Upgraded
Discussion in 'General Tundra Discussion' started by JROCK915, Feb 10, 2015.
  1. Feb 10, 2015 at 8:36 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Got her sit'n pretty now!
    tat2ude39 and Wisconsin Bill like this.
  2. Feb 11, 2015 at 4:31 AM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    Nice! :thumbsup:
    JROCK915[OP] likes this.
  3. Feb 11, 2015 at 5:58 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Lookin Good!
  4. Feb 11, 2015 at 6:17 AM
    What's the height difference in the front from the rear?
  5. Feb 11, 2015 at 6:36 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    5" front, 2" rear.
    I'd like to bring the rear up 1", but that'll mean either: replacing the new shocks for some w/ longer pistons, or a bracket moving the existing shock foot, higher.
    Reason being, I'll be close to locking out the rear if I go another inch higher.
    IF...if she settles about a 1/2" (as to be expected) in the front, I won't worry about the rear.
    Any suggestions???
  6. Feb 11, 2015 at 7:42 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    OME extended rear shocks and Coachbuilder 3" shackles for the back maybe?
  7. Feb 11, 2015 at 9:11 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Nice. Yea I would crank the coils down in the front a 1/2" or so to be level and avoid additional cost in the rear.
    JROCK915[OP] and Wisconsin Bill like this.
  8. Feb 11, 2015 at 11:26 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Looks sweet! Congrats.
  9. Feb 11, 2015 at 6:27 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Do you know if Pro Comp, or Icon have an extended rear shock. I prefer to stay some what unison. I know Icon and MaxTrac has shackles I could get.
  10. Feb 11, 2015 at 6:32 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    I'm hoping I may not have to. I'm thinking in a month +/-, there'll be some "settling". IF not, I'm ok dropping a lil extra in the rear to bring it up.
    I'm hoping just a set of extended shocks will give me the 1/2" in the rear, that I'm looking for.
  11. Feb 12, 2015 at 7:05 AM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    I am about 80% sure all of those are extended as well so you should be good.
    JROCK915[QUOTED][OP] likes this.
  12. Feb 12, 2015 at 8:46 AM
  13. Feb 12, 2015 at 9:11 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    im putting some pro comp shocks on the rear of mine because i have 4" blocks. they have one that is designed for that. it was $80 for the pair
  14. Feb 12, 2015 at 5:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great. So jealous!
  15. Feb 12, 2015 at 10:29 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Do you know which ones? I'm running the Pro Comp Pro Runner SS in the rear now. My Krawler guy said I'm 1.5" from locking out my rear. So he didn't wanna put my 1" block back in.
  16. Feb 12, 2015 at 10:31 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Explain the shackles to me. Will they extend my shocks, like a block would? I'm not too familiar w/ those. Thanks
  17. Feb 13, 2015 at 9:22 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    ES9000 SERIES SHOCK - Part # EXP924518....unfortunately i tried to install last night and i couldn't seem to get it to fit. the top bolt seemed too short with all the rubber cushions. im calling them to see if they sent me the wrong one or what
  18. Feb 13, 2015 at 9:50 AM
    Check out this link.
  19. Feb 13, 2015 at 12:25 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    i got on the phone with seller and pro comp. first thing they said it was the wrong shock because it wouldnt give me enough travel. so they are sending me a shock for a 6" lift. but they didnt guarantee i would have a longer thread and said to shave down bushings...i may try another brand
  20. Feb 13, 2015 at 8:13 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Ok, so probably the MX-6 shock. I'll look into those.
  21. Feb 13, 2015 at 9:07 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Awesome. Thank you. I'll be ordering soon.
  22. Feb 13, 2015 at 9:08 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Oh, ok. It may be their MX-6.
    I'm shopping for some now.
  23. Feb 22, 2015 at 12:26 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
  24. Feb 24, 2015 at 8:55 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    i got mine in and installed. i ordered mine off of 4wheel parts.
    EXP929511
    07 Tundra Rear w/ 6 lift
    they fit they work great. i purchased some yellow boots to go with my scheme. worked out great. took 5 min.
  25. Feb 24, 2015 at 5:15 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Did you need to extend your brake lines?
  26. Feb 28, 2015 at 9:03 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    nope
  27. Feb 28, 2015 at 10:00 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Sweet!
    Got my new extended shocks in today. Gonna bring the ass up, another 1". I'd go 2", but I'm reusing my old blocks.
    Thanks for the info.
  28. Mar 1, 2015 at 1:17 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    cool. its an easy set up. will ride a lot better
  29. Mar 1, 2015 at 1:21 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
  30. Mar 1, 2015 at 1:28 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    as soon as these tires wear out. looking for some 38" tires. i have got some 33" on their now. but with the spindle lift and blocks in the rear and with some minor fabricating/cutting i can probably squeeze 38" tires in that will also give me an additional lift
