looks like next month ill be moving to fort collins colorado baby
    Hooptytrix, NUDRAT[OP], Dog and 2 others like this.
  25. Jul 27, 2020 at 4:57 AM
    #6235
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Professional Hand Model it took me some time to tinker with it to get it right. Gotta make sure the bulb is in the right way, and that you don't burn up the in-laid board pathways. A tricky job for sure! Good luck.
  26. Jul 27, 2020 at 10:13 AM
    #6236
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  27. Jul 27, 2020 at 10:32 AM
    #6237
    Info? What when why?
  28. Jul 27, 2020 at 1:54 PM
    #6238
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Many years ago I had an early eighties Chevy Suburban and it had an under hood light that had a built in mercury/tilt switch. The mounting of the light provided the ground and the positive was wired to a constant 12v supply. Putting in a halogen bulb made it a really bright under hood light, I'd imagine something like it exists in LED form nowadays.
    Here's a pic I found online that looks very similar to the light my truck had...
  29. Jul 27, 2020 at 2:14 PM
    #6239
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sweet-ness. Might be hard to mount on our hoods without a pre-made stud being on the hood. I was just gonna look into using the left over LED strips I have, along with the wiring, and etc.
  30. Jul 27, 2020 at 2:14 PM
    #6240
    Fred
    Hand Protectors
    I bought one of these the other week and it perfect. Rechargeable. Nice light. Strong magnet and lightweight. Has three modes.
    Hooptytrix and artsr2002 like this.
